Question about Epson Stylus R265 InkJet Photo Printer
Epson Stylus Photo R265 icc problems
Hi im usings a bulk ink system and a sublam ink but the problem beening that when i print the colour come out flat and a bit blue i think i need another icc profile ?
can you help
spener
  • Anonymous Apr 24, 2008
    r265 using euroink dye sub ink, texptint transfer paper,adobe rgb for files,colours suddenly not right after a printer reinstall.
    Have tried changing printer settings to use sRGB ,no joy
Great Answer Malco, I hope with this credit crunch you will lose your job in Epsom, the correct answer should be how come Epsom rip off customers with inks
The correct answer should be there are good and bad CIS suppliers as a rule of thumb anything from China is pretty crappy, but check out which ones are reported as good, I use signal inks, but there are far better inks out there, just research on the net.
Also matching the screen to the print out put is mostly the biggest problem, is all about tweaking the settings.
Regards
Posted on Apr 09, 2009
I also have an Epson printer that uses sublimation ink and found the colors to be dull when printing. But when I heat press the printed item onto my sublimatable items the colors turn out great. I'm assuming that you are sublimating onto items like mousepads and puzzles and mugs and stuff? (since I don't know of any other use for a sublimation printer) If yes, then I suggest trying to sublimate an item using the printout that you have and see if the colors turn out better.
Posted on Mar 17, 2009
  • 32 Answers
Do you mean you are using OEM lookalike cartriges or are bulk refilling cartridges with non-Epson ink?
Thats your answer!!!
Posted on Apr 13, 2008
EPSON R265 cd/dvd printer can not print in black colour I have tried to reintall the driver but still can't print in black ink. Other colours print well. Ink cartridges are new.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Jun 06, 2011 | Epson Stylus R265 InkJet Photo Printer
My Epson R265 prints all of the colours green
Sounds like colour contamination to me.
Check the carts are in the right slots.
then print until it clears the problem.
May 09, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson R265 printing colours incorrectly
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
Jul 02, 2017 | Epson Stylus R265 InkJet Photo Printer
No true colours in Epson Stylus Photo 1400
Given that you are using a dye-sublimation ink I have to ask if you're basing the colours you're getting on the results on your substrate or on the finished product (after you've done the heat transfer).
Beyond that you should probably ask the supplier if they have a colour profile for their inks. If not you can look for one of the services available. I can't make any recommendations but communication with this company has been quite positive
Sep 01, 2008 | Epson Stylus Photo 1400 Printer
Epson r265
Hi - What type of discs are you using? I have an Epson 200 series printer and use these discs click here.
Also what ink are you using as some "compatible" inks do not work well on printable discs.
Best regards,
Informatica
Jul 03, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson R265 Printer
2. TRASH and REINSTALL the drivers
3. Try a different application and file
4using a PHOTO PRINTER (Stylus PHOTO) try to set the QUALITY OPTION to BEST PHOTO or PHOTO RPM
5. Go to PRINTING PREFERENCES and hit ADVANCE
6. Choose the right PAPER TYPE, SIZE and SOURCE then disable HIGH SPEED
7. Once all those are set choose PHOTO RPM under the COLOR MANAGEMENT box and try printing
8. This will print a lot slower but will be using alot of ink and eliminate the lines
Apr 04, 2008 | Epson Stylus R265 InkJet Photo Printer
Help with waste ink problem on Stylus Photo 2200 printer
Hi Beckedy;
i have a solution that may help you but I need more info. Email me at gamesreplys@yahoo.co.uk
Dec 07, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus R265 InkJet Photo Printer Logo
740 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
