Question about Minolta magicolor 2300W Laser Printer
Problems with the changing the toners
Hey, The program on the pc tells me that the toners are empty, now i've changest the toners but nothing helps. In the software program i can't klick on the menu item - toner replace... - so what can be the problem of this?
Thanks for helping me.
    Champion:
  • 214 Answers
Pleas try to install the status monitor again, if status monitor is installed correctly, then the toner replace should be available
Posted on Feb 28, 2008
Toner empty error message
my dear you chek toner and change toner tenk
Jul 08, 2015 | Xerox WorkCentre 3119 Laser Printer
Cartridge not recognised!
Assuming it's installed correctly, removed the protection. Try unplugging it for a bit, then plug in, it should do a selftest.
Apr 28, 2013 | HP Laserjet Pro Cp1025nw Color Printer
There is a red light flashing beside the triangle symbol on my cannon lbp5050n. What does this mean?
Hey!
If that happens look in the system tray for a yellow tiangle,click on it and it will tell you the problem!It might just be a empty toner!
Hope it helps!
Jun 28, 2011 | Canon LaserShot LBP5050N A4 Colour Laser ,...
Where is the toner sensor on the toner holder in the DCP-7020 it keeps telling me toner is empty and toner should not be empty yet.
If you look at your toner cartridge you should be able to see a clear plastic circle. That's part of the toner level mechanism. I've gotten a few more prints out of my cartridges by putting a piece of tape over the clear plastic and coloring it black with a sharpie. However, there are other mechanisms used to gauge toner levels, and this will not be a permanent fix.
I've also gotten a little more life out of it by simply shaking the toner cartridge for about 15 minutes. It helps coat the inside and might break up chunks inside the cartridge itself.
Jun 16, 2011 | Brother DCP-7020 All-In-One Laser Printer
We have a Brother HL-2040 abd the toner light keeps flashing and we are unable to print anything and it has toner in it
Hey there,
Brother printers are known for this problem. They tell you that toner is empty based on sensors and not based on actual toner left. A way around this is to take out the toner and look on the sides of it. There should be a hole on each side (one that has clear plastic over it). These holes are used for the sensors. Take some electrical tape (or any dark tape) and tape over those holes. Once they are tapped over the sensors think there is toner. Put the toner back in and enjoy.
Hope this helps!!!
Mar 17, 2011 | Brother Office Equipment & Supplies
I have Canon ir5075 and it asks me to change waste bottle. I empty the bottle. But do not know how to tell the printer that it is empty.
I am not familiar with this model but usually Canon waste bottle has:
1. Check if the waste toner botlle has some clear portion near the neck, (as in IRC3200) or other part of the bottle ,even the waste toner was removed but if this portion is still clouded by toner the sensor will still detect the waste is full
2. If the situation is not like this some Canon Ir machine needs to reset waste toner counter in the service program mode even the waste toner bottle was emptied
Jun 09, 2009 | Canon imageRUNNER 5000 Copier
Question about mc 2350 cartridge
I just got done replacing my toner.  You'll need to change toner and most likely all of them. There is no other solution.  I refill mine by buying the bottle toners.  It can be messy and you'll need to take some parts off the cartridge to get to the opening plug and reset the lever so that the printer knows the cartridge is full.  It is cheaper than buying a toner. The cartridge has a life of about three refills.  Anyway hope this answers your problem.
Aug 07, 2008 | Minolta magicolor 2350 Laser Printer
Minolta 2400W - Put cyan / black toner
hey, the problem is that toner cartridge reading chip is dirty.
take out Pc drum and remove all toners, clean toner chips with alcohol. then locate a 3 pin reading chip under the toner rack left side and use pressure air to clean it. reinstall everything. if its not helping, replace the chip, its not expencive
Jun 28, 2008 | Konica Minolta magicolor 2400 Laser...
How to overcome the "Toner Empty" message?
hmmm..that toner empty issue is built into most printers, and it's not something that you can fake out, in most cases. Oki is telling you the straight stuff, here.
May 01, 2008 | OKI C3400N Single Pass Color Printer
Printing in Grayscale or black
Too few manufacturers will allow their units to print in grayscale when a color toner is low or empty. The only way to get your unit working is by installing the required toner. By the way, start a budget to buy the transfer belt, drum unit, waste toner bottle and fuser unit. These are also consumables with a lifecycle.
Oct 01, 2007 | Samsung CLP-500 Laser Printer
Minolta magicolor 2300W Laser Printer Logo
104 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
