Question about Thomson 28VK25US TV
Rear Projection After an hour or two i realised my 44" rear projection color wheel had broken not my lamp fan the problem i have is getting hold of a new one can anyone help spent hours tryin to find someone that sells them thanks the model number and make is Thomson 44DLW617
  • BILLLEITH May 01, 2008
    YES MY LIGHT WHEEL SHATTERED I AM TRYING TO FIND A NEW ONE WITHOUT ANY LUCK SO FAR I THINK ITS CALLED A OPTICAL LENSE BLOCK
TRY contacting Parts suppliers like, VANCE BALDWIN ,TRITRONICS, MCM ELECTRONICS AND HERMAN/ PANSON For a few Charlie
Posted on Feb 12, 2008
Have sound no picture fan makes noise then stops
If lamp, color wheel (if used), or a number of other things are wrong set will do just as you describe.
remove lamp and inspect to see if shattered inside.
with lamp removed look where it faces (may need a mirror) to see if the wheel is there and or shattered or broken.
first two things to look at. Lamps in general have a 2,000 hour life=average user that is 2 years.
4_16_2012_1_30_56_pm.jpgcolor wheel (typical)
4_16_2012_1_31_36_pm.jpglamp unit (typical)
Apr 15, 2012 | RCA HD50LPW164 50" Rear Projection HDTV
Have sound but no video, also makes a high to low pitch noise,light blinks on start and stop switch. Sometimes it will come on if I wait an hour or so.I have changed the lamp. Could this be the color wheel...
Yes sir the problem is the color wheel try to replace it. Remove the lower access panel from the back of the set. To the left of the lamp housing, you see the color wheel. Unplug the two leads and, using the Torx screwdriver, carefully remove the three screws that hold the wheel to the lamp housing. Good day and best regards.
Sep 03, 2011 | RCA HD61LPW164 61" Rear Projection HDTV
HLR 5067W 6yrs old. I replaced the lamp and color wheel about 3 years ago. Last week the TV would not turn on. Fans run hard, no light from the lamp. Tries for 3 cycles, then shuts down and front...
Tv is on every day and watches 4 to 5 hours every day?Yes,3 years now the projection lamp require replacement again and the board that call the Ballast board might require replacement too,this Ballast board only job is it to ignite the projection lamp only..
Jun 04, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
When I turn my tv on it makes this loud noise like a motor is running and I have no picture. Any ideas of what the problem may be??
hi,
you have to che check three thing in your tv
1. lamp
2. lamp cooling fan
3. color wheel
you have mentioned that there is a loud sound can caused by the lamp cooling fan or by the color wheel. when the bearing of any one get damaged it will create aloud noise.
check the color wheel first. also check the lamp is it broken or not. if you need any more assistance feel free to contact me through fixya
ok
Feb 02, 2011 | Samsung HL-R4667W Rear Projection...
Tv stays on for couple of minutes and then shuts off
Hear any grinding or motor noises,pictures flashes or flickers in black and white?All these cause are the death of a colors wheel.Must replaced the colors wheel.When was the last time,this tv replaced it projection lamp?1 1/2 or 2 years the projection lamp was replaced,tv on and in used like 4 or 5 hours a day.The projection lamp life is over.Require a new projection lamp.
Aug 16, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
44 inch RCA hd44lpw62yx1...sounds like fan is
It not the fan.These noise all way came from the colors wheel.Tries Tv Repair World.com,Ebay.com for the part.
Feb 06, 2010 | RCA HD52W56 52" Rear Projection HDTV
Test
Ballast Lamp provide back light in DLP TV and if its bad / broken TV wont power up. If lamp is weak, dark or less bright picture will come in screen. Color wheel is responsible for colors in picture and if its broke, TV wont power up and common problem with color wheel is high pitch noise while it spins.
Jun 12, 2009 | Sharp 65DR650 65" Rear Projection...
Lamp won't come on and loud rattle in back of tv
Probably a defective color wheel. The bearings are bad or perhaps the wheel itself is broken.
Jun 12, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLN617W 61 i
it is not related to the failure of the fan or color wheel by anything other then the age of the set..the lamp has a normal life of 4000 to 6000 hours and since your set is around 3.5 years old it probably has that amount of time on it..the lamp is consumer replaceable and many places sell them..the lamp number should be on a small sticker on the side of the set
Dec 02, 2007 | Samsung HLN617W 61" Rear Projection HDTV
3 blinking lights no visual...just bought new color wheel
recheck those plugs from color wheel to dmd bd, when was the last time you replaced the lamp?
Oct 18, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
