Machine loosing water
Hi, I have the above washing machine. I've had it about 3 years, and never had problems. last night I put a load in and when I got up this morning the floor was full of water. the machine was showing error message "E1". I've checked and cannot see any blockages. I then put another load on and it seems to me that when it is filling with water, the water is also going out via the drain pipe. I cannot find the book or my receipt and I took out an extended 5 year warrenty on the thing, but I don't know where I've put the paperwork.
  • joyjones Feb 15, 2008
    Thanks - we found the leak! It was on the inlet pipe! Silly me!
    Problem Solver:
  • 10 Answers
The pipe inside the washer where the water goes from the tub to the pump might be loose
Posted on Feb 12, 2008
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
I have a Bosch SHU3036UC dishwasher. While sitting idle - during the day or over night, it fills up with fresh water. I shut off the water supply last night and this morning it was dry. Any ideas?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 12, 2011 | Bosch SHU3036UC Dishwasher
Hello my name is Kevin Singh and i had purchased one of your Bosch Front loading washing machines (model number: wfk2401) probably about 10 years ago i used it last on this last Sunday and it seems to not...
Have you checked the pump and filter are clear? Remove kickplate plinth panel to expose pump. Drain off excess water via small black hose. Check the hoses are clear, particularly if it is connected under the sink, via a spigot connection. If the machine has good motor action, but not spinning effectively, it will more than likely be a drainage problem.
Oct 19, 2010 | Bosch Washing Machines
Water won't come out of the machine. It worked the night before last...I did not change any settings or touch anything. What can I check?
heatman101
Sep 18, 2010 | Roper RAX7244KQ Top Load Washer
LG WM2355C water leaking under machine after washing finished.
HI, you will want to Inspect the water supply connections. this is a good spot to check first. there may be a loose connection here, causing the leakage. Next, Inspect the drain hose. Check to make sure that it is tightly connected to the drain pump. replace if needed. Last. Inspect outer tub/basket for cracks or corrosion.
You will find the issue in one or all of the above stated check points.
Jul 23, 2009 | LG WM2277H Front Load Washer
Wont spin at all.
It could be that the motor needs new brushes (fairly cheap on ebay - and easy to do), or the motor run capacitor is faulty (lots of buzzing going on - but not much effort from motor), or it may be the motor or speed controller at fault.
Check the cheap bits first. ;-)
Nov 05, 2008 | AEG Lavamat W1450 Front Load Washer
Broken Machnine
hi. thanks for the question. the problem is .there is something caught in the water pump, and a burnt out belt ,replace both parts thanks the appliance doc
Oct 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Tabs
Hi Zanussi do not recommend tablets for this machine as it is a jet system and uses far less water than conventional machines. it recommends liquids or loose powder to be used in the tray I know as I sold these for 10 years.
May 04, 2008 | Zanussi ZWF1440 Front Load Washer
Whirlpool LSR7233000 Washing Machine
HI thanks for your question. i would look at the lid switch, you said you had an off balance load. that could have broken the lid switch. replace it thanks
Oct 26, 2007 | Whirlpool LSQ9610L Top Load Washer
Machine will not empty or rinse
Put off the machine. After 3 or 4 minutes put the control to "spin only" & put the machine on. If this does not work you hv a drain problem which shd be checked......
Aug 27, 2006 | Zanussi F1045W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
