Question about Oracle 10g Database Standard (ODBSEONUPP0)
Installation of coreldraw 11
Hi this is lewies here i have a problem in installing a Coreldraw 11 on my pc.
every time i have to press retry to complete 100%b but then it doesn't complete
Pls Advise
    Novelist:
    Champion:
  • 202 Answers
1. Seems like some semi-critical installation files are missing / corrupted in ur installation package / CD / DVD, Consider approaching the supplier for a new pack CD/DVD, or if u r talking about some trial packs from net, try redownloading them :)
2. Audio and sound devices will not exist, if the drivers are not installed properly...Please do install them...Try posting the question with appropriate details :) so that people can get u the drivers too...
I hope, my suggestions were helpful to u!
bye
Have a nice day
Posted on Feb 19, 2008
I have problems of my PC that is audio and sound device is missing. How can I loaddown in free of cost so that I can listen BBC and music too. Thanks
Yours
Bhagwan
Posted on Feb 13, 2008
Corel DRAW X6 problems
I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
If nothing seems to work I would then do as follows.
1.Uninstall CorelDRAW X6 via Control Panel
2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
8.You SHOULD now be able to run your CorelDRAW X6.
9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
Good luck and hope this helps!
Nov 12, 2014 | Corel DRAW Graphics Suite X5
After i uninstalled coreldraw 12 and installed coreldraw X5 trail, everything when wrong so i uninstalled coreldraw X5 but now i can't reinstall coreldraw any version and to other applications like...
Hi ebiau
Probably , if you have deleted coreldraw 12 via Control Panel , some files remained in the registry , corrupting current installation attempts .
Use the restore system application to set your computer back to an earlier date when everything was running smooth .
Next time you need to delete a program , use a proper tool like free RevoUninstaller from :
http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
Best regards ,
fanaudi .
May 13, 2011 | Computers & Internet
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Oct 15, 2010 | Corel Draw 8
Coreldraw 12 does not launch even on new installation of xp and coreldraw 12
Are you receiving any errors?
Is this the shortcut on your desktop?
I would try navigating to the actual coreldraw.exe file
windows logo + r
type
coreldraw.exe
If it's anything like microsoft word you can use this
window logo + r
type
coreldraw.exe /s or /a for safe mode options.
Aug 01, 2010 | Corel DRAW Graphics Suite 12 for PC
What is a M.cdr file and how can I burn it to dvd to watch on dvd player?and the same for a dmg file?
Detailed information for file extension CDR: File classification: Graphic Mime type: application/cdr, application/coreldraw, application/x-cdr, application/x-coreldraw, image/cdr, image/x-cdr, zz-application/zz-winassoc-cdr Identifying characters: Hex: 52494646, ASCII: RIFF
Program ID: CDraw4 , CorelDRAW.Graphic.8 , CorelDRAW.Graphic.9 , CorelDRAW.Graphic.10 , CorelDRAW.Graphic.11 Associated links: XnView Other applications associated with file type CDR:
  • Elite Plus Commander Saved GameThe Identifying characters used for this association are:Hex: 45 4C 49 54 45 20 43 6F 6D 6D 61 6E 64 65 72 20 46 69 6C 65 1A , ASCII: ELITE.Commander.File.
  • Final Cut Pro CD/DVD Image File by Apple Inc.Final Cut provides Mac users editing tools, sound design, real-time motion graphics and DVD authoring. CDR files are ISO images and, if moved to a PC, can be renamed and burned as ISO files. Associated links: Ken Stone's Final Cut Pro Website
  • GameJack Virtual CD or DVD Image by S.A.D. GmbH.Appears to be an older extension. GameJack seems to use .XMD now.
  • Raw Audio-CD Data
  • Sound File This association is classified as Audio. Associated links: Linux Player
The DMG file type is primarily associated with 'Macintosh OS X' by Apple Inc.. On the Macintosh, these files are treated like a real disk. They can be created with Disk Copy, burnt to CD or mounted as a normal volume. The DMG file also comes in different formats: HFS, HFS+, UFS, ProDOS, Linux, and Fat32 and so may also require special mounting software to account for the format. IsoBuster can interpret these files directly as can other programs such as UltraISO. The program TransMac, by Acute Systems, can both open and create DMG files on a PC.
Oct 22, 2009 | Apple iMac 24" Desktop
Corel draw files do not open
Try launching CorelDraw FIRST then open the file from the CTRL+O command in Corel. Let me know if this works!!!
Mar 18, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
Can't open Coreldraw 12 file
convert bitmap object in lo-resolution by convert to bitmap option & than try to save the document
Feb 26, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
Oracle 10g Database Standard (ODBSEONUPP0) Logo
74 people viewed this question
Top Oracle Computers & Internet Experts
Bonded Repair
JonSnell Electronic
JonSnell Electronic
 steve
steve
Are you an Oracle Computer and Internet Expert? Answer questions, earn points and help others
