Question about Nintendo DS Lite Console
Animal cossing cant save the game from outside or in the attic as the game says to do...
  • zie zie Feb 12, 2008
    have shut off the game several times and have tried removing it and starting again yet it still wont save
  • zie zie Feb 13, 2008
    have done many of tom nokks task,and have put work uniform on and have spoken to him heaps yet i still cant save the game.... could the game be faulty ,we got it second hand
You should try doing more of Tom Nokk's tasks. Until you get the work Uniform and put it on and talk to him I don't think you can save.
Posted on Feb 13, 2008
  • 54 Answers
Shut off the game, then try again.
Posted on Feb 12, 2008
WGI Blade Infrared Game Camera, 8.0 MP Model: T8i20CA2 Can this camera capture picture of animal as small as a mouse and be used in the attic
Yes, but does depend on how you set it up; motion sensing and intervals. If all else fails, set it to time lapse, 1 second intervals, and you will find your critter. Also, consider an infra red light to brighten the area in which the camera is recording. Finally, I suspect bats. Hard to find and noisy at night. Worse in the winter. Sorry about that. Let the bats be - not harmful and are a declining species which eats an enormous number of insects.
Apr 27, 2017 | Pest Control Home
What is donald trumps email address, phone contact, and how do i contact him?
twitter is what dear donald uses
the address is on all his tweets
Feb 21, 2017 | The Video Game Consoles & Games
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
I can't save progress in Animal crossing! >< plz
Sorry, that's not true. You can save anywhere in the game by hitting the start button, whether or not you're in your house. To me, it sounds like your game file is corrupted. Your only option at this point is to start over again. If it doesn't work after that, you should buy a new game.
Aug 03, 2009 | Nintendo Animal Crossing for DS
Where is your attic in animal crossing
All yo have to do is go upstairs. There is no true "attic" just the "save room."
Jun 30, 2009 | Nintendo Animal Crossing for DS
Dsi cant exits ds lites town without blue screen
Try updating your software in your dsi? Keep in mind that AC was intended for ds not dsi so there is some bugs. Just like how AR(action ready codes) wont work for dsi, it just wasn't made for dsi.
solution? buy a ds? gamestop sell used ds for 70ish dollars or so.
May 20, 2009 | Nintendo Animal Crossing for DS
Animal Crossing WW for DS.Can't save game
I can't understand this. Nothing like this has ever happened to me and I have had Animals Crossing - Wild World for a while.
I think maybe you should try to take the game back and get another cartrige.
I can't give much help, but I have tried..
Thanks(:
Mar 28, 2009 | Nintendo Animal Crossing for DS
Shutters closing while running
The shutters should be gravity closed, which means they are counter weighted just enough to close with no air flow...  when the fan starts, it will create a slight pressure differential across the shutters - when that pressure overcomes the counter weight, the shutters should open...  I assume you open windows and/or doors when the fan runs...
I would check for the following items: a) (unlikely) check to see if the counter weight is adjustable, if so, it may be slipping and needs reset.. I think this is unlikely as I think most shutters do not have adjustable counter weights -- check last)
b) check your attic vents to the outside -- the air being blown into the attic must escape to the outside world, otherwise it will build up pressure and the airflow will drop or stop altogether -- this sounds like what is occurring, at slow speeds, there is insufficient airflow to open the dampers, at high speeds, they open long enough for the pressure to build up and then they close as the air flow diminishes
c)  have you replaced windows, caulked up windows, made any modifications to reduce the flow of air into the living areas -- air must enter the house just as air must leave the attic (assumes you don't open windows or doors)
d)  if you have a fireplace, check to make sure some animal or other hasn't plugged up the chimney -- if the house is tight, the attic fan will pull air from the chimney unless it is blocked
hope this helps...
Jul 25, 2008 | Ventamatic Direct Drive Whole House Fan...
Cant save the game
All I can say is press start or go up to the top floor and go to your bed and save. I can only help you up to here.
Feb 19, 2008 | Nintendo DS Lite Console
Animal Crossing will not save.
I have repaired many of these units for people and from what I am hearing it actually sounds like a game problem. Have you tried other games in it just to see if they will save if they will I would swap out the game.
Oct 16, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
