To delete file permently
Dear sir
After deleting the file in harddisk i am getting it back by backsoftware but i need it permently to delete,
Please say how to delete them
    Genius:
  • 2,985 Answers
As you discovered any 'deleted' file can be recovered with the correct software.
The only sure way is to destroy the drive
Posted on Feb 12, 2008
Reset password
Sometimes, passwordprotection is just a software-issue. In such case you can consider to hook this harddisk to another computer, to see if this protection is still active.
If it is, than it might some software located at your external harddisk. If it does, it's good to verify if it is loaded by a .ini-file.
Windows, for example is default set to check for new hardware, and if it is a harddisk, to explore it in the background. If there's an ini-file in the root, it'll read this file, which might link to a program to activate (located at your harddisk). If you're able to remove this file, you've overcome this protection.
For this, you need to go to "start" and then enter the following command : "cmd" or "command" (without the " ").
NOTE : I don't know which type of Windows you use. Some Windows-versions expect cmd, some command.
If you succeeded, a window will pop-up, with black text. Then go to the specific drive. If your drive is known as D-drive, enter "D:"
Than enter "dir autorun.ini" .
If you see this file is present, then delete this file by :
"delete d:\autorun.ini".
If succeeded type "exit"
Finally, reboot your PC and see if your protection is gone.
Oct 12, 2013 | Buffalo Technology Buffalo MiniStation...
Hi ! I have gateway 500 nx, windows XP. I'm tryin to permently delete some files but using the Gateway Manual for my model tells me to " see USERS GUIDE" n then go to " Deleting...
Right clicking the file/folder and selecting delete (or press delete on keyboard)
then select/right click on the recycle bin and select empty
Jun 15, 2011 | Gateway Computers & Internet
How do I permentally delete avery wizard 3.1 ? It still appears after removing it from add/remove in control panel.
Click on start search, put the name of the program in the search for files and folders with an '*' asteric at the end. This will search for any file or folder using a wild card, so all will show up. Delete all the files and folders found in the search.
So, in other words, search for files and folders, put '*avery wizard*' (without the single quote marks) in your search for box and delete the files that are found.
I hope that this was helpful. If so, please leave a positive rating.
Thank You,
Brian
Jan 08, 2011 | Avery Wizard for PC
N73 Cellular Phone: my nokia n73 memory low delete some data sir what ...
This problem Arises When your Phone memory(C:\ Drive) Is almost Full .normally C: Drive Has 44.4MB Space. But When it goes below 500KB,it shows
"memory low delete some data"
So delete unwanted files from phone memory using any Good File managers .One i suggest is Using "Xplore" An application for n73
Which can be downloaded Here
Or else use Phones inbuilt file manager to delete unwanted files from phone memory.
Hope this will solve your problem
(Alternate download Path Click HERE)
May 16, 2010 | Nokia N73 Cellular Phone
How can RECOVERY
Best way, remove and connect your Harddisk, to USB external and find the files, delete the files except recovery just look at the files and read all of them in folder. You will understand which one is recovery and your original Dell files. Then make scan and check error while you are there.
Connected to your computer, But Please read first If you are not sure do not do anything, It is your own risk so doing wrong.
It is easy to recover without deleting original files by just deleting last programs that you have installed. So Delete the programs that you do not need. Goodluck
JMC
Aug 18, 2009 | Dell Studio XPS 16 Notebook
Recycler folder
The recycler folder is a system file, it is created automatically as a place holder for files you send to the recycle bin. As far as I am aware, the only way to stop it being created is to turn of the recycle bin for each drive you have.......Doing this has the effect of permently deleting files though......
Aug 09, 2009 | Microsoft Windows XP Professional With...
Non ntfs problem
One possible work around
Provided you have access to another PC and feel comfortable with taking your hard drive out of your PC and putting it back in
1. buy a USB external hard drive enclosure and install your hard drive into it
2. connect this USB hard drive to another PC
3. create some free space by deleting some files (see Safe files to delete below for details)
4. reinstall hard drive back into your PC and try to boot normally
1. temporary files - on Win XP these are normally in "C:\WINDOWS\Temp"
2. temporary internet files - on Win XP these are normally in "C:\Documents and Settings\[Your Username]\Local Settings\Temporary Internet Files"
3. other temporary files - on Win XP these are normally in "C:\Documents and Settings\[Your Username]\Local Settings\Temp"
Note that if you have more than one user account on the PC, then each user could have files that are safe to delete in the folders mentioned in number 2 and 3
-Magnon
May 24, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Delete permaent
Delete - will simply remove reference to the file- thus making the space available - this can be reversed.
To remove filed permanently from a hard drive the whole drive need to be overwritten then formatted-
Even here a determined individual with the correct software will still be able prise out old data.
The only sure way is to destroy the drive.
Feb 12, 2008 | Computers & Internet
Computers & Internet Logo
364 people viewed this question
David Payne
David Payne
