Samsung DVD R/RW
My drive does not get open buy pressing the eject button many time i make to open it by inserting a pin in its hole every time ,what i have to do to repair it at home
  • Ashuinfy Feb 12, 2008
    Problem Solver:
  • 19 Answers
It's not the motor in most of these problems, it's the drive belt between the motor pulley and the tray mechanism pulley. They are tiny, and get worn easily. Replacing this with a better quality belt, or a small "O-ring" usually solves the problem.
Posted on Sep 21, 2009
Or right click on your cd/dvd icon and select eject.
see if this works.
Posted on Dec 27, 2008
  • 796 Answers
Actually the problem u got is a faulty motor driving the cd tray......
this happens to every single cd/dvd drive unless it is not properly handled by us....one solution is to replace the motor in it....no idea how much it will cost...
and nowadays the cost of cd/dvd writer cost has reduced a lot...better wait for few days and upgrade it to a blueray thing....
thanks
Posted on Feb 12, 2008
Acer aspire dvd wont open with eject button
Whether you use your DVD drive to install software, make backups of your personal files or watch movies, having that drive onboard makes your computer more useful and more versatile.
While DVD drives function normally most of the time, sometimes a DVD will become stuck in the drive, and the tray will refuse to open.
Knowing what steps to take to resolve the situation allows you to start enjoying the advantages of the DVD drive again.
Log on to your computer and click the "Start" button. Choose "Shut down" from the menu and then choose "Restart." Wait for the computer to restart, then press the eject button repeatedly.
Remove the DVD if the drive pops out.
Since there is no hole skip this and go to cleaning the lens.
Shine a flashlight on the DVD tray and locate the small hole near the eject button.
This is the bypass hole and it allows you to eject a DVD when it becomes stuck.
Insert an unbent paper clip into the hole and push it in until you hear the DVD begin to spin. Push the paper clip in until the drive pops out.
Remove the DVD and insert another one.
Use the bypass hole again if the new DVD becomes stuck.
If the new DVD sticks as well, you need to clean the laser lens on the DVD drive.
Insert a laser lens cleaning DVD and close the tray.
Run the laser lens cleaning program at least three or four times to make sure the lens receives a thorough cleaning.
Restart your computer and insert a DVD to test the unit.
Oct 19, 2012 | Lifetime Acer Aspire 4810TZ-4011...
When I Press Eject button the tray does not open. It is also taking too much time during booting.
Use a pin and insert in the emergency eject hole (usually in the center below the tray) and then you can eject the drive tray with force. It is time you planned for a new drive.
Untill then please insert a music CD into the drive tray and leave it there, this will ensure the eject will work (most of the time). Booting time will definitely increase if the drive has issues, reading or responding.
Feb 03, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
I cannot eject my dvd it doesnt play also
Look at the drive there should be a tiny pin hole near the eject button, insert a needle (saftey pin, sewing, etc.) into the pin hole and push this opens the drive.
You can also try opening my computer and right clicking the dvd drive and select eject.
Jan 05, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
Non-opening dvd/rw
Well, it may have got jammed. so try this trick.....
If you look at the dvd/rw drive..on the side of the button of the drive...you will find a very tiny hole so take a paper pin and insert it in the tiny hole if the drive is opened great!!! otherwise get it replaced as the dvd/rw drives are not costly thesedays..
Sep 08, 2009 | Pioneer DVR-107D DVD±RW Burner
Dvd rw drive does notrespond to eject command
this is common there is a small pin hole front left corner bend a paper clip straight and insert in the hole the door will open about 1 inch long to go in
Aug 22, 2009 | eMachines ET1161-01 PC Desktop
HP dvd 940 i lightscribe---tray sticks
underneath the tray there should be this little hole. if you see that hole insert a pin in it, and the press the eject button and push in the pin at the same time. that should make it work
Apr 04, 2009 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
What can i do to open the door on my ez-dub
HI Buddy If your cd drive not opening no prob haah,, i have solution to open this, near by your cd room button there would be whole tiny whole ok, you have to do that when u pressed the button same time your have to entered the pin in to whole then your cd drive will come out easily.
if u will suceed then reply me plz ok best of luck.
Feb 28, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Failure opening the tray
do 1 thing,take a pin and insert it in the small hole below the tray
and then press the eject button
Jun 04, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
DVD won't eject cd
Seems to be a hardware failure, last thing to try before throwing it out, is right click on my computer>properties>Hardware Tab>Device manager Tab. Next click the '+' sign on DVD/CDROM Drives, highlight your DVD RW and right click then uninstal. Re-boot your pc and let windows find and re install your drive. This should sort it; if not it's down to using a pin in the tiny hole at front of drive to eject manually. Your Ratings are important
Nov 13, 2006 | Samsung (TSH552) DVD±RW Dual Layer...
Computers & Internet Logo
286 people viewed this question
Alun Cox
David Payne
David Payne
