Question about Acer TravelMate 2300 Notebook
Connecting laptop with projector
Hello experts, my work has an epson EMP-821 projector which everyones' laptop can connect to apart from mine. our IT guy had a go last week and was pressing 'fn' and the ' F' keys as well as adjusting the screen settings, allto no avail. i work in china and the IT guy has no english so i'm not sure exactly what he was doing. i have an acer travelmate 3300. the configuration lable says travelmate 3302WXCi. i'd love to know if there's any chance i can link the two or should i just give up? cheers, tom
  • 4 more comments
  • lgbob Mar 09, 2008
    Am having the very same problem without any success.
  • Anonymous Mar 17, 2008
    Hey Guys, I have an Acer Travelmate C300, yes, not the latest gear.
    Problem is that I visit different clients, who each have their own different projectors!
    I sometimes can't get their projectors to recognise my laptop.
    Can you please give me step by step instructions to achieve success?
    My original user manuals give no guidance on this matter.
    Desparate,
    Bruce
  • post1139 Apr 10, 2008
    I'm connected to an optoma projector. My wallpaper shows up on the projector screen. When I select "identify" from the Display settings, a "1" shows up on the laptop screen and a "2" on the Projector screen, but I can't get the video to show on the projector screen unless I manually drag it to the screen. Can't seem to make any difference with various settings. Any ideas.
  • andrewpillan Apr 28, 2008
    i cant get a picture after the start up screen when using a projector
    i have a acer travelmate 2300 wheni restart my start up screen shows on projector but after windows is .loaded nohing
  • Anonymous Jun 10, 2008
    • i have acer laptop model 4315 connot display to epson projector model EMP-S5 it display when I configure cemos...after booting no display..
  • taherjr May 03, 2009
    acer aspire 5000 does not recognise projector, vista os.
    Champion:
  • 238 Answers
.hi, if the projector connector is a "D" type same like your monitor, then u will have to adjust the display card properties and select a compatible monitor, or select TV if ur laptop has a Video out.also try out pal/ntsc selections. if it does not work , let meknow all the avilable connectors on the laptop.we'll figure it out, dont worry
Posted on Feb 14, 2008
You could try using the S-video connection.
Posted on Feb 13, 2008
Below your screen, there is an icon on graphic display, click on it and select which mode of output you wish, i.e., monitor and display out, or display only, etc.
Posted on Feb 26, 2008
What do I use to connect Macbook pro to an Epson EMP projector?
you need a cable:
type depends on your macbook pro model and epson:
use-connect-macbook-pro-epson-emp-rd53xsmc3ry4fozipcd12amw-5-2.jpg use-connect-macbook-pro-epson-emp-rd53xsmc3ry4fozipcd12amw-5-5.jpg use-connect-macbook-pro-epson-emp-rd53xsmc3ry4fozipcd12amw-5-9.jpg
Nov 29, 2012 | Epson EMP-S1H Projector
I have a DELL XPS 15 Laptop. I tried to connect the laptop to different lcd Projectors using HDMI to VGA connector. The laptop could not be connected with any of the lcd projectors and no projection on the...
Hi
Sure can be fixed.
1st of all you need to connect the projector with your laptop turned off. One the laptop has finished booting and loading windows. Hit the Fn+f4 or f7 key to switch between the displays then you will get the display.
But if this also does not give display then you can check with the projector with Video INPUTS (Eg. Input 1 / Input 2 etc.,)
Jul 21, 2011 | Epson EMP-S5 Projector
No signal on epson emp-x3 projector using susb cable
I'm assuming (because of the USB) that you wish to connect a computer to the projector.
You will need a VGA cable connected to the Computer input on the projector and the VGA output on your laptop.
If it is a laptop you may have to active the external monitor on your laptop. This is generally done by pressing the function key and F5. But this will depend on your Laptop and OS on the laptop. Look for a button amongst the F keys (at the top of the keyboard) that will do this on your laptop.
Mar 21, 2011 | Epson EMP-X3 LCD Projector
My Epson EMP-1815 Projector displays replace lamp. Should I replace only the lamp, or the lamp along with the housing module advised by my supplier, which is quite expensive. Does it require an expert in...
If you understand the requirement of specialist lighting and how to handle the lamp, the cheaper option will be fine.
Make certain you rebuild the light box exactly as you took it apart.
Use a camera to take photos.
Jan 04, 2011 | Epson EMP-54 Multimedia Projector
MISSING CABLE
you can buy any vga cable at any electronics shop in your area. usually epsons pin configuration is just standard so any vga cable will do. also try to look for it in any computer surplus store (if theres any). LCD TV nowadays has a bundled vga cable that will work with your projector too.
Jan 31, 2009 | Epson (ELPLP25H) Projector Lamp for...
Yellow green screen
If you are connecting it to a computer with a VGA cable, you may have to go into the options of the projector and set the port correctly.
Go into the menu, and select the "image" area. In here you should be able to select computer.
Aug 19, 2008 | Epson EMP-S3 Multimedia Projector
Screen image is distorted small using Epson EMP 821 with Latitude D620
Check Epson"s support site to see if there is a driver for the projector. Some projectors require a driver for the visual clarity, and lots of times the driver disc doesn't come with the projector, go figure, and don't ask me why.
Aug 04, 2008 | Dell Latitude D620 Notebook
Emp-s1
Pls change the display settings of your laptop to 800x600 or 1024x724 then check. The projector SVGA.
Pls tell if you are not able to solve the problem.
Viren
Apr 12, 2008 | Epson EMP S1 Multimedia Projector
Computers & Internet Logo
1,877 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
