Question about RCA R52WM24 52" HDTV Projection Television
FL231 replacement did not work
I have the same issue as the above, and hoped the FL231 replacement would do the trick. Now I am back to where I started, a mostly new (17 months) TV with convergence problems. I already replaced the convergence board as well. A technician said it would take him hours to figure out which fuse/transistor/or whatever else may be broken on the board. Here in Hawaii, labor is in excess of $100 an hour. Any further suggestions? And anything being started against RCA for consistently building a product that goes bad immediately after the warranty period has expired? Come on, the date stamp on my TV is JUL 06!
  • 44 Answers
Convergence is not the problem my dear. what u saw is due to improper signal. you said u replaced the convergence board, but the problem is still there. the frequency is not proper. what happen sometime the component used in the board shift there value. u chage the board that's ok, but you didn't check the frequency applied to that board. in some cases the frequency is applied through the electrolytic filters. after sometime they shift there value and make variable changes in the frequency. in some cases it is applied to complementry transistors. pair of two transistors NPN & PNP. what we do, we first check the electolytic filters, in most cases they are defective. second option is the polyster capacitors, who hold the frequencies and play the important role in any electronic device. if there is any tantulum capacitor is used, it's rare chance of them to be defective, there only alternate is- replace them. if you have any other source like:. external frequency generator board (which produce both horizontal & vertical frequency with clock pulse). it would be helpful.
tell me if you check all this then i will give you more solutions......
but i don't think u need more
BEST OF LUCK
Posted on Feb 12, 2008
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
2wh7rca r54 - blowen fuse after replaced
You replaced the fl23 fuse? Did you rember to resolder the connections on the flyback?. Look in the tips and tricks section for the fl231 fuse problem
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Double picture, red,blue,green lines
consult the Article in the tips and tricks section "the fl231 problem"....it give complete instructions on this simple repair and where to locate the fuse
May 10, 2009 | RCA R52WH73 Projection Television
RCA R52WH73 convergence problem
have you checked the article i wrote on the fl231 problem. its in the tipss and tricks section. ititle the fl231 fuse problem. the convegence option missing is a clear indication of this problem. it a repair that anybody that can use a soldering iron can do
Apr 10, 2009 | RCA R52WH73 Projection Television
Convergence problem
Replace FL231, DL231 and CL230 the parts and free instructions on how to do the repair are available at the following link. The parts are listed under the RCA parts category.
http://servicemanuals.vstore.ca/
Mar 13, 2009 | RCA R52WH73 Projection Television
R52WH74 WONT CONVERGE
first question is the picture also bowed in on top and bottom. if so you may have the common fl231 fuse problem if you do consult the fl231 problem under the tips and tricks section. if you dont then you defently hav a convergence issue. the thing to look for is under setup do you have the autoconvegence option if you dont then you have that problem.
Jan 17, 2009 | RCA HD52W59 HDTV Projection Television
Destorted picture on my tv
the fl231 problem requires a soldering iron. to remove it from the circit board. I would not recomend this for someone who has never soldered before. and consult the fl231 problem under the tips and tricks section
Dec 26, 2008 | RCA HD52W59 HDTV Projection Television
My Television looks like 3D
if this is the fl231 problem look under my profile under tips and tricks section. there is a detailed instruction on how to repair the fl231 problem
Nov 11, 2008 | RCA HD56W66 56" HDTV
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
