Question about Microtek ScanMaker 9800XL Flatbed Scanner
Microtek scanmaker 9800xl problem
Scanning line art, comes up all black with no image. Also, half way through the scan machine vibrates a little like something is getting stuck.
  • hariprawoto
    hariprawoto Jul 15, 2013
    I am Having on screen error message like shown herein. Can it be solved without replacing the lamp? cause my 9800XL is a brand new scanner that I just try to use at home.
9800XL - fix for failing lamps
1) Unplug the scanner - not just from the computer, but also from the AC!
2) If your unit has a Transparent Media Adapter on top, disconnect it from the back of the scanner, lift it off and set it aside.
3) Remove the four white slotted screws at rear of unit.
4) Remove the four Philips screws in the area surrounding the glass scanning bed.
5) Carefully lift the top off, and set it aside.
6) Inside the scanner, there will be a black metal contraption that rides the two steel rails in the unit. On the side of the contraption are some black screws. This device contains the lamps as well as the image sensor. Unscrew the 4 screws that hold the top cover on. Lift off the top cover. You may gently move the thingy along the rails for easier screw access, it will automatically reseat itself when powered on.
7) Inside this area, you will see a small circuit board. Disconnect the two connectors on it, remove the two screws that hold the board in place, and lift it out.
8) On this circuit board there should be one or two damaged capacitors. Unsolder them and replace them with 2 33pF 3kV capacitors (cost: under $1.00)
9) Put the whole thing back together, and it should function properly.
Posted on Apr 20, 2012
  • Vadeem Sep 16, 2014
    Hey Thanks! You were absolutely correct! Found two capacitors burnt to crisp! Thanks for info.
Every image scanned is black
have you check the lamp if is on?
did you felt down the scanner because maybe the lens is out of position and or CIS (the receptive od light module)
hope i help
Dec 02, 2010 | Microtek ScanMaker 9800XL Flatbed Scanner
I have a Microtec ScanMaker 9800XL connected to a Mac OSX 10.5.8 When I scan I get a black screen/no image. I have turned the scanner and computer on and of and have checked the connections. I last used...
did the lamp lights? replace it if not.
if the lamp lights and the comm between pc and scanner is ok and you take black image. then there was a problem on scanner module _light receiver_.
Scanner gives poor quality scan...bulb?
I have one with the same problem. Look at the lamp. If it isn't really bright, that could be the cause. Mine is bright at one end and that is the side of the page that is good. I am not an expert so I could be wrong, but that is where to start if all else looks OK. Am looking for a cheap replacement lamp myself. But at the prices of all-in-ones, it's not worth spending much.
May 26, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
Can't view the entire image area of a Microtek 9800xl
Go into preferances, overview preferances and adjust to full screen.
Feb 13, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
Lines across scan
It appears to be a freak problem. The best way is to bring it to original condition. Try uninstalling the scanner, run Scandisk on the Comp, Switch off and reinstall the driver. this may work.
S. Mohan
Feb 12, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
Xrays
You can't scan xrays unless you have a scanner capable of scanning film, which requires a film attachment.
Jul 29, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Microtek ScanMaker 9800xl
Try doing a fresh reinstall of the software for the scanner and then adjust the color ratios durring the install. I have found that every one to two years it is good to go through and refresh all my drivers for scanners printers ect.
Apr 25, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Microtek is famous for making a good product that will last you a good while if it is maintained and taken care of. Yet their lack of support for said products is lacking. Try to uninstall and reinstall all the software for the scanner. Make sure before you uninstall that you still have the install disc. If not then you can find the drivers on the Microtek site.
Mar 04, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Lines on scanned images
if the lense has dust on it how do i clean
Oct 29, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
Lines appearing in scanned images
it is due to following reasons 1. dust on lense 2. connector problem 3. laser lense gone 4. missalingment
Sep 28, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
Microtek ScanMaker 9800XL Flatbed Scanner Logo
705 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Michael
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
