Question about Brother MFC 7420 All-In-One Laser Printer
Brother mfc 7420-dark copies
I have a brother mfc 7420 which is printing with very dark backgrounds. I have replaced both the toner and drum units twice. When I check the drum after printing the drum is covered in toner! Any ideas what could be causing this. Many thanks in advance.
  • 1 more comment
  • tniah Feb 18, 2008
    I too am getting a dark background on printed pages, gray and blotchy.
    I have replaced the drum and toner and still have the problem. I guess it was not the drum at all, I hope I can take it back. I see one
    responder says to replace the blade, so where is the blade and where
    can I buy one?
  • Chantal1 Mar 04, 2008
    I have the same problem too! I need help.
    I clean it every day,but it is annoying and doesn't work great
  • barnetpl Feb 28, 2009
    i replaced my toner with an off brand and started getting copies that were nearly black. The toner is all over the drum. I replaced the off brand toner with a brother toner and am getting the same results. I clean the drum over and over and still cannot get a readable copy
    Problem Solver:
  • 10 Answers
U have to replaced blade.
Posted on Feb 13, 2008
  • 11 Answers
Brother is very picky about their supplies. You will have to replace the toner with a Brother brand toner. There is no drum cleaning blade in Brother drums. They use opposite charge to clean and they have a brush to catch paper dust. You will simply need to replace the toner with a Brother toner.
Posted on Feb 18, 2008
Drum end soon brother mfc 7320 printer usb002
My Brother MFC 7420 said drum end soon, so I ordered a new drum. Then I waited for something to go wrong before I replaced it. Basically I was looking for a deterioration in print quality. I waited and waited. I think it was over 3 years. I replaced the toner a few times. While the print quality never really went done, the frequency of other problems finally shot up. When I replaced the drum the problems went away. My advice -- ignore the warning unless you have other problems.
Dec 08, 2013 | Brother MFC 7420 All-In-One Laser Printer
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 printing light after installing new cartridge
It could be an issue with the drum unit either being faulty or the internal drum counter having been reset sometime after a new drum was installed. I would recommend removing the currently installed drum unit and trying it in the second printer you mentioned with the toner cartridges that has been confirmed as working.
If the problem persists it is likely to be a froblem with a fuser or another internal part that is not traditionally a consumable item. In which case I would recommend contacting Brother or a printer technician.
Sep 13, 2012 | Brother MFC 7420 All-In-One Laser Printer
Cleaning blade did not work
error code c00f0401 of my hp officejet v40 printer
Jan 07, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Jan 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
When printing with my Brother MFC, the pages are dark.
Did you change the toner cartridge with a new genuine oem cartridge?
Do a report print <settings> page from the menu and check the 'Drum life' Bar graph. If close to, or at 0%, get a new Drum unit
Dec 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Shadow printing
likely the drum failing. Remove the drum unit and toner cartridge, and check if the drum is contaminated with toner. If so, replace it.
please rate me
Mar 31, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 prints black pages
The drum is defective. The cleaning blade has failed.
Jan 31, 2009 | Brother HL-2040 Laser Printer
Poor print quality from Brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Print problems with brother MFC-8860DN
Brother MFC 7420 All-In-One Laser Printer Logo
1,016 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
