Question about Acer Aspire 5100 Notebook
Pioneer DVR-K17RS ATA ACER CODE=39
The Pioneer dvd-rw referenced above in my notebook (aspire 5630) does not function - code 39 error. The driver is the problem but I cannot find a new or updated driver to make it work. Can you help?
Pioneer DVR-K17RS ATA in new laptop - suddenly stopped working - gives code 39 error; can't reinstall driver. have tried deleting it from devices (Windows vista machine) Sorry the product is an Acer Aspire 5720 but this programme refuses to accept that
  • Grahamt Apr 27, 2008
    I had the same problem on an Acer 7720Z. Fix is here:
    This is a bizzare fix but it works. Microsoft do not want to know.
    I lost my CD Rom drive after installing my mobile phone sotware
    Go to http://www.unisupport.net/lang/en/tevion...
    Scroll down the page to:
    Download the ArcSoft Universal Windows XP / Vista Patch:
    1) Download this patch - just click on this line of text to download
    This takes you to: http://www.arcsoft.com/downloads/patch/A...
    Click run.
    Once complete reboot and you will now be able to access your CD rom/DVD RW
    It's far less painful than REGEDIT !!!
  • Anonymous Oct 02, 2008
    mesecito Driver DVD Pioneer K17Rs
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)" . You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Nov 16, 2008
    Problem Solver:
  • 31 Answers
Hi Friends,
Acer Aspire 5100 PC Notebook main problem is Connection Problem, Software Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
d45s4
Posted on Jul 20, 2010
    President:
  • 1,257 Answers
A good registry scanner can clean up a lot of problems with your computer. Here's a link to a good free one:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on Apr 27, 2008
Go to http://www.unisupport.net/lang/en/tevion_usb_dvb-t.html
This takes you to: http://www.arcsoft.com/downloads/patch/ArcSoft_Vista_Update.exe
Click run.
    DO NOT USE REGCURE - ITS A SCAM SITE !!!!
I was having a similar problem with my new VAIO VGN-CR22DE PC Laptop running VISTA and has a PIONEER DVD-RW DVR-K17 ATA. However, I was getting a error code of 10.
I found a solution at the following link:
http://discuss.extremetech.com/forums/thread/1004364399.aspx
This usually happens when a piece of software is uninstalled and doesn't remove all its connections to the drives, which you didn't even know it had installed. Heres a method that worked for me.
1. Choose Start > Run.
2. Type regedit in the Open text box and click OK.
3. In the Registry Editor dialog box, navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4. Select File > Export (Windows XP) or Registry > Export Registry File (Windows 2000).
5. In the Export Registry File dialog box, select Selected Branch under Export Range, name the file (for example, CDDVDkey.reg), and click Save to save the file to the Desktop.
6. In the right panel of the Registry Editor, select the LowerFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box.
7. Select the UpperFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box.
8. Close the Registry Editor.
9. Restart Windows.
I hope this works for you.
Posted on Mar 02, 2008
Got the problem myself and have tryed ib4g2008 advice, still dose not work
Posted on Feb 15, 2008
    Genius:
  • 3,587 Answers
Go to system in control panel..remove the DVD from the list..scan for hardware changes, then it will re install the driver again.
got backup for your Acer?
Posted on Feb 12, 2008
  • 244 Answers
SOURCE: Pioneer DVR-K17RS ATA ACER CODE=39
If you can't restored the driver, you should reload the operating system using Alt+F10 or using disks (not from windows, boot from disks)
In your case, it's look like you can't access the dvd in windows, i hope you can access in dos mode.
Posted on Jan 20, 2008
  • 13433 Answers
Try to remove the device from Device manager, and then reinstall or upgrade the driver. If the error continues to occur, it may be possible to edit the operating system Registry to resolve the issue.
Click the Start button, press run and type regedit.
  1. In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
  2. In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
  3. In the System folder, double-click the CurrentControlSet folder.
  4. In the CurrentControlSet folder, double-click the Control folder.
  5. In the Control folder, double-click the Class folder.
  6. In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
  7. In the right pane, click to select the UpperFilters registry value.
  8. Press Del / Delete to remove the registery entry.
  9. In the Confirm Value Delete dialog box, click the Yes button.
  10. In the right pane, click to select the LowerFilters registry value.
  11. Press Del / Delete to remove the registery entry.
  12. In the Confirm Value Delete dialog box, click the Yes button.
  13. close the regedit window.
  14. Restart the computer.
Posted on Feb 11, 2008
  • 244 Answers
it's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
http://support.microsoft.com/kb/314060
Posted on Jul 01, 2008
hardkiss69
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
Thanks
Posted on Sep 18, 2008
  • 1257 Answers
Follow this article to fix the issue.100% Guaranteed
http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/bd9763de-6141-45ea-990b-70c207fe3fb6
Posted on Mar 22, 2009
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Mar 28, 2009 | Acer Aspire 5610-4648 Notebook
from your description, it's windows problem.
You can either reload your operating system or edit the windows registry.
To edit the windows registry follow this step from Microsoft:
Oct 05, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Jul 01, 2008 | Acer Aspire 5610-4648 Notebook
the dvd-rw doesnt work in mi acer aspire 5520-5912
May 18, 2008 | Computers & Internet
Hi How old is this laptop? If it is brand new, then you should be able to send it back to acer. Its the problem with drive or mainboard not with the drivers.
Thanks
Mar 16, 2008 | Acer Aspire 5610-4648 Notebook
Thanks
Feb 22, 2008 | Acer Aspire 5630 Notebook
i believe it's software problem, you can reload the operating system using alt+f10 or you can try this
Feb 16, 2008 | Acer Aspire 5610-4648 Notebook
Feb 11, 2008 | Acer Aspire 5100 Notebook
Jan 20, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5100 Notebook Logo
1,435 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
