Humming or squealing noise when tv is turned on (model 32LG30)
Humming or squealing noise when tv is turned on regardless of video input, speakers muted or not. Sometimes goes away in 15 seconds....sometimes it doesn't.
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
This hum could be from a ground loop or a bad main board in your TV.
1. Try removing all the inputs from the back of the TV.
2. Unplug the TV for about 3 minutes and plug it back in.
3. Turn on the TV and go to HDMI1 input.
4. Turn the volume up to see if you hear the hum.
5. If you hear the hum without any inputs into the TV, then the problem is with your main board, or with the quality of power you have going to your TV (your wall outlet may have an open or bad ground).You can try plugging the TV into a different outlet across the other side of the house (to try a different circuit) to see if your power is the problem.
6. If you don’t hear a hum without any inputs into the TV, then the audio hum is caused from one or more of your inputs.
7. You will have to plug in one input at a time into the TV, and turn up the volume to see if that one input is creating the hum.If the TV hums, then you have a problem with that device and or the cable that connects it to the TV.
8. There is a chance the hum will occur when two or more devices are connected to the TV at the same time.So be careful of this issue. This issue is not the fault of the TV and is a grounding issue between the devices.
I hope this information has helped you.
Good Luck.
check the type of cable you are using. low end cable lets in a lot of static and distortion, if I were you I would look into some higher end cable. I find 9 times out of 10 with situations like yours the cabling usually is the culprit.
1. Turn tv on 2. Input mode should be tv 3. Turn volume to zero 4. With remote enter 9 8 7 6 5. A menu will appear on left side 6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice, 7. Turn up volume and listen if hum is gone.
Usually Humming noises come from frequency interferance. In this case it is being caused by your input sources. A smiply solution is to replace the cables and or seperate the source cables away from any electircal cords or sources.
probably your wires. any time speakers hum something is not connected properly or there is interference from another gadget nearby. Invest in some better wires and your problem should go away
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
