Question about ASUS A8N-SLI Deluxe Motherboard
PCI card not been detected via Windows.
I have got a Asus A8N SLI deluxe motherboard and the sound card stoppoed working with Windows refusing to find it, either by Device Manager etc... I have rebuilt the machine upgrading to Vista Prem and still no joy. I finally replace the sound card with a newer card same issue. I think the PCI is dead but my PCI express Graphics work fine.
Thanks for your help.
Darren
  • Anonymous Aug 29, 2008
    proplem
Sorry but the sound card is PCI Sound blaster Audigy 4 card. I know what the problem is now, its the south bridge on my motherboard is broken. But thanks anyway.
Posted on Feb 15, 2008
    Problem Solver:
  • 24 Answers
The sound card is installed into the ISA slot not the PCI slot.
clear the cmos for a minute, set it normal again.
install the sound card to the ISA slot carefully - i mean a working sound card and couple the system unit and boot, surely you will have your sound card working.
UZOWUANYA
e-mail:uzowuanya@yahoo.ca
P5N32 -SLI Deluxe. I use windows xp on virtualbox and have problem with sounds, I dont have sounds, Have to using chipset Nvidia? If yes which one?
hi
if you want to go for then only you can put any Nvidia Pci card
or
try to run motherboard drivers hope fully sound will come
May 30, 2010 | ASUS P5N32-SLI Deluxe Motherboard
Asus a8n sli premium
From the Asus support site.
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory.
Jan 06, 2009 | ASUS A8N-SLI Deluxe Motherboard
Sli problems
Get drivers from nvidia.com; If that doesn't work reinstall windows and do the same.
Jan 05, 2009 | ASUS A8N-SLI Deluxe Motherboard
ASUS EZ-PLUG not plugged in?
ASUS EZ_PLUG is optional for SLI mode...this model of your motherboard has an SLI that connect 2 video card using pci express...if this is only you problem for bugging the EZ_plug not connected,you can disable that in BIOS setup...
Oct 28, 2008 | ASUS A8N-SLI Deluxe Motherboard
Firewire problem
http://support.asus.com/download/download.aspx?SLanguage=en-us
this site has a list and downloads for your motherboard drivers could not see firewire that may be in packaged in one of the other drivers
Jul 31, 2008 | ASUS A8N-SLI Deluxe Motherboard
Asus A8N sli Premium - sli problems
I went through your bios manual three times & did not come across a setting that gives you the option as you listed above.
What I did come across & triple checked your Manual Pg. 2-28 section 14. Asus EZ selector card connector (144-pin SLI_CON.
When using two PCIE SLI cards make sure the card is seated correctly & set for Dual Video Cards. (extreamly important).
Pg. 4-34, section 4.4.9 SLI mode Recommend kepping to Auto. Than the Bios detects the setting of theSLI selector card.
Refering to the sentance above the manual recommends all settings be set to Auto. Your Bios will do the rest. If for unknown reason you no longer have your manual you can download it from Asus. You'll need to fill in the 3 windows under, Please Select the Product.
Motherboard
Socket939
A8N-SLI Premium
Any more question Drucos, please feel free to post back here!
& please vote...
Feb 22, 2008 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
Once installed Asus A8N SLi will not boot up in Vista 64 bit
Link: http://support.asus.com/download/download.aspx?SLanguage=en-us
Make sure that you have the lastest Firmware installed in your BIOS.
Also run Windows Vista Upgrade Wizard before installing Vista to check for compatability.
Note: Vote for me......
Jan 27, 2008 | ASUS A8N-SLI Motherboard
Describe your ASUS A8N-SLI Deluxe nVidia video card
Yes, you do. Your board was built with the idea to use 2 graphic boards to get great video
NVIDIA® SLI™technology revolutionizes PC performance by combining multiple PCI Express GPUs in a single and scalable system! Gamers and hardcore enthusiasts know that dual GPUs mean increased, supercharged 3D graphics and performance
Dec 09, 2007 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
System wouldn't Boot
If your CPU or memory were an issue your Asus board would sound off with BIOS beeps. Asus uses the Award BIOS & you can see what these beeps mean at the link below. Regaurding your PC not able to boot is an issue with your PCIE/PEG video card-in relationship with BIOS setting & the SLI switch card mode that came with your board. When running 1PEG video card you must set this in the BIOS to Auto & you need your SLI switch card connected in its slot. By default, the EZ Selector card is set for a single graphic card. When you install dual PCIE graphic cards on A8N-SLI series motherboards, please make sure EZ Selector card set to the Dual Video Card side and properly inserted. Link to Award Bios beep codes: http://www.bioscentral.com/beepcodes/awardbeep.htm
Will come in handy.
Reading the FAQ's at Asus site will help you better understand your A8N-SLI Deluxe. You'll need to fill in the, "Please Select the Product" first: http://support.asus.com/faq/faq.aspx?SLanguage=en-us
Dec 05, 2007 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Deluxe Motherboard Logo
174 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
