Question about Nokia 3200
Nokia 3200 not displaying
I dropped my Nokia 3200 and the lcd connector came off with the contacts.Now the only way to reconnect the lcd is to bgridge it for which i need the diagram of the tracks. Is there anyone who can mail it to me.
  • rolandx Apr 06, 2009
    my cellphone nokia 3200 has no display, how to know to fix my cellphone
First of all press the handset and fix it with cell guard.
Posted on Feb 12, 2008
Step to unlock phone restricted for nokia 3200
you can get the Nokia 3200 model Unlock code at free of cost at here Unlock-free.com/nokia/nokia-3200.html and follow the instructions below and unlock it step by step.
Nokia 3200 unlocking instructions Warning : Do not enter any wrong unlock codes on your Nokia 3200 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 3200 mobile phone, your phone may get permanently locked and sometimes become unusable.
1 - Switch on your Nokia 3200 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3200.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3200 would then display the message "SIM Restriction Off" and will be unlocked!
Dec 18, 2011 | Cell Phones
Solution for black display
There are many relating problems regarding the issue.To Change LCD, secondly Main Strip,thirdly Main strip connector and Display IC(Filter).So, the first step is to change LCD and the Main Strip.If the problem still persist you need to the display IC and to check the Strip connector.But in my advise better to contact mobile repairing shop.Good luck.Thanks for visiting fixya.
Oct 17, 2011 | Nokia 6500 Slide Cellular Phone
Good Day..my nokia 3200 has a problem with its LCD there are two black lines appears on the screen..as the days goes by the lines getting better..i need some help on how to fix this problem..
Experiencing black lines or forming stain is not repairable anymore,possibly needs a replacement,if the parts is with your,this can be change simply by removing the front covert and unscrewing 6 screws using T6 precision screw driver or anything that can release the screw.gently lift up the entire frame to separate the main board,now lift up the lcd connector on upper right portion using any flat thing like cutter or something.now you can replace the lcd and test if the replacement works fine.
Otherwise,bring the phone to a service center for LCD parts replacement.
Thank you for visiting FixYa....
Aug 12, 2011 | Nokia 3200
My samsung corby lcd has got lines on display
Hi! surely is an lcd problem. You will need to have it replaced to get rid of the lines. Hope this helps and thank you for using FixYa!
Sep 20, 2010 | Samsung Computers & Internet
I dropped my nokia 6303 and screen not working now. Phone still works but cant see who's calling. Can it be fixed?
hi,
yes it can be fix ,but unfortunately not by you..beacause its a sensitive case...go to a cellphone shop to repair your lcd connector first ,that lcd connector connects the lcd or glass display to main board of the cellphone ,if it is damage or lost of contact you cellphone display is not working...second try to replace a new and good lcd before going to the last option ,which is the display driver of the phone...the display ic is a small components that makes the lcd functioning..
the above solution must be doing by an expert mobile technician and its step by step procedure must needed to prevent bigger damage in your phone..
i hope it will help you ,thanks for trusting fixya..
Jun 19, 2010 | Nokia 6303 Cell Phone
I turned it on, and the screen has gone all weird like I have dropped it, but I haven't.
you can try to take off the lcd display and then reconnect it again to see whether it will work again.
if not, then you need to buy the new lcd.
thanks
May 08, 2010 | Nokia 5800 XpressMusic Smartphone
I have a nokia 1208,in which the back light is glowing n there is no display.PLz help me,wat is to be done?
You have to replace the screen.Please contact your nearest Nokia service center for a genuine accessory.
Jan 01, 2010 | Nokia 1208 Cellular Phone
My n70 is just vibrating and not ringing and is
The LCD display connector is either loose or the LCD is faulty, the speaker contacts are loose or the speaker is faulty.. Other than that, you have to have it checked by a qualified technician. Follow the procedures below to disassemble the phone and check the LCD, connectors and speaker.
  1. Wear a pair of electro-static discharge (ESD) protective gloves.
  2. Unlock and remove the battery cover.
  3. Unlock the clips of the front cover beginning at the bottom by prying the latches with your fingernail or a prying tool one at a time.
  4. Carefully remove the front cover.
  5. Protect the display with a plastic film.
  6. Remove the 6 screws using a T6 screwdriver.
  7. Swing the user interface (UI) frame assembly upwards from the bottom. Bear in mind that the flex connector is still connected.
  8. Disconnect the flex connector carefully by prying it.
  9. Clean the connectors using a soft-bristle toothbrush with a lacquer thinner.
  10. Remove the engine board and place it in a cushioned non-conducting tray.
  11. Clean the speaker terminals and contact pads on the engine board using a cotton bud with lacquer thinner or alcohol.
  12. Lift up the speaker terminals to ensure it makes contact with the contact pads on the engine board.
  13. Check the resistance of the speaker using a multimeter. The resistance reading should be 20-30 ohms, otherwise replace speaker.
  14. Put back the engine board.
  15. Reconnect the flex connector firmly and reassemble the UI frame assembly.
  16. Remove the protective plastic film and reinstall the front cover.
  17. Insert the battery and turn on the phone.
  18. There should be a display and tone when the hands appear on screen. Otherwise, have your phone checked by a qualified technician.
Check this out for the complete disassembly:
Nov 24, 2009 | Nokia N70 Cellular Phone
My nokia 3200 lcd showing blank can any body send me the lcd jack print for jumpering.
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Jun 10, 2009 | Nokia 3200
No Signal, No Network, No Display
I think that the LCD is not aligned with the phone. Had the same problem when i open my phone.. Just realign the LCD and it would work..
Sep 18, 2007 | Nokia 6600
Nokia 3200 Logo
212 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
