Question about Motorola Mobility RAZR V3x Cellular Phone
Motorola RAZR V3x Cellular Phone Won't turn on
Will not turn on properly, even with charged battery, tried takin battery and sim card and placing back in phone, tried different sim, this is the second battery i've had for this phone. Only lights around the key pad light up.Oh what to do???
  • 4 more comments
  • aster_butt17 Feb 12, 2008
    i havwe the same prob. whats wrong with it
  • DwyerJ Mar 30, 2008
    I put my Dads Telstra sim card into my unlocked Motorola V3x to get some phone numbers out of it and when i took his sim card out and put mine back in my phone would not turn on and the battery was fully charged before this incident
    please help!
  • Anonymous Sep 03, 2008
    My phone will not turn on at all. I was just sending texts one night when it turned off and wouldn't turn back on. I have dropped it a fair bit and do at least 10,000 texts per month but it shouldn't just stop. At one point it turned on to a black screen that said battery: ok programme: ok. Sort of a system reboot. I have no idea what the problem is
  • Anonymous Sep 08, 2008
    key pad lights up but will not turn on.
  • luvshearts13 Dec 05, 2008
    my fone wont turn on either even if the battery is just fine! please help me i dont want to wait till christmas to get another one
  • Anonymous Mar 17, 2014
    Every 30 seconds the phone lights up on its own. There are no notifications causing it to light up. It turns on and then stays on for around 10 seconds and then goes back into sleep mode for about 15-20 seconds then turns back on again.
  • 3 Answers
I have the same phone. it is motorola faulty built of chipsets. just return the phone for a next one
Posted on Feb 18, 2008
How do you change a sim card in a motorola v3
If you want to change a sim, switch off the phone, remove the back cover, remove the battery gently remove the sim an place the new sim.
Put the battery again, cover the phone and switch it on.
Aug 11, 2010 | Motorola Mobility RAZR V3x Cellular Phone
How do I remove the Sim card from a Motorola Razr V3M cell phone?
it is very easy to remove.just use your finger to open the back cover of the phone, remove the battery close to where the battery terminal is, and slide out the Sim card out.
But if you can not remove the Sim card with you finger, just get s screw on something you can use to pull the back cover and the battery out, then you can get access to your Sim card.
Good luck to you.
Mar 15, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Razr v3x sends mms only
Cleanup your Inbox/Outbox, and then pull out battery and sim card for 30 seconds. That should fix it up.
Sep 25, 2009 | Motorola Mobility RAZR V3x Cellular Phone
The v3 keep askin for my sim card but the card is in what can i do
Turn off the phone
Remove the SIM card
Wipe the metallic portion on the back of the SIM with a cloth
Put the SIM card back in
Turn the phone back ON.
If this did not resolve the problem, try using another SIM card so that you could verify if the problem is the SIM card or the SIM slot.
Have a great day!
Sep 18, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My razor is instantly turning off and sayin insert sim card but the sim card is correctly in
Check whether there is any fluff, dust or grease on the SIM card contacts or on the contacts in the phone body. Also check that the SIM card is properly aligned and a reasonably tight fit in its housing
Jun 08, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My motorola razr v3x has no power when i turn it on.
Check to see if the aqua strip is pink. if so then you will need to see your cellular provider. if not insure that the battery is charged and installed correctly with the sim card if needed. If it still doesnt work I would check on my warranty status.
Jan 11, 2009 | Motorola Mobility RAZR V3x Cellular Phone
changing sim card.............flip phone over....take back off...........take battery out.....take sim out replace it...put battery in..............cover back on done deal....
Nov 04, 2008 | Motorola Mobility RAZR V3x Cellular Phone
....motorola v3xx won;t turned ON!!..HELP
Have you tried replacing the battery? Also try this first - remov battery and SIM card. Wait 1 minute. Replace battery and SIM and power on. See if that helps.
If problem persists, you may have to repair the phone.
Oct 25, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
hi Bilkow..
In attempting to remove the SIM card without removal of the battery you could have potentially broken an electrical link in the main circuitary or caused a fault within the battery compartment.
i would suggest checking out the Motorolla website to see if there are any FAQ's or solutions for you there. if the problem persists, i would contact your Mobile carrier for assisstance.
hope this helps
Oct 12, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola v3 razr
Try making sure the connection points for the sim are clean. After taking the sim out, gently but firmly blow into the area to dislodge any dust. Put the sim back in and cross your fingers.
Jun 12, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility RAZR V3x Cellular Phone Logo
797 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
