Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
Tv power light blinks but it won't turn on apex gb43hd10
I found this 43in apex tv sitting on the side of the road in a nice neighborhood with the manual and the remote with the original batteries still in it sitting there so we put it on the roof of the car and drove like 6 blocks back to the house.
plugged it in and it clicks once to try to turn on then stops and dosen't turn on and nothing is burnt anywhere on any board and the tv other than that is perfect no scratches no dust nothing anywhere. i,ve spent 3 days online trying to figure out whats up with it cause if it's a decent price to fix it or have it fixed would be worth it to me. also if u unplug it while it's supposedly on and plug it right back in the green light on the front comes on for a second.
HELP>>please any ideas or info appreciated
does anyone have one that works how many clicks does it make when it turns on?
  • 2 more comments
  • beeman212 Feb 16, 2008
    which wire/plug would the anode lead small or big wire.
    thx for the help
  • runner110 Apr 21, 2008
    not getting any picture but you can see the menu screen
  • Anonymous Apr 21, 2008
  • kalaniboy03 May 15, 2009
    i have an apex hdtv. gb43hd08. i turn it on and it clicks like it's going to turn on but nothing. the power light comes on for 2-3 seconds then turns off. no picture no sound. please help.
Posted on Apr 13, 2008
  • 96 Answers
Yes it is diffenatly going into protection mode, I haven't work on this set, dont' know what format it is, CRT, DLP, Plasma, LED, LDS. To me the first obtion on the top is correct, it it still doesn't start check for the horz transistor to see if it is shorted, you will need a moltimeter, keep the hight voltage block unplug, if the transistor is shorted could be caused by serveral issues, bad voltage block, horx transformer, diode in the defflection, or just burt out. Look for other short within that area if there seem to have no short, replace the volt block and it should start. Also some set has shutdown because of bad convergence, don't this set, I would say this one don't have it, if the convergence ic's draw's to mutch current it shout's down the power supply for over current protecting. I have seen this in other set, to know if this is your problem you will have to know lot's about schematic and able to read it and see if it has over voltage, curent and beam protection build in it. Cheaper set don't have it. RCA of famous for this.
I hope this help
What About Bob
Posted on Feb 13, 2008
  • 48 Answers
I've seen this problem several times on this model. Your TV is going into shutdown because the HV block is defective. You can take out the Anode lead and isolate it carefully then turn the set on. If it now turns on, and stays on, then the high voltage block is bad. Getting this part is another, bigger problem.
Comcast remote codes for apex digital dt502
Brand: Apex Digital
Most likely code: 10765
Others to try:
10748, 10879, 10767, 10890, 11991, 10889
To program your remote:
  1. Turn on your TV
  2. Using the code list, find the first five digit code that is listed next to the name brand of the TV that is to be programmed
  3. On the Comcast remote, press and release the TV key
  4. On the Comcast remote, press and hold the SETUP key until the TV mode key blinks twice then release the SETUP key
  5. On the Comcast remote, enter the first listed five digit code
    Note: If this number is entered correctly and is an accepted TV code, the TV mode key will blink twice. If the code is entered incorrectly or is not an accepted TV code, the TV mode key displays one long blink and exits programming mode
  6. Aim the remote control at the TV and press the POWER key once
  7. The TV should turn OFF - if it did not turn off, repeat steps 1-6 with the next TV code listed, until a working code is found
Nov 03, 2013 | Apex Digital DT502
Tv green light is plinking. But tv won't come on, it acts like its.
Power Supply board is dead.Replaced the power supply board will solved this problems.Tries websites, to buy a refurbish power supply board for the replacement.
Mar 20, 2010 | Apex Digital LD1919 19 in. LCD TV
My Apex GB43HD10 pictures disappears after a while, sound works.
possible solder connection in the powersupply needs to be
resolderd it shouldnt cost much
Sep 15, 2009 | Apex Digital GB5108 51" Rear Projection...
My apex gb43hd10 has a black screen square only on cbs.
it is your captions turn captions off how old is you tv is it analog or digital tuner
Jan 19, 2009 | Televison & Video
Apex Digital GB43HD10
I was watching My Apex Digital GB43HD10 one night and i smelled smoke the TV went blank i lost all power, i called the repair man and he came and looked at it and replaced the thermosat and it solved the problem.
Oct 20, 2008 | Apex Digital GB4308 43" Rear Projection...
Apex gb4308 43in problom
From reading your question i have decided this isn't something you have any hope of fixing yourself. Take the TV to a service center/technician they will be happy to fix any "vertical convergence" issues you may have.
Apr 27, 2008 | Apex Digital GB4308 43" Rear Projection...
Apex GB43HD10
You can get the part at Vance Baldwin parts. I am not sure of your boards part number, but it sjould be 8667204170T
here's the link hope it helps.
Jan 16, 2008 | Apex Digital GB4308 43" Rear Projection...
Rear Projection TV
I have the same set, about a year into owning it went black, power light but no picture, still under warrenty and ended up being the main board, they replaced and has worked well since, these tvs are sensative to spikes over the cable line, I got a really good cable surge protector after it was fixed.
Oct 11, 2007 | Televison & Video
You did better than me. 1 year one week.
Aug 21, 2007 | Apex Digital GB4308 43" Rear Projection...
The circuit board on the right hand side is either cracked or the soldering came loose, I took mine apart and found it by mistake, everytime I pulled up the board i had picture again, so I propped up the board with some dumb-dumb and it has still been working, there are no parts for this TV
Mar 10, 2007 | Apex Digital GB43HD09 43" Rear Projection...
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
943 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
