Question about HP LaserJet 4250dtn Printer
Hp 4250 paper jam erro
My hp 4250 laserjet keeps giving paper jam erro even after changing the fuser unit.
  • 2 more comments
  • Anonymous May 06, 2008
    13.1 error
  • Anonymous Jun 07, 2008
    I just bought an HP 4250 and the paper keeps jamming and I have not yet produced one printed page.  One of the small black wheels at the back was off the springs and I have fixed that but no improvement.  The paper keeps being stuck under the printer cartridge and is all crumpled up.  Any suggestion?
  • Anonymous Aug 04, 2008
    Jam the paper when feed up from the tray at all times. Check any paper or the wheel might be stuck but all seem okay.
    Turn off and unplug power from outlet-might reset itself did not work.
    Pull the paper tray out, make sure any paper are stuck together.
  • Sunil Roy
    Sunil Roy May 11, 2010
    Does it makes any sound like picking up paper from tray continues
  • 28 Answers
Check for the Try relay wich pick ups the paper if it is damaged it showes same error paper jam .
Or your paper jam sensor on the fuser side may not be proper check for that.
Posted on Feb 17, 2008
    Problem Solver:
  • 10 Answers
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Posted on Feb 13, 2008
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
Repair on Hp laserjet 4250. Printing but smearing black ink on paper
the fuser roller needs to be checked/ replaced. this is in the fuser unit which is availale in the maintenace kit from hp. all instructions in the manuals and on hp website
May 11, 2010 | Office Equipment & Supplies
Hp 4250 laserjet is noisy and has numerous jams. page count is 137,619 maint kit has 39% left when searching event # 13.05.00 Fuser output paper late jam
Probebly the swing gear assy, this assy is driving the fuser, is defective. This is a common problem with these machines. Replacing the gear assy should solve your problem.
Feb 16, 2010 | HP LaserJet 4250n Printer
WHERE'S THE FUSER ROLLER AND WHERE DO YOU PURCHASE FUSER OIL ON A HP LASER JET 4250 N PRINTER?
The 4250 uses an "assembly" that does not use fuser oil. The fuser is housed in the rear of the printer. It applies heat and pressure to the paper as it exits, melting the toner into the fibers of the paper. Some fusers are remanufactured. If done properly, with the proper amount of fuser sleeve grease, these fusers can last as long as the original equipment fuser.
If not properly trained, fusers should not be disassembled and rebuilt.
Oct 01, 2009 | HP LaserJet 4250n Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
HP LASERJET 4 PAPER JAM 13
Rollers do not turn on!
Rollers are driven by a motor.
How is the printer telling you this information? (does the PC give an error, or the printer flash lights)
Does the paper make it out of the machine?
Is this "Rollers in the Back" the Fuser Unit?
is The Fuser unit is going bad,
if you open the back top cover, where it gets real hot, where the paper exit's, you should see two rollers, one orange, one either brown or black.. if that orange roller is damaged, has crease's, or covered with black toner, if the paper jams here alott, you probably need a new fuser unit. there is a pm kit available which includes the fuser and rollers, transfer, etc, which this site might have
http://www.all-laser.com/cgi-bin/webc.cgi/Menu_HP_maint.html
Oct 23, 2008 | HP LaserJet 4 plus Printer
HP 4250 down (paper jam without paper)
hi,
the fuser of that unit is in the back, you can saw it by sliding out the back cover. you can pull it by unlocking the 2 lock on side of it..
try to locate the sensor of the fuser assembly.and also try to see if they pick up very well both tray 1 and tray 2..
hope it would help you..
Aug 05, 2008 | HP 4250 Monochrome LaserJet Printer
HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Jan 09, 2008 | HP 4250 Monochrome LaserJet Printer
Hp 4250 GHOSTING
Are you telling the machine that paper type is letter head or envelopes, It must be done, it changes temp of fuser to suit the paper type, no it is not a power supply problem change paper type to card stock/thick/letterhead etc to suit then machine will adjust temp to suit.. ie file, print properties paper type.
50.2 fuser error replace fuser.
Dec 06, 2007 | HP LaserJet 4250n Printer
HP LaserJet 4250dtn Printer Logo
1,689 people viewed this question
Ben Johnson
