Question about O2 Xda Atom Exec Smartphone
Cannot detect wifi
My phone cannot detect my home access point on Belkin N Wireless Router. The router was set using WPA-Personal TKIP Security key; 6 Wireless Channels; Bandwith 20 Mhz; Broadcast SSID; Protected Mode off; 802.11e/WMM QoS On; and Wireless Mode 802.11b,g&n. It was detected on laptops and my Nokia N95. Please advise. Thanks in advance.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 146 Answers
Login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
I want to know how i can make my Linksys Router WRT160N work as access point
By default Linksys router behaves as Access point. On some router you have to enable the wireless function.
So the following to configure the router Wireless Access Point
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts. You can connect as many devices as you wish since it is a access point
Thanks
Vote me If it helps
Apr 26, 2011 | Linksys WRT160N Wireless Router
What's the difference between WEP and WPA? What should I pick?
WEP is a weak securtiy protocol that is outdated and can be easily broken
WPA is a newer security protocol that is much harder to break with AES encryption
WPA is always recommended mode for operation over WEP.
Use WPA2 which is latest version if it is supported by device.
Mar 12, 2011 | Belkin N1 Wireless-N Wireless Router
How to secure my internet connection via smc router
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
IF THIS ALL DOSEN'T WORK TRY THE FOLLOWING:
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Aug 03, 2010 | SMC Barricade 7004VWBR Wireless Router
Setting up security WPA
Hi Friend,
In order to resolve the issue please follow the steps:
1.Connect the router to the computer and turn it on.
2.Type 192.168.1.1 in the address bar of the Internet explorer and hot enter.
3.Enter the Username and Password (default password is admin and leave blank the username section)
4.Click Wireless tab and fill the sections as mentioned:
Wireless Network Mode-Mixed
Wireless Network name-As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID-Enable and click Save settings
5.Now click Wireless Security tab.
6.Select the Security Mode as WPA Personal
7.WPA Algorithm-TKIP
8.WPA shared key- Enter a key/password of 8 to63 digit length
9.Group Key Renewal-3600 and click Save settings
Turn off the router for 30 seconds and turn it on after that.
Now your network is secured with WPA Personal key.
I hope this will resolve the issue.
Regards
Chiranjeet
Jun 01, 2010 | Linksys Wireless-G WRT54G Router
I DON T KNOW HOW TO CHANGE THE SETTINGS ON MY ROUTER SO THAT IT CAN CONNECT WITH MY WII. THE ROUTER AND THE WII ARE COMPATIBLE BUT IT SAYS TO CHANGE THE ROUTER FROM 6 TO EITHER 1 OR 11 BUT HOW DO U DO...
Go to your router's Web Utility, if possible through a computer connected to the router by cable (because you'll loose access to the router once you change its encryption rules). If you haven't changed the access parameters, the default IP address is 192.168.1.1, with 'User Name' left blank, and 'Password' set to 'admin'. In the 'Wireless' tab. I supponse you already have encryption definitions there. Try to set your 'Security Mode' to 'WPA Personal' and 'Algorithm' to 'TKIP'. Chose any 'WPA Shared Key' you want (from 8 to 63 characteers), and set the 'Group Key Renewal' parameter to 0 (zero, i.e. no key renewal, at all). Save your settings.
You see, my router is not Linksys, but in essence, the encryption parameters are quite alike, and this is how I managed to provide internet to my son's Wii console.
Hope it works for you.
Regards, Carlos
May 27, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
My g wireless Belkin USB Network adapter doesn't seem to be funcionig. I cannot access Internet Explorer. I have HP PC with Windows XP. I',m using Sprint WiFi.
Is your router connected to your Broadband modem (cable or DSL) into its broadband port? The router must be first connected wired to set it up for wireless access. Use your browser to access http://192.168.1.1 and log in with login info from the manual. Once you get in, set the Network Name (SSID) then the wireless security. I prefer WPA-PSK[TKIP] for its simplicity. You will need the passcode you set here to log in with your wireless computers.
Nov 11, 2009 | Belkin (F6D3230-4) Router (F6D32304)
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
How to make a secure connection.So far i have an open connection. My router is Belkin_G_Plus Mimo
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
8. Changing the Wireless Security Settings
Your Router is equipped with the latest security standard called Wi-Fi Protected Access 2 (WPA2). It also supports the legacy security standard called Wired Equivalent Privacy (WEP). By default, wireless security is disabled. To enable security, you will need to determine which standard you want to use.
To access the security settings, click Security.
The Router features WPA2, which is the second generation of the WPA-based 802.11i standard. It offers a higher level of wireless security by combining advanced network authentication and stronger Advanced Encryption Standard (AES) encryption methods.
2. You can configure wireless security/encrytion settings here. Select WPA-PSK (no server) from Security Mode drop-down menu. The new page will display on next screen
3.Setting WPA Security
Note: To use WPA security, your wireless network cards must be equipped with software that supports WPA. At the time this User Manual was published, a security patch from Microsoft is available for free download. This patch works only with Windows XP.
Your Router supports WPA-PSK (no server). WPA-PSK uses what is known as a pre-shared key as the security key. A pre-shared key is basically a password that is between eight and 39 characters long. It can be a combination of letters, numbers, or characters. Each client uses the same key to access the network. Typically this is the mode that will be used in a home environment.
Setting WPA-PSK
1. From the Security Mode drop-down menu, select WPA-PSK (no server).
2. For Encryption Technique, select TKIP or AES. This setting will have to be identical on the clients that you set up.
3. Enter your pre-shared key. This can be from eight to 39 characters and can be letters, numbers, or symbols. This same key must be used on all of the clients that you set up.
Jun 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Security connectivity issues
is the PC connection you're able to maintain once upgraded to WPA a PC that is physically connected to the router? if so, that would make sense because WPA (and WEP for that matter) are only wireless security protocols and have no protections for hard-wired connections.
In order to convert your system to WPA security, you must first make sure all of your hardware is WPA compatible (that isWPA Drivers are available for it).
For your PC wireless connection, if you're running Windows XP you can go to the microsoft website and download the WPA client. It is available in the Microsoft Knowledge Base Article 815485. install the update and reboot. you will then be able to enable WPA security on your client.
Then you'll possibly need to update the drivers for your hardware for WPA support (router, wireless NIC, etc) if they did not already come enabled.
next you get to configure the router for WPA. you'll want to make sure you're set to WPA with preshared keys (no authentication server required), use TKIP as the algorhythm, and leave group key renewal at it's default value. and of course Select a key that is not likely to be guessed. write the key down as you'll need to configure your NIC using it.
to configure your NIC, once you're in the configuration menu select WPA-PSK for your authentication, TKIP for the encryption mode, in data encryption set it to TKIP, and in the network key put the key you selected earlier.
At this point you should be able to access your wireless router (or other access point). These instructions were kind of generic since i do not have the specific router you're using available to me, but the settings i discussed should be pretty universal when it comes to WPA security.
Jul 01, 2008 | D-Link DI 514 Wireless Router (DI-514)
Cannot Detect Home Wifi Access Point
What he means is:
Go to the start menu in your PC/Laptop and click Run.
Type regedit in the box and press enter.
When the regeditor pops up, in the left pane click
HKEY_LOCAL_MACHINE
then open these by using the + boxes
Comm, then TNETWLN1, then Parms
If they are all there, in the right hand pane you should see the other bits:
HTCPreloaded status" =dword:0000001
'HTCPreloaded wifi" =dword:0000001
If they are there you need to change them to look like the ones he posted. To change them you right click on them and click Modify. When you have changed them to match, click OK and exit regedit.
Jan 27, 2008 | O2 Xda Atom Exec Smartphone
O2 Xda Atom Exec Smartphone Logo
239 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
