Question about Mercury P4VM800M7 Motherboard
Usb ports are messed up
All the usb ports (including the front ones) dont work any more.when you insert a flash drive,a message saying the device has not been recognised or it has malfunctioned appears.i have tried reinstalling the usb drivers to no avail.when i reinstall windows they can work for an hour or so before they go back to their old self.
    Problem Solver:
  • 10 Answers
U put the front pannel usb cable wrong see again u find the mistake
Posted on Feb 12, 2008
Whenever i insert my external hard drive to the USB port of my desktop, the desktop flashes a message saying USB not recognize. And the hard drive does not work. i do not know to make it work..
The most common cause of this in my experience is not enough amperage available at the USB port. If you're using a front/top case port, try switching to one of the ones at the back of the case that is connected directly to the motherboard. If that doesn't work, you can use an externally powered USB hub, which usually solves the problem as long as the hub has a 2A or better power supply.
Hope this helps.
Sep 25, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
My 16GB usb flash drive is not working. it is shown on safety removal & device manage, but when i try to open it the please insert disc message appeard
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 10, 2011 | A-Data Technology Adata USB C802 8GB BLK...
When i plug in the u3 flash drive it says usb device not recognized
Hi ,dkjran,
If your computer affected by virus will not show in the pc .so you will install it to another pc,and format it .Flash drive can not recocknize,becayse there are some reason .
  • VIrus affected
  • Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it may be possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted then it will indicate that it is Healthy.
If this doesn't work then it is faulty.
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
hope it will help you
Dec 12, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
Sep 07, 2009 | Electronics - Others
This has happened once before and I think Windows XP fixed itself after some time, but I don't know how. While transferring files onto a 4gig flash drive, I got an error message that one file could not be...
I have seen USB ports fried like this, by USB devices. It can render them usesless.
What you can try, is go to the Device Manager, and uninstall the USB ports there. Then go up to Scan for hardware changes. That should automatically reinstall the drivers, in case they got hosed.
If that still does not work, they may be dead. I have seen it where even a device light works, which means there is power on the USB port, but the communications part does not work.
In a desktop PC, you can get an add in PCI card, and route the ports to the front, that is a possible fix for you.
Apr 11, 2009 | Computers & Internet
How do I get started using a USB flash drive and how do I set up a security system?
hey, heres something that would help u:  Copying files to a flash drive on a PC:
  1. Open My Computer and see which drives are shown. Most computers, for example, have a hard disk such as a C: drive and a few removable storage devices such as a floppy drive, a CD-ROM drive, and perhaps a zip drive.
  2. Insert the flash drive into the USB port and watch to see where the USB flash drive appears. Most will appear as removable storage, but some will instead appear as hard drives. Note the name Windows is using to refer to the flash drive ("Removable Disk (G:)," for example).
  3. Open My Documents or the location from which you want to transfer files to the flash drive. Select the files or folders you want to save to the flash drive by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files you wish to save.
  4. Right-click on the file(s) or folder(s) you selected, then select Send to, then select the name you saw appearing in My Computer for the flash drive ("Removable Disk (G:)," for example).
  5. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  6. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
Copying files from a flash drive on a PC:
  3. Double-click on the flash drive to locate the file(s) or folder(s) you want to copy to this computer. Select the files or folders you want to copy by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files or folders you wish to copy.
  4. Right-click on the files or folders you have selected and choose Copy.
  5. Open My Documents or the location to which you want to transfer files from the flash drive.
  6. Click on the Edit menu, then select Paste.
  7. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  8. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
    ok_msg.gif                                      =========================================================
For the security system setup go through the following link .. http://www.rohos.com/configuring_usb_stick_logon.htm
if u require some other sort of security system let me know.
cheers
Oct 13, 2008 | Computers & Internet
Mercury P4VM800M7 Motherboard Logo
67 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
