Television repair My TV is not working when I switch it on the led light up but no other action the CRT does not light at the back where it supposse to light what could be the problem
  • goldeneffey Feb 12, 2008
    my samsung lcd tv has no pictures appearing on the screen but the sound comes on.
  • 44 Answers
Check the EHT Transformer and the power transistor connected with it. follow the track of centre pin of power transistor. check the power supply and the fuseable resistance in circuit. also check the drive at the driver transformer. check 2-3 volts AC drive on base of power transformer. inform me if you find any problem.
Posted on Feb 12, 2008
It is a 32A14 model. power to house was cut off, electric people replaced phone poles. when power came back on tv wouldn't turn on, no red LED indicator light lit up, and it makes this chirping sound in...
The tv high voltage "H" horizontal transistor IC is dead.That "H" transistor IC sit out side outer wall of the FBT-the flyback transformer,that the big black block of a plastic,with a red wire with a cap hook up to the CRT-(tv tube).Best take to the shop for repair,because part for analog tv are impossible or near impossible to find and do for the replacement.
Mar 14, 2011 | Toshiba 32A14 TV
My TV just turned off and the red power light started to blink, why?
In most cases this error will dissapear by switching your television off at the wall and then switching tv on (via power button on TV front/side panel) "Whilst still switched off at wall outlet"
This will discharge all capacitors inside the TV
Now turn TV power button off then switch back on at the wall outelt then try to resume watching TV.
This solution may clear the blinking red light however if it does not it could be a more serious issue such as a blown fuse or even blown control circuit on the TV, In this case you should decide whether a repair is economical or to replace the TV.
This solution is based assumption this a CRT television and not an LCD.
Hope this helps
Feb 28, 2011 | Toshiba Televison & Video
Tv just stopped working while it was on and being watched. when it is on there is a light humming noise coming from the back
This tv have trouble getting a High voltage on to it tv (CRT tv tube) screen,sorry can be any things,in the tv any electronic components is dead. This tv must be troubleshoot by a tv Tech. to rplaced to repair.Shop for another new tv and compare the tv shops,prices for a repair,which it better for u,take that actions.
Dec 15, 2010 | RCA 35V432T 35" TV
Got blue dots on screen
Sounds like you have a light engine, or another term for it is optical block, that is going bad. We've seen several of these at our tv repair shop. It is a very expensive repair in most cases. Try contacting sony about it. They were offering a discount on a new lcd or led tv from a class action law suit for this part.
Jul 28, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
Sony BRAVIA 32 inch
I had the same problem with a old Sony TV.
To find out if the problem is temporary
  1. Turn off the television.
IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
If the light is still flashing the tv has stop working and you will need to buy a new one.
Dec 08, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Television repaur
It sounds as though you have a bad start up circuit. This problem could be a transistor , capacitor, scr, diac or several other components in the power supply. This is not a problem a non trained person can repair as you will need to trouble shoot the circuit board. If you do have experience in trouble shooting components, start in the power supple with the regulator transistor, and also always check the horizontal output transistor before moving on to the transformer. Good luck and I hope this has helped in some way.
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Televison & Video
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
