Passing PCL code from Word document
pls let me know how to pass PCL commands from word document....
I am trying to print word document to printer and printer is having images stored inside it as a fonts...
Thanks
Mangesh
  • xlsia3 May 11, 2010
    get version of word/give a descriptive as to what exactly are you trying to do
    Sniper:
  • 146 Answers
All PCL Command Sequences begin with the escape character (an ASCII control code with a hex value of 1Bh, 27 decimal) and end with the first upper case letter (or "=" note: "@" is considered an uppercase letter). In between there is either nothing (the PCL command is just the escape and a single upper case letter) or a set of one or two characters and often a numerical value. The single character commands are listed at the end of the "Decoded PCL commands" table below. The first non-uppercase character after the escape will be a symbol between "!" and "\" (most commonly one of %,&,( or *) which is called the "parameter." After the parameter there is normally a lower case letter called the "group." After this there may be a numeric value. If no value is present, the value is assumed to be zero. Finally the ending uppercase letter is called the "command." See Examples, Tutorials below for some samples of PCL commands and the Decoded commands List for detailed information. Note that these use the text "Ec" to mean the escape character. Since the escape character is not printable, it is very hard to convey in human readable text. Common abreviations are Esc, Ec, [], or <-. See the ASCII page for more information on the codes. That page also allows you to convert between hex, decimal or ASCII codes. The form below can be used to find english descriptions of PCL commands. Just paste the PCL into the box, if you use "Ec" or "esc" to mean the escape character, press the "Ec and esc
i hope this will work for you
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
&%STH
Posted on Aug 25, 2008
Whenever I try to print something from my laptop, it says the printer is in error
Let Me Know ur operating system
and next type services.msc in run command check the right pane whether the print spooler sevice is running or not if not pls right click on it and start the service
for more clarity pls call me on +919347143100
thank you
X VIRUS LAB
83bdc5de-5bc2-4c73-95e1-9b3c77ec6895.jpg fc46ea48-7ba7-4ea3-bc2c-7f413b8eb600.jpg 10693748-992f-4cb3-a29f-51bbe0a88829.jpg
Apr 07, 2014 | Samsung SCX-6x45 Series PCL 6
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
HP L7680 Error
GOOGLE IS YOUR FRIEND IN SUCH CASES :) Excuse Caps. Your Drivers need updating, but you are seriously hampered because all support for XP ended ages ago. Why are you still running Windows XP leaving your computers open to security breaches? You should be on Windows 8 Pro at the least or Windows 10. What I would do is go to the HP Website and download and install the drivers and software again.
Search Results PCL XL Error. The PCL XL error is most commonly associated with HP LaserJet printers. The error occurs when several pages are sent from a document to the printer's print queue. ... HP has identified the problem printer drivers for most of their printers that display the PCL XL error.Mar 11, 2016
PCL XL Error - The Tech-FAQ
www.tech-faq.com/pcl-xl-error.html Feedback
About this result
How to Fix PCL XL Error ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-pcl-xl-error Mar 31, 2015 - When attempting to print certain documents on a Hewlett-Packard LaserJet all-in-one printer, you might sometimes end up with a piece of paper with a "PCL XL" error code printed on it. This is due to the printer's inability to process certain parts of the document, such as embedded fonts or images.
Solved: PCL XL Error and other weirdness - Customer Support Forum
forum.support.xerox.com/t5/Printing/PCL-XL-Error-and-other-weirdness/td.../164 Sep 17, 2010 - 10 posts
Hi all,. We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 ...
PCL XL error in printer - Microsoft Community
https://answers.microsoft.com/.../pcl-xl-error.../124223ac-bd82-4758-8d7f-7efe95a04... Nov 11, 2013 - I have a HP LaserJet 4250 PCL6. I was trying to print and all of a sudden I am getting an error message. ... c:\ windows\system32\spool\printer\X64\3 rename the file relating to your printer with the .gpd extension - call it anything you wish and then reboot your pc and it re-creates ... PCL XL error: IllegalOperatorSequence
3 Dec 2016
PCL XL error - Subsystem: IMAGE - Error: IllegalAttributeValue ...
13 Jul 2016
Getting PCL XL error when trying to print.
30 Dec 2012
When trying to print, get a page that has message PCL XL Error ...
28 Dec 2012
More results from answers.microsoft.com
Troubleshooting: PCL XL Error - Customer Support
https://stamps.custhelp.com/app/answers/detail/a.../troubleshooting%3A-pcl-xl-error Next, you will need to install the "PCL" or "PCL 5" version of your printer's driver. This driver should already be available on your computer or the CD that came with your printer. It can also be downloaded from the HP website.
www.tech-faq.com/pcl-xl-error.html Rating: 4 - ‎4 votes
Mar 11, 2016 - The PCL XL error is most commonly associated with HP LaserJet printers. The error occurs when several pages are sent from a document to ...
PCL XL error Google Search
Jul 25, 2017 | Office Equipment & Supplies
Hi there. I have an on-going issue with this printer. I'm using Windows XP, sp2 on a Mac Pro. While printing I get these error messages on a regular basis: Error: undefined Offending Command: (what...
sounds like it's trying to send pcl code to the printer and can't read it, need make and model of printer
and what is the print file your trying to send, does it only happen on this type of print file?
Apr 27, 2011 | Office Equipment & Supplies
Control panel displays: "!Print Cartridge. Refer to printer documentation" What does this mean as device does not resposnd to any command whether through computer or on the control panel
Hi iam gaurav patil Control panel displays: "!Print Cartridge. Refer to printer documentation" What does this mean as device does not resposnd to any command whether through computer or on the control panel 2 day i refil my cartridge then also i cant print my docs pls solve my problem
Aug 31, 2010 | HP Photosmart C5280 Printer
PCL XL error Error: InsufficientMemory Operator: EndPage Position: 152856
Add more memory into your PCL printer -- each printed page is produced by your printer processing the PCL (Printer Command Language) commands. The page that you are trying to print is "too-complicated" for the printer to generate, giving the limited amount of RAM currently installed in the printer.
Or, reduce the complexity of the page that you're trying to print.
Aug 04, 2010 | Computers & Internet
HP LaserJet 2015 printer series - PCL XL ERROR is reported during printing
First Solution :
1. Disconnect the Power Cor from back of Printer ( while printer is has power )
2. Wait for 10 seconds
3. While holding Power Button, Connect the Power cord and release the power button
2nd Solution :
This issue can be fixed by enabling the following option in Printer Preferences . To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet 2015 PCL, and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Jun 18, 2010 | HP LaserJet P2015 Printer
Phaser 3200 only printing code, not actual document
Try downloading and installing a PCL language driver from the Xerox.com site for the phaser 3200. It looks like that could be a PostScript issue. Installing the right driver is very important anyway. If that does not help, try and copy paste the document in a new document and save first as the old document could be corrupted. If this does not help either lemme know and I think of something else.
Nov 11, 2008 | Xerox Phaser 3200MFP/N Laser Printer
PCL XL error
It is a driver error, try another printer driver version or use PCL 5 rather then PCL 6 driver,
Check your USB cable it must be HighSpeed or USB 2 cable.
Jul 28, 2008 | HP LaserJet 3050 All-In-One Printer
Computers & Internet Logo
1,108 people viewed this question
Alun Cox
David Payne
David Payne
