Question about NEC MultiSync XM37 Plus 37 in.CRT Conventional Monitor
Monitor Screen Is Bright White When Turned On
I have a NEC Multisync XM37 Plus and one day why using it, the screen went real bright. I have tried to adjust the contrast but it did not fix the problem.
Justly open [of] its box and searching of sparpart flybac and turn around variable screen, ok later will be found [by] appropriate picture, [in] www.modifmax.com
Posted on Feb 15, 2008
Justly open [of] its box and searching of sparpart flybac and turn around variable screen, ok later will be found by appropriate picture, in www.modifmax.com
    Problem Solver:
  • 16 Answers
Try to reset to factory defaults
Posted on Feb 13, 2008
My computer screen became way to bright all of a sudden what should I do?
the monitor is on its way out, but you could adjust the brightness and confirm the power going in
Mar 27, 2010 | NEC MultiSync 1920NX 19" LCD Monitor
Multisync lcd1760nx This monitor powers up and works fine as far as I can tell. I set my notebook screen to show on this monitor as a clone screen(same image as my notebook screen). I cant see the image on...
Hi frnd.. there is a test known as Monitor self test to perform this just power on the monitor and unplug the flex cable.. U will see a logo bouncing up and down.. if this happens then it means the monitor is fine...
Sep 29, 2009 | NEC MultiSync 1760NX 17" LCD Monitor
Laptop monitor comes on bright whitish color
may be the LCD display of the laptopisgone or ur VGA adapter has some issues
Jul 26, 2009 | HP Compaq Presario C700T Notebook
Screen is on, but does not appear to be on
The monitor was broken. I returned it to the vendor for replacement. Your tech did not seem to feel it was a monitor problem and only focused on the video card - although I asked him directly regarding his confidence of it being a videio card problem versus being a monitor problem.
I will not use your service again.
Mar 21, 2009 | LG 22" FLATRON LCD Monitor
NEC 1860nx. When owering up monitor, screen lights up, then 2 seconds later goes dark. Can I repair this?
The inverter board was made using lead free solder.... thank the Europeans for that. The larger components develop cracks on their solder joints after a few months of on time. Remove the inverter board. Use 15x magnification or better in bright light and you'll see the cracks on the ends of the large resistors. Apply fresh solder and you'll be good to go. You might run into resistors where you solder one end and they lift up... that means joints on both sides went bad. Son't kow how many more fixya's I'll answer w/o free access to the other responders?
Mar 15, 2009 | NEC MultiSync LCD1860NX 18.1" LCD Monitor
On-Screen menu keeps showing
My screan is too bright how do I adjust to make it toned and more comfortable to use
I have A NEC MultiSync LS15
Feb 15, 2008 | Computers & Internet
Screen and colors too bright
CRT and LCD will look different when compared side by side. Is your CRT calibrated, or are they right in the sense that they are what you are used to? Also Anyway, you can adjust the colors and light levels from the menu on your screen, and depending on your operating system and graphics adapter you should be able to make adjustments there, too. For windows XP, right click your desktop and select properties->Settings->Advanced. There might be a color management tab. Also, there might be software to help you do this already installed. Look for a program group with the name of your Graphics adapter manufacturer. Very often ATI or nVidia. A few resources to help calibrate: http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm
May 17, 2007 | NEC MultiSync 1920NX 19" LCD Monitor
NEC MultiSync XM37 Plus 37 in.CRT Conventional Monitor Logo
111 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
