Question about Panasonic NV-MD10000 Camcorder
Blue vertical streaks on the recorded picture.
When I point the camera at a light source, I can see blue vertical streaks of light originating from the light source that move downwards.
This is present on the LCD, EVF and the recorded picture.
I have replaced the CCD unit but the problem is still there.
Any ideas what could be causing this ?
Please help.
  • Kanishka Feb 12, 2008
    Forgot to mention the model.  It's a Panasonic NV-MD10000.
    Master:
  • 383 Answers
Is it a lens flare .... I can only confirm after seeing the video....
Posted on Oct 09, 2008
Nikon coolpix s710 pictures have a streak
I think your picture has a bright light source in the frame. In digital cameras this phenomenon is common that in some angle these streaks of lines are produced with very bright light sources. be careful not to include bright light source while taking pics. But if u have these streaks and line in all the frames, then better check your camera with the service centre.
Aug 22, 2014 | Nikon COOLPIX Cameras
COOLPIX S570 Digital Camera: When recording a video, any bright light source in...
Some cameras do that. Most of the time, the streaks don't appear on the picture.
May 07, 2010 | Nikon COOLPIX S570 Digital Camera
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Powershot A75 with pink/blue streaks
I have similar problem.highlights overexposed,with streaks of pixels running vertically.overall pinkish hue
Sep 07, 2008 | Canon PowerShot A75 Digital Camera
Blue vertical line on the LCD/EVF/Tape
If this camera is 4-5 years old or more, you need to replace its Capacitors, may be all Elecrolytic Capacitors.
Jul 31, 2008 | Panasonic NV-MD10000 Camcorder
Hitachi rear proj TV, light blue vertical streak center screen, moves slowly
Sounds like a source problem. What happens when you play
a DVD or some other source??
Need more info? Always give Model # and age----T.
Nov 03, 2007 | Televison & Video
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Blue bars on lcd
I had the same problem with my camera i hit to the Camera body down side and its working now.
Apr 12, 2007 | Panasonic PV-GS29 Mini DV Digital...
PV-GS9 mini dv playback problem
I covered several threads that recommended buying a Mini DV cleaner and running it up to 4 times. They also suggested to change to change your video tape as it may have been the cause of the original problem.
These solutions may have worked for many but not me. My camera was becoming progressively worse. It went to blue bars and no sound to no picture at all...just blue. After using a cleaner 4 times I became frustrated to the point I was going to buy a new camera.
However, with the camera still playing, I did the typical guy thing and rolled up my fist and gave it a good hit along side of it. Remarkably it went back to just the blue bars. I hit it again and it went back to a perfect picture. I'm not saying this will work for you and hitting it too hard could make things worse but I was at a point where I didn't care any more and took a chance that paid off.
Dec 30, 2006 | Panasonic Palmcorder PV-GS9 Mini DV...
Panasonic NV-MD10000 Camcorder Logo
141 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
