Question about D-Link SWT DSL-504T ADSL MODEM with 4 Ethernet Ports (790069265204)
Multiplayer ip when i want to play multi player in gamespy it tould me that the router that i have (D-link DSL 504T) give another ip for the client instead of the real ip . i'v already import all the ports of game spy to get away from the firewall (to windows firewall and router firewall ) but the problm still existing . please help me ...
  • 667 Answers
If you need to open ports on your router just follow the manual. If you need one just add a comment and I'll get right back to you. If this doesn't work do the same. Go slow and follow instructions. This should fix your problems. Keep track of what you do so it can be undone to start fresh just in case this doesn't work but it should.
Firewalls
GameSpy Arcade is 100% reliant on your Internet connection being fully functional. The same holds true for any games that you want to play online against other people. Firewalls and proxy servers are designed to block your Internet connection in order to minimize the chances that your computer will be accessed (or hacked!) by "unwanted visitors." They also have the unfortunate side-effect of disabling many of the things you might want to do online -- like play games -- since these activities depend on your PC making an unimpeded connection to other computers. Therefore, if you are using a firewall or proxy, Arcade may not function properly nor will you be able to download and install all of the files that you need in order to use the software to play games online.
Connecting to different places online requires access through "ports" in your PC's Internet connection, and firewalls and proxies will close certain ports for your protection. This is not always necessary, but you as the firewall/proxy owner are the only one who can open those ports. We can't do it for you - but we can give you some tips on how to configure your firewall / proxy to allow Arcade to work properly.
What is a firewall or proxy?
Firewalls and proxies are software programs or pieces of hardware designed to protect your computer and/or network from Internet intruders. Some of these are:
  • Windows XP Firewall
  • Norton Internet Security
  • Tiny Personal Firewall
  • Zonealarm
  • Sygate (proxy)
  • Wingate (proxy)
  • Internet Connection Sharing aka ICS - provided by Windows 98SE and higher (proxy)
  • Linksys Routers (hardware firewall)
  • D-Link Routers (hardware firewall)
  • Cisco Routers (hardware firewall)
Working Around the Firewall / Proxy
If you are behind a firewall/proxy and are able to change its settings, Arcade needs the following TCP ports open in order to function:
  • 6667 (IRC)
  • 3783 (Voice Chat Port)
  • 27900 (Master Server UDP Heartbeat)
  • 28900 (Master Server List Request)
  • 29900 (GP Connection Manager)
  • 29901 (GP Search Manager)
  • 13139 (Custom UDP Pings)
  • 6515 (Dplay UDP)
  • 6500 (Query Port)
    Disabling firewalls will not work
    Unfortunately, in most cases, firewalls/proxies cannot simply be disabled in order to allow you to use Arcade and your game. Disabling the firewall / proxy will not open the necessary ports. It will simply shut down the firewall/proxy and leave the ports closed. Also, many factors may conflict with your firewall: Internet Connection Sharing, the use of more than one firewall, or your operating system may all cause conflicts that keep you from enjoying Arcade.
  • Special notes to Windows XP users:
    Windows XP has a built-in firewall. If you are using 3rd party firewalls/proxies with Windows XP, you will have to consult both the firewall/proxy developer and Microsoft to determine their compatibility with one another. You will also need to speak to your game's developer in order to determine the game's compatibility with WindowsXP, its firewall and your 3rd party firewall/proxy.
    Disabling / Setting Permissions on Specific Firewall Programs
    We do not recommend disabling your firewall. Disabling it will not make it open up the ports it has already closed. Instead, you need to configure it to allow access to Arcade. This is usually called "giving permission," and can be accomplised quickly by following these steps:
  • Windows XP Service Pack 2 -- The built-in firewall that comes bundled with Windows XP will affect two areas of your Arcade experience: 1) Arcade itself (including the login process, using PlayerSpy, chat, using the Download Manager and playing games) and 2) Hosting any parlor or peer-to-peer games. In order to use Arcade and play games properly with Windows XP, you should follow these steps:
    1) Unblocking GameSpy Arcade During Login: Click the "Unblock" button in the Windows XP firewall prompt the first time you attempt to log into Arcade atfer installing Service Pack 2
    2) Unblocking GameSpy Arcade via Control Panel: If you forgot to click "Unblock" in Step 1, or if you want to be ahead of the curve, you can configure the XP firewall to unblock Arcade via the Windows Control Panel. To do this: Click on Start > Settings > Control Panel > Windows Firewall. In the Windows Firewall menu, Click on the Exceptions tab. If GameSpy Arcade is not listed, Click on the Add Program button, find GameSpy Arcade on the list of available programs and click the OK button.
    3) Unblocking Your Games: This can be done in one of two ways: a) Either wait for Windows to prompt you to unblock the game and click the Unblock button (this usually happens the first time you attempt to host a game after installing Service Pack 2, or; b) Use the Windows Control Panel to add the game to your list of Exceptions, using the same method listed in step 2 above.
    4) Unblocking Ports: You can take the unblocking process a step further by instructing Windows to open the Firewall to all ports used by GameSpy Arcade and most of its supported games. To do this: Click on Start > Settings > Control Panel > Windows Firewall. From the Windows Firewall Menu, click on the Exceptions tab, then click on the Add Ports button. From the Add Ports Menu, enter a port from the list of ports at the top of this Arcade support page. Be sure to indicate whether this is a UDP or TCP port (the list above should indicate which it is).
Posted on Mar 22, 2008
D-Link DSL-504T driver disc missing, looking for Win 7 compatable driver for modem.
No driver needed since you aren't connecting the pc the the modem, but to the router.
Connect the pc to the D-Link DSL-504T with a LAN cable, access it from a browser by going to this IP - 192.168.0.1 - , in there access the modem settings and configure it accordingly.
Jun 20, 2011 | D-Link SWT DSL-504T ADSL MODEM with 4...
I suspect other people may be using my internet. I have a DSL-504T D-Link router and a Belkin wireless router connected to that for our laptops, how do I protect our internet?
Go to the site
http://support.dlink.com/emulators/wbr2310/wireless.htm
and follow the steps for your router.
1.In Wireless Security mode select Enable WEP wireless security.
2. Authentication select as shared key.
3.Now set your WEP key values.
4.Save the setting.
Hope this will help you.
Thanks for using FixYa.
May 14, 2011 | D-Link DSL-504T Router (DSL504TX31FOC)
How can I play Conflict Global Storm online
You need to have GameSpy account to play multiplayer internet
If your old GameSpy account refuces to login, just stop fighting with it and make a new one because this game has issues with too old GameSpy accounts.
If you get error message about friends list when you try to log in GameSpy account, you need to remove some friends from your GameSpy account friends list or just create new GameSpy account with no-one on friends list.
To host and join multiplayer you have make sure you have public IP, because this game requires a lot of open ports (see manual page 17).
Aug 24, 2010 | Eidos Interactive Conflict: Global Storm
I need to change the modulation type on my modem to select g.dmt to make my internet connection more stable HELPPPPP!! i have NO clue how to do it. it's an ADSL 2+router DSL 504T.i am computer...
To configure the modem You will need to use the cd provided.
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_C3_QIG_v2.00.pdf
Or to configure without the cd follow the steps below:
  1. Connect the Adsl router with your computer.
  2. Use the network cable provided with the router.
  3. Connect the power cable to the modem, it will light on firmly with a green button on.
  4. Open your web browser and type the ip address: http://10.1.1.1
  5. Default username and password is:
  6. User-name: admin
  7. Password: admin
  8. Use the quick setup wizard.
  9. It will be more easy for you to configure it.
  10. Be sure to have the username and password from the ISP for the internet access, you may need to reconfigure it from start. or if you may need to reset the modem
  11. At times to access your modem you will need to set the ip of your network card to the same range.
  12. To set the ip go in control panel then open network connection
  13. Doulbe click the local area connection.
  14. open Internet Protocol Open Tcp/ip
  15. then set your ip Like: 10.1.1.5
  16. ok
  17. ftp://files.dlink.com.au/Products/DSL-504T-GenII_NZ/Manuals/
I am enclosing a manual for you.
If you Need further help do not hesitate to revert back
Ok cheers
Uttam
Feb 13, 2010 | Computers & Internet
Remote manage a DSL 504T router
If you have a dynamic IP on your wan port you shall register a domain name and register it with dynamic DNS, provide your dynamic dns name in your DSL router so that you shall connect to your DSL router by calling the registered dynamic dns name from any where (you should have internet connection).
1. Register a name in dyndns.com
2. update this on your dsl router
Wait for some time,
3. access the registered name from anywhere using a browser
Jun 09, 2009 | D-Link DSL-504T/EU Router
Router problem. Netcomm NP740n
you can always go into the router by entering the default gateway ip.
Worst case scenario - do a hard reset on the router to fix it.
Jun 08, 2009 | Computers & Internet
I need to open port 8888 on d-link DSL-504T and is there any manual i can see to do that thanks so much
Please download this maunal.
http://www.pobox.co.uk/support/downloads/manuals/DSL-504T_Install_Guides.pdf
and refer to page 14 which is port forwarding...
Jan 28, 2009 | D-Link DSL-504T Router
Belkin wireless router not assigning IPs for wireless clients
Some routers start handing out DHCP wireless IP's at 192.168.2.100. Try setting the upper limit at .110. If the router is found in a site survey (view wireless networks) but cannot connect, the limitation would be why.
Jan 10, 2009 | Belkin (F5D7230-4) Router (587009)
DSL-504T Router - not connecting?
Try using the D-Link Click'n Connect Utility.
Admin is the correct code for both the user name and password.
10.1.1.1 is the correct IP address for the setup page.
You may need to reset the router again by holding the reset button in for 30 seconds until the lights flash off then on.
Here is the setup manual:
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_GenII_QIG.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 04, 2009 | D-Link DSL-504T Router
Pluging in
Rather than me repeating them, this same question has been answered several times on FIXYA. I would copy
and paste it in the FIXYA search on top of page to find several answers.
Dec 25, 2017 | D-Link SWT DSL-504T ADSL MODEM with 4...
D-Link SWT DSL-504T ADSL MODEM with 4 Ethernet Ports (790069265204) Logo
1,627 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
