Question about Baby Gear
What car oil
HI can you please advise what oil I should put into my rover metro 1.1 1992
  • 50 Answers
Hi you need 15w40
Posted on Feb 13, 2008
Just bought rover metro 1.1 brakes not good do i
Take the car to quickfit, they will do a free brake check and,if required,fit front pads,rear shoes.Metro not good at breaking anyway,stops wheels from locking too quick....also as your car is fairly old change the discs as well.will make all the difference.
Jun 03, 2010 | 1993 Land Rover Defender
Rover metro.is a 1.4 16v and a 1.4 8v have the same wiring loom ??
It depends which loom you're talking about. ;)
Try visiting: www.mg-rover.org and add me as the referrer: hottubrepairer
Cheers,
Ian.
Apr 03, 2010 | 1993 Geo Metro
How to put a 2l 16v in rover metro
I doubt that you'll be able to squeeze a T-series engine into the engine bay, not only that, the extra weight would cause problems too.
You're better going for a K-series 1.8VVC engine. They're 145/160BHP, light and will fit with some modification to the subframe.
Try searching for the 'metro power' forum, or visit www.mg-rover.org
Cheers,
Ian.
Feb 15, 2010 | 2000 Mini Cooper
Hi! need to find a battery for my 1995 3.9 L
Delco I have had the best results with,Please be advise about batterys dont alway go with the most cca ratings like 1000 cca ,go with something like 700 cca,you battery will last longer and your recharge time is less
Sep 14, 2009 | 1995 Land Rover Range Rover
Need code for rover metro stereo
the only help can give you is you must go to the dealer to get the code.
May 07, 2009 | Car Audio & Video
Rover 45 - oil capacity and type
Hi, Go to http://www.mg-rover.org, covers all MG Rover models, they will know exactly and type, etc.
Mar 22, 2009 | 2006 Sterling 825
2000 Chevy Tracker 2.0 pouring oil
leaking from top or bottom? tr checking around the valve covers. if there is a build up you may need to change your valve cover gaskets. if you can let me know where the oil is collecting i may be able to advise a bit better.
Feb 27, 2009 | 2000 Chevrolet Tracker
Subject: 1974 Rover P6 3500 V8 Auto. After a few months lay up and after getting the car started, we noticed the oil pressure warning light was on and the pressure gauge was at zero. Is this a failure...
In most engines, the oil pressure warning lights works in conjunction with the pressure gauge both of which detects the oil pressure circulating inside the engine. The pressure is brought about buy an oil pump which drives the oil around. Therefore, the light going on and/or the gauge reading zero indicates that either:
1. there is very little or no oil inside the engine; or
2. the oil pump is not working.
Another possibility is that the oil is too thick for the pump to work on.
All of the above has to be corrected prior to turning your engine.
It would be very rare for both the oil pressure sensor (that activates the light) and the oil pressure gauge to be defective simultaneously.
To my understanding, most if not all Rover V8 engines have an external/mechanical oil pump that is mounted on the front cover, the base of which carries the oil pressure relief valve and oil filter. This page has information about Rover's oil pump.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 24, 2008 | Computers & Internet
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
