Question about Sony Hi8 Hi-8 Tape
Hi8 camera tapes
Hello i have numerous HI8 tapes from my camera that i was just about to record onto my dvd recorder when my son decided to pick up my camera and drop it smashing it into various peices.
I have alot of cherished memories on those tapes.
Any idea of how or what i can use to get the images off those tapes.
Which other types of camera will allow me to play the tapes so i can record them onto disk?
  • Jaffadutch Feb 14, 2008
    thank you for your help will try and source one
  • 395 Answers
Any brand of hi8 or digital8 camcorder will play back those tapes but sony made a tape deck made to record and play back digital8, hi8, and 8mm tape. you can get here
Posted on Feb 13, 2008
Why am I having difficulty rewinding and playing tapes?
Is the Canon UC9 a HI8 camera?? If not it wont play HI*.
Aug 21, 2015 | Canon UC9 Camcorder
Play back pre recorded HI8 tapes on my TRV130?
The Sony DCR-TRV130 is a D8 digital camcorder which is not compatible with Hi8 camcorders.
You need to have an Hi8 camcorder or DCR-TRV103 or similar camcorders that backward compatible with Hi8 camcorders.
Dec 31, 2014 | Sony Handycam DCR-TRV130 Digital Camcorder
Was giving a hi8 steadshot video camera recorder and do not no what type of tapes it takes and or can i review my recording on tv or must i only put tape in equipment and watch from camera
Hi8 takes hi8 tapes. Your particular model will be the variable to determine playback options. It probably has some type of RCA out that would let you view it on a tv.
Nov 17, 2012 | Video Cameras
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
Nov 24, 2010 | Sony Handycam CCD-TRV81 Camcorder
Problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Oct 23, 2008 | Sony Handycam DCR-TRV140E Digital...
Sony Hi8
If you see the line while in the camera mode (actually recording a scene), then the line will be on the recording most likely. Check your tape for damage by lifting open the front of the cassette (tab on left side of tape), pull tab back while opening cover and inspect for creases or damage. Either of these cases will be non-repairable (bad recording). If the tape path is out of line the then it may be possible to have a tech realign the tape path to correct problem.
Apr 23, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
How do I transfer my camcorders recordings from HI8 tape to a computer or DVD?
Do you have another video camera that will hook up to your computer? In the past, I've connected my old Hi-8 to my Mini DV, recorded the footage from the Hi-8 to the Mini DV and then digitized on the computer from the Mini DV. You will however need some video software like iMovie for this solution.
You can also, hook the Hi-8 camera up to a VCR or TV using the appropriate cable and view it that way.
Feb 09, 2007 | Samsung VP-L800U Camcorder
Tape compatibility question.
Yes. Hi8 camcorders are manufactured to work with 8mm or Hi8 tapes. The difference is the quality of the tape. 8mm tapes will provide about 270 lines of resolution where a Hi8 tape will provide up to 400. For better quality recordings, you'll want to use Hi8 tapes.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sony Hi8 Hi-8 Tape Logo
429 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
