Back to:
Tags:
HP Compaq Presario v3000z  PC Notebook
Unable to install Audio driver (by 21 users)
posted by AnandSingh on Feb 12, 2008
I have installed XP in Compaq Presario 707TU Laptop. I have configured audio as below. Install Microsoft UAA sp31994, then install High-definition audio driver sp33443. But I get the error message "Driver Installation Failed: Could not find the MEDIA device for this driver."
Please give me a solution ASAP.
unable to install Audio driver problem, and notify you when a new solution is offered.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
20 Other Users Have The Same Problem
Comment by Guest, posted on Aug 27, 2008
i have same prob......
Comment by vartul, posted on Aug 19, 2008
After installing Windows XP i installed the UAA diver. But then also the sound drivers are not installing. It gives the error Media not found. Please help
Comment by snigu, posted on Aug 15, 2008
After installing Windows XP on my system on trying to install the audio driver the system is giving the error message media device not found
Comment by hrishi_6032, posted on Aug 09, 2008
I have installed XP in Compaq Presario V 3000 Laptop. I have configured audio as below. Install Microsoft UAA sp31994, then install High-definition audio driver sp33443. But I get the error message "Driver Installation Failed: Could not find the MEDIA device for this driver."
Comment by Rogyvet, posted on Aug 03, 2008
I've installed windows xp in my pc compac presario c700, and i now don't have a sound. I downloaded all the drivers and but audio driver caused a problem. when i'm installing it, there is a message telling me "there is no media divice for this driver"... So help me how to get it.
Clarification Request
by Nitrotrike, posted on Feb 12, 2008
Did you try to use the HP auto update utility?
Best Solution
posted on Mar 07, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i have same problem. i cant install the audio driver to my compaq presario v3000. an error is occuring. what to do? pls help
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on unable to install Audio driver:
I don't want to Accept this solution
Solution #2
posted on Aug 08, 2008
FixYa! (100)
1ITguy
Rating: 92%, 2 votes
Try installing manually from add remove hardware or updating from Device manager, and locate the path of sound drivers.
Thank You!
Solution #3
FixYa! (100)
pkbytes
Rank:Wiz Wiz
Rating: 86%, 26 votes
Please check wheather service pack 2 has been installed properly because it is required for installation of high defination audio device instalation
Regards
Parveen
Thank You!
Solution #4
posted on Sep 27, 2008
Not Rated (0)
gregpg69
Rating: 0%, 0 votes
have installed XP in Compaq Presario 707TU Laptop. I have configured audio as below. Install Microsoft UAA sp31994, then install High-definition audio driver sp33443. But I get the error message "Driver Installation Failed: Could not find the MEDIA device for this driver."...
Thank You!
Can you Help with these PC Laptops problems?
PC Laptops
Not able to run any DVD on my Laptop Latitude D610 whereas...
PC Laptops
hello , i own a Fujitsu Siemens AMILO Pro V2035 laptop and...
PC Laptops
Pls help me to find SATA drives to be integrated on XP...
PC Laptops
when i want to send webcam to any one which is in my list...
HP Compaq Presario v3000z (RD153AV) PC...
hii... if that so, than what should i do as i`m gettin...
20 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jul 23, 2008
yes how to over came this problem when installing the driver ?
Comment by aqil_skripsi, posted on Jul 13, 2008
I haave the same problem
Comment by dkagrahari20, posted on Jul 12, 2008
there is a problem of installation of audio driver my laptop no is hp compaq presario c738tu . after installation it shows the massage that there is no media divice so itcan not install. plz help me for installation.
Comment by amit_kapila_, posted on Jul 10, 2008
hi even i m facing the same problem even my laptop is showing same mesage.
Comment by Guest, posted on Jul 05, 2008
kbkj
Comment by Guest, posted on Jun 26, 2008
same problem as urs
Comment by Pifec, posted on Jun 21, 2008
I have installed XP in Compaq Presario F700Laptop. I have configured audio as below. Install Microsoft UAA sp31994, then install High-definition audio driver sp33443. But I get the error message "Driver Installation Failed: Could not find the MEDIA device for this driver."
Comment by chrisgreener, posted on Jun 09, 2008
I have installed XP in Compaq Presario V3000 Laptop. I have configured audio as below. Install Microsoft UAA sp31994, then install High-definition audio driver sp33443. But I get the error message "Driver Installation Failed: Could not find the MEDIA device for this driver."
Comment by Guest, posted on Jun 05, 2008
Comment by Guest, posted on Jun 03, 2008
i have compaq presario v 3000.....though i have properly installed drivers i could not hear sound from my laptop...i have again installed my audio driver........it says media driver not found.....what am i supposed 2 do?
Comment by mastyo, posted on Apr 04, 2008
my laptop (presariov3000) can't install sound driver because the laptop can't find it
Comment by Guest, posted on Apr 01, 2008
hi, iam trying to install sound drivers in my notebook presario v3000 but it showing error like could not find the media device for this driver
plz help regard this send mail to my mail id sreekanth.murugula@gmail.com
Comment by akeim, posted on Mar 20, 2008
YES PLS ME
Comment by Guest, posted on Feb 27, 2008
yes
Comment by ajay arora, posted on Feb 22, 2008
sound driver for compaq presario v3000
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
