Question about Compaq Presario 5000 PC Desktop
Change cd\dvd drive
I want to change my cd drive . but how can i remove the front panal
    Problem Solver:
  • 7 Answers
mostly it is only snap on in the front. try to start pulling softly at th lower edges....
sometimes the frontframe is screwed from the inside, before start pulling take a look...
mfg
Posted on Feb 12, 2008
Can't get DVD ffrom computer drive
Let's start with the obvious...Did you press the eject/ pull-in button on the drive when the computer was on? Do you have power to the drive when the computer is on (does the light on the front of the drive light up when you first boot up your computer?) Is the front of the drive flush against the computer and not sticking out a little? If the answers to all of the questions is yes, then you have a jammed drive. By the way, does it make any noises when you first turn on the computer or does the light on t only flash with no noises? If you have confirmed everything, now is time to get messy! Turn off the power to your computer and pull off the panal that exposes the motherboard and all of the devices inside. Take the connectors off the drive in question and unscrew the mounting screws. Slide the drive out and put it on the desk or table. Manually pull out the drawer where the CD is and take it out....buy a NEW drive and toss the old one!
Jan 02, 2013 | Computers & Internet
How do I get the cd/dvd player into the slots that are blocked
The plastic front panel will have removeable plastic panels the size of the CD/DVD drive, these are held in place by clips, you can push the panel out.
You can also remove plastic front panel, it may be secured by screws or plastic clips. When you remove the plastic front panel the CD/DVD drive slot may be covered with a metal plate, you can remove this plate by bending the metal plate back and forth until it breaks away from the drive bay.
Jan 22, 2012 | XION (XON-001) ATX Mid-Tower Case
I have a gateway 506gr desktop that wont turn on that i am trying to get on and i have replaced the motherboard to fix this issue with no luck. when i plug in the power supply nothing happens and when i...
Most of the times replacing the faulty capacitors works without any issues (provided that the capacitors have been changed properly)
As for new motherboard, I suggest that you try to boot up the PC with minimum components. First, remove the components such as hard disk, CD/DVD ROM, Graphic card, RAM(s), keyboard, mouse etc. Add 1 RAM, connect VGA cable/ display, modem, mouse and keyboard and Reconnect the power supply (24 Pin as well as 4 pin connectors, Processor Fan and observe if it works. The motherboard LED should lit up and steady. If you suspect that the power switch could be the cause, you can remove the front panel connectors (of power switch, power LED, HDD LED etc). Now, to boot up the PC, you have to short the POWER SWITCH Jumpers/ connectors with a screw driver. (PWR_SW). This step would clarify the functioning of the switch. Also, BIOS cell could be dead and may need replacement. Check the existing RAM on some other PC. Try to replace the RAM and see if it works.
Gateway Computer User Guide
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 29, 2011 | Gateway 506GR PC Desktop
How do I use a 7 disk duplicator tower? Model 52X65x52x
Hi you put your dvd or cd into the top copier,put however many blanks you want copied into the burners below, you dont have to use all 7 if you dont want to make sure the control panal on the front says copy press enter and thats it.
Jan 24, 2011 | Tower CD&DVD Duplicator Cases: 8 Bays...
I have an Acer Veritron and CD/DVD stuck. I looked for the tiny hole on the front of the CD drive and there is none. I attempted to go to my computer and right click drive and it is hanging.
I fyou know how to, try and remove the cd/dvd drive itself from the tower. check if there is anything stuck, and gently press the cd/ dvd drive in opposite directions. also check the cable thats powering the drive. reseat it properly.
Apr 03, 2010 | Acer (91.49C37.001) CD-ROM Drive
Need to replace cd-rom drive, how difficult? dell dimension 3000 pc desktop
It is not difficult to change cd/dvd drive.
Open cpu cabinet.
Then remove icd cable and power cable from cd/dvd drive.
Then remove screws of old cd/dvd drive.
Then you can pull it from cabinet from front side.
Then put your new cd/dvd drive into it's position then lock it with screws.
Then connect ide cable from motherboard and power cable to drive.
Then you can use it.
If you connect to drive with 1 ide cable means if you connect harddrive and cd/dvd drive with 1 cable then set harddrive as master and cd/dvd rom as slave you can set it slave with jumper settings.
It is in back side of cd/dvd drive.
There is instruction how to slave it with jumper.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 17, 2010 | Dell Dimension 3000 PC Desktop
Windows media player cannot detect my dvds in the dvd rom player. i have windows vista
Open "My Computer".
Insert a CD-disk into the drive, while holding-down the LEFT-SHIFT key.
Does the label under the CD-icon change?
Remove the CD-disk.
Insert a DVD-disk into the drive, while holding-down the LEFT-SHIFT key.
Remove the DVD-disk.
If no changes in the icon, after the above, it's time to spend $40 to replace the "dead" drive with a new CD/DVD writer.
Jan 09, 2010 | Dell Inspiron 530 -Intel® Pentium®...
Remove he dvd drive from Packard Bell computer
Remove both left and right panals on the tower. Disconnect the IDE ribbon cable and power from back of the cd drive. There also may be a small wire that connects ether to the sound card or motherboard also. Remove all screws from the right and left side of the device. Push the drive out the front.
Jan 19, 2009 | Packard Bell Computers & Internet
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
