Printers
Problem for Printers
Generic problem for all Printers
CANON IMAGE PRO W6400
By PASHMAN on Feb 12, 2008
HAS A CODE OF E02E01 CAN YOU HELP
Best Solution
posted on Feb 12, 2008
Very Helpful)
techguru005
Rank: Master
Rating: 85%, 62 votes
This error code is a Carriage motor error. Below is the outline for what to check and what to repair/replace. Good luck.
Cause
This is displayed when a jam or other physical problem puts an excessive load on the carriage motor so that the carriage could not operate.
This is displayed when the carriage motor could not reach the prescribed speed within the prescribed time.
Probable problem locations
Foreign object in carriage movement path, carriage rail, carriage belt, linear scale, linear encoder, carriage motor, engine controller, system controller
Remedy
1. Carriage movement path check
Remove any foreign objects (jammed sheet) in the carriage movement path.
2. Carriage rail
Use rail cleaner to clean the carriage rails if a visual check reveals that they are dirty.
3. Carriage belt
If a visual check reveals slack in the carriage belt, remount the belt.
4. Replace the linear scale.
5. Replace the linear encoder.
6. Replace the carriage motor.
7. Cable connection check
Replace the cable between the carriage motor and engine controller if the connection is not functioning normally.
8. Replace the engine controller.
9. Replace the system controller.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 11, 2008
Not Rated)
samrimmer115
Rank: Apprentice
Rating: 0%, 0 votes
we had the same problem at our company and as we where looking we noticed a little copper bush had fallen out of the main carriage and was hanging on the bar of the track
hope this helps
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not... (More)
Answer
Is c4200 stil availabl eto buy?
Answer
My ML1610 Samsung printer is not working. The red and green light are blinking simultaneusly and... (More)
Answer
I have an old HP 3100 all-in-one laser printer/copier/fax/scanner. Two questions. Would like to... (More)
Answer
My Lexmark is X5495. It used to scan, then I downloaded Windows 7 & the printer did not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
