Question about Canon L120 Fax Laser Printer
LOUD SOUND WHEN SENDING FAX
Hi, I have a new Canon FAX-L120 that is working fine but one thing that disturbs is his loud sound when sending fax and "a toouut - toout" telephone line sound when the line is busy and fax cannot be sent, that we would like to turn off or down as much as possible, please can you email me the answer if not a problem, thank you very much, regards, Tea.
teakruzic@gmail.com
  • Anonymous Apr 16, 2008
    Exactly the same problem - would like to mute all sounds.
  • 398 Answers
There are 4 volume controls to access them press MENU.
You should see “MACHINE SETTING?” if not use the SET arrows to scroll through the different menus, stop when you see “MACHINE SETTING?” Now press the SET button.
Now use the up & down arrows to get to
Buzzer Volume = that the machine beeps
SET
Key volume = the tone that sounds when you press keys on the control pad
SET
Alarm volume = the alarm if something happens.
SET
Line volume = sets the level you hear at the fax is actively transferring a fax.
If you want to change any of the settings, press the up or down arrows to the level you like best and press SET if you don’t what to change that item just press SET. When you have adjusted all levels the way you want them press STOP and the levels will be remembered.
The most annoying sound to most people in the Line Volume. I have known people that like it as quiet as posable in thier work, but the problem is if you turn down the ALARM you won’t know when there is a problem. Many people like a little line volume so that they hear when they dial into a busy phone line, or if someone picks up the shared voice line.
Posted on May 30, 2008
What happen my canon fax L100 not sending and resiving
I would look to make sure that the phone line is installed in the LINE port and not the handset....
Jan 11, 2014 | Canon L120 Fax Laser Printer
When trying to send a fax from a Canon L16-L140 the error message: "Document ready, checking scan error, please press OK" appears. When pressing OK nothing happens. I can receive faxes fine though Please...
Hey! If the take out the cover that's covering the receiving paper,Look in there and u will see a black lever with a green sticker on it!Make sure its clipped into place by pushing it upwards un till you hear the click sound!Then press ok!!Enjoy! Good Luck!
Sep 27, 2010 | Canon L120 Fax Laser Printer
Memory Full Canon i-sensys Fax L120
try this
press "menu" and then "#" button, go to service mode. Select the "clear data function". and select "memory clear"
Sep 03, 2009 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
How to I delete my fax machine memory? It says Memory Full and I am not able to send a fax. Please help me. Thank You My fax machine model is Canon FAX L120
Hi
Go to Control Panel>Double click of Printer & faxes >It will open up a window you need to delete all tasks from that. If it still doesnt help contact Canon people for further assistance :
http://www.usa.canon.com/consumer/controller?act=ContactCanonAct
Thanks
Rylee
Jan 08, 2009 | Canon L120 Fax Laser Printer
Put in number press the green button to send the fax and it comes up with Memory Set Doc flashing but wont send the fax.
try sending manually
to do so
load a document---->press hook----->dial the number----->when you hear a fax tone press start.
Aug 05, 2008 | Canon L120 Fax Laser Printer
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Jun 25, 2007 | Canon L120 Fax Laser Printer
Canon L120 Fax machine
You have to make sure that the document release lever is fully down.
Jun 01, 2007 | Canon L120 Fax Laser Printer
Canon Fax L120/L100
press menu and then # goto service mode. Select the clear data function.
Clear all the memory, dRAM and counter.I hope it will work for you.
May 10, 2007 | Canon L120 Fax Laser Printer
Canon L120 Fax Laser Printer Logo
265 people viewed this question
old marine
old marine
