Question about Panasonic KX-FL511 Plain Paper Laser Fax
KX-FL512,612,542,FLM652 During the Tx or making copy a strange sond comes out from the document gear box and the document feeds like step by step not softly. When i replaced the whole document gear box the problem was solved but when I take a look on the gears there is nothing wrong with them. Is there any other solution
    Novelist:
    Champion:
  • 202 Answers
these kind of problem occurs normally in paper printing machines due to faulty rollers / damaged or worn out rollers...
Check with correct spares for the rollers...
Also look for any rust on the feed rods and moving parts at paper entry area...
Really ur curiosity must be appreciated, bcos most people will settle with the rectification of the problem and don't dig further...Keep digging
Keep up the good spirit
bye
Have a nice day
Posted on Feb 19, 2008
    Scholar:
  • 95 Answers
The problem may be in the busing or the shaft that actually holds the gear in place. try turning it by hand, and also try turning it with a little bit of pressure. Check the shafts and especially the base of the gears where they are mounted. Sometimes those gears will wear down at tht point from constant pressure and rotation, causing the gears to slip during operation.
Posted on Feb 13, 2008
  • 31 Answers
Perhaps the problem is in the drum unit
try to isolate the problem with another drum unit.
Posted on Mar 11, 2008
Panasonic KX-FLM652
Do you have a question about this unit?
Jul 14, 2013 | Office Equipment & Supplies
Replace toner and drum and when i make copies they come out blank
This comes from the manual for your device:
A blank sheet is ejected.
You placed the document facing the wrong way when using the copier.
The other party placed the document in their fax machine the wrong way. Check with the other party (KX-MB781 only).
Try putting a page in and seeing if it copies blank and then putting it in the other direction. Have you had the same issue with printing?
If everything comes out blank it is the fuser or heating element.
Oct 25, 2012 | Panasonic KX-MB781 Laser Fax, Copier,...
Memory full
Deleting a Document from Memory
1 Press [Menu].
2 Use UP or DOWN arrow to select MEMORY REFERENCE, then press Start/Copy.
3 Use UP or DOWN arrow to select DELETE DOCUMENT, then press Start/Copy.
4 Use UP or DOWN arrow to select the transaction number TX/RX NO. of the document you want to delete, then press Start/Copy. The LCD displays YES=(*) NO=(#).
If the LCD does not change after you press UP or DOWN arrow, this means only one transaction is stored in memory.
If you are unsure of the transaction number TX/RX NO., print a list of documents in memory (see page 34).
5 Press [*] to delete the document.
If you want to keep the document in memory, press [#].
6 To continue deleting other documents in memory, repeat the procedure from step 4.
To finish, press Stop.
Feb 28, 2012 | Canon FAX-JX200
Document won't feed
Paper Pick up Rollers get dirty or worn out with the passage of time. Hence, require cleaning or replacement if worn out. In case you find them dirty use a soft, dry, lint free cloth to clean the rollers. Dont use chemicals as they may damage the rubber and plastic. However, if needed, you can use damp cloth or some cleaning liquid such as mild detergent of glass cleaner to damp the cloth. As you have posted your question under Panasonic KX-FL511 is would highlight the steps for it. Im Using a similar model KX-FL612
After lifting the top cover, you have to pull down the under part of it down to locate the rollers
Lift the top Cover, Locate the roller and clean them..
Hope it helps! Good Luck!
CreativeTECH
Dec 01, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
Replaced geerbox oil in kx 250(04)now bike wont finde 3rd,4th,5th. it wos fine before.please help me!
Thats a strange one.For some reason it may be just locked in 2 gears at one time.Lift the bike of the ground onto some sort of stand.Don,t start it.Take the plug out.Run the rear wheel backwards and forward.Clicking the gears at the same time.This might 'unlock' a wound up box.Being off the ground you can't hurt it.Just try different gears and in both directions.I hope this helps,because its a strange problem if all was ok beforehand.Thanks
Aug 30, 2009 | 2004 kawasaki KX 250
Out going fax is coming black
FIRST test copying. if the copy come out completely black, then the exposure or scanner lamp or contact image sensor is dead,not lighting on. Now if the copy has black only black lines on it,then you can clean the place where the document passes thru where the light of the exposure lamp projects unto the text of the document being scan,which is the small glass on the left side of the platen glass when you open the auto document feeder.NOTE: Lay your document on top of the platen glass & make copy if the copy come out clean as you needed it,then the lamp is O.K. Then the small glass just need to be clean. If the copy is completely "BLACK", then the lamp is dead, or the circuit that control it. In thus case then you need a technician to do it
Jul 14, 2009 | Panasonic KX-MB781 All-In-One Laser...
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
ADF for MP530 does not work
Welp, I pulled out my screwdriver and fiddled around just a bit and got documents to feed again (yay!). I do not believe this is a permanent fix, though, but it was enough to get my document scanned in without me having to feed each sheet manually.
Step 1: Open the document feeder cover. Easy to do, you just stick your hand under it and lift up. It has a little pressure because of the latch but it is designed to give way when you lift hard enough. Once it's open, pull out the little black plastic piece that keeps the cover from swinging all the way open.
Step 2: Unscrew the ADF motor/gear assembly cover. There's a single screw holding it in. Once you unscrew it, you'll need to pull up on the left side of the cover until it pops upward, then you need to push the cover towards the left until it is freed up from the rest of the cover. This one was a little tricky. Several times I thought I might break it (before I realized that I needed to push the cover towards the left) so try not to apply unreasonable force while you're doing this.
Step 3: Close the document feeder cover, put your documents in the feeder and start your scan. Use your fingers to fiddle with the gears while the ADF motor is running and trying to feed documents. I'm not sure if I flicked the little gear upward or downward to get the documents to feed, but one of those ways got the documents to start feeding. Once it started feeding the first page, it seemed to work well for the rest of the pages without me having to fiddle with it anymore.
I am guessing that there is some level that controls the location of the middle gear that needs to be oiled, but I didn't go any further to try and make that happen. Hence this is probably just a temporary fix for now.
Putting it back together is pretty straightforward. Just do the reverse of what you did to get it open.
Hope this helps someone!
Jan 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
223 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
