Question about Panasonic KX-T7730 Corded Phone
Need to program pf buttons on kx-t7730
Hi
I have a kx-ta 624 with 6 co lines (3 in Use) and 24 extensions and i now need to program the pf buttons down the sides of the phones so that each co line is accesible and various extensions are avaliable. the only manuals that are online that i can find are quick referance gides that are next to useless.
Many Thanks
Henry
  • Anonymous Mar 12, 2014
    how to assign PF Buttons on panasonic kx 7731 phone
Press Program Button
Press Button to be Programmed
Dial 1 - Plus extention number to be stored on button
Press button directly under 'ENTER'
Posted on Feb 18, 2008
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    How to save number in kx-t7730
    Press program, and one of the 12 right side buttons. Dial 9 + number and STORE. This assumes that your dial "'9" gives you an outside line. If it doesn't, read about system programming and 400 where you assign the lines to be active or disabled. A "9" should give you dial tone as well as 81, 82, 83 etc. Instructions are in the OM of a TA-824 or the Users guide of a TA-624.
    Carl
    Jun 08, 2011 | Lands Phones
    I have panasonic kx-t7730 phone .i have 3 lines in same number from my service provider .2 lines are already assinged its working fine my 3rd line is not working when i try to press the 3rd button its...
    Your 7730 is just a phone. The programming is done to the SYSTEM that the 7730 plug into, from either a maintenance program on a PC or extension 101. There will be a programming manual (PM) for the particular system, be it a TA-624, 824 TAW or different system. In system programming, you turn the lines on in system program 400 and adjust the ringing in programs 407-409 (TA codes). You also have to plug the 3rd line into the CO3 port on the cabinet.
    Carl
    Apr 03, 2011 | Panasonic KX-T7730 Corded Phone
    How to set a new CO num into kx-t7730? screen is appear "CO not assigned"but the line already plug in .
    In analog system like the KX-TA series, the lines have to be both installed and programmed to a set. System program 400 sets the lines and pressing PROGRAM, a CO button on the left side of the phone and dialing 0x STORE sets the line on the telephone.
    There are also some access and ringing programs that need to be done in system programming and they are located in sections 407-412 or so.
    For example, if you added line 3, you would go to 400, make sure that CO 3 is enabled, then press PROGRAM on each phone and the 3rd button up from the bottom. If the display doesn't say "CO3", then you dial 03 STORE and that will set line 3 on the phone.
    Carl
    Feb 18, 2011 | Panasonic KX-T7730 Corded Phone
    I'm using Panasonic KX-T7730. and Panasonic Advanced Hybrid System KX-TES824BX . Please help me.I need to make security lock for outgoing calls ...
    In programming you can set up Forced account codes for Local, Toll, or All calls. The extension is flagged in program 605 or 2.1 of the system and the codes are put in 310 or 1.5. It's one of 2 ways you can do it, you can also change Class of Service on each phone to deny them access to certain numbers.
    Keep in mind that this is programming for a TA-824 release 3.0. We know loop start CO lines and no ISDN or BRI. Your system may be different.
    Carl
    Nov 23, 2010 | Panasonic KX-T7730 Corded Phone
    Panasonic kx-t7730
    Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
    PLEASE vote if this was helpful
    Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
    How do i add a new phone to an existing system? I have connected the phone & just need to assign an extension number for it so that the other phones can see the system, thank you
    If you have installed it on a new extension, it already has a number. By default, on a TA-series system, the jack and extension are the same, so Jack 12 is extension 112. Quickest way is to plug the phone in and dial 0. The main phone rings and the display will give you the extension number.
    To program the buttons, press PROGRAM the button and dial 1 plus the extension number. The lines should already be programmed by default, but they are 0 plus 01, 02, 03 etc. Press STORE after each button you program.
    If you want to program ringing and line access differently than it already is, you need to look in the Programming Manual for the specific phone system. The Panasonic cabinet is going to be white with a silver tag or a model number stenciled or embossed on the case. Something like TA-824 or TA-624 would probably be your system model.
    Carl
    Dec 15, 2009 | Panasonic KX-T7730 Corded Phone
    HOW TO PROGRAM ONE TOUCH DIALLING FOR KX-T7730 WITH CO BUTTONS ONLY ON THE RIGHT?
    So that we're on the same page, a 7730 has PF bottons on the right and "CO" buttons on the left. If you have a different phone, like a TA-308xx or a Euro phone that isn't offered in the U.S., then it may only have a single row of buttons.
    Programming is the same. If the button is a CO button (with a light), then your one touch requres a "2" in front of it to speed dial a nunber and a "9" or outside line access code to dial an outside number. So, to call 212-555-1212 you press PROGRAM the CO button, 292125551212 STORE. An inside number is stored under the CO button with a "1" plus the extension number.
    A PF button already has the assumed "2", so you would just dial 92125551212 in the example above.
    Carl
    Dec 13, 2009 | Panasonic KX-T7730 Corded Phone
    How to store numbers for speed dialling on Panasonic KX-T7730 having only 12 CO buttons.
    Well let's see. You have 12 CO buttons and 12 PF buttons, and at least 100 system speed dial numbers available.
    Which ones are you looking for?
    Depending on what Panasonic system you're connected to, the PF buttons program by pressing PROGRAM and the button, and dialing the number with a "9" or trunk access code in front of it then STORE. If you're connected to a TD system it's PROGRAM 99.
    System speed dial numbers are entered from the main or manager's phone under system program 001.
    Carl
    Jun 28, 2009 | Panasonic KX-T7730 Corded Phone
    KX-T7730 phone. Need to reprogram one of the PF buttons as a CO2 button. I accidently messed up the programming of this button while trying to program a different PF button as a one-touch dialing...
    Just so we're on the same page, the PF buttons are the 12 buttons on the right and their ONLY function is one-touch dialing. They can't be CO buttons. The 12 buttons on the left are called CO buttons and they can be programmed to do a number of things, including CO, DSS, and feature access buttons.
    To reprogram the button, press PROGRAM, the button, the dial 0 + the CO number (1-8) and STORE. Extensions are 1+ext and one-touch are 2+. Other features are in the programming guide.
    The PF buttons are programmed by just dialing the digits, but if it calls out, you must dial an access code first, usually "9".
    Carl
    Jun 17, 2009 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730 Corded Phone Logo
    450 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
