Question about Smeg SE250XUK Stainless Steel Electric Single Oven
Oven not working
Hi my oven isn't working.
The light comes on but the fan and light on the thermostat doesnt come on. T here is no heat. Suggests that there is electricity to the oven but something isn't right. I have had a check of the main electricity switch as I had a power cut a few days ago but its on and looks fine. Can you let me know if there is something else that may be wrong before I have to call in an electrician?
Thanks ND
  • Wilana Feb 22, 2008
    I have an SA9065 gas double oven and the lights, fan and conventional oven work but the fan forced doesn't work (i.e. there is no heat). Could you give me some advice on what could be the problem.
    Thanks
    Wilana
  • jez_cath Jun 30, 2008
    have the same oven, but no heat... fan and lights work
    President:
  • 1,462 Answers
For darnos
have you reset the clock? this needs doing after you lost power. i suspect you have it on auto
for jez-cath and wilana
in both cases, probably the fan element at fault.
Posted on Oct 18, 2008
My problem was a bit different to yours.. the light and fan were functioning, but there was no heat. It turned out that BOTH elements had blown and had to be replaced. (expensive exercise and the stove was only 4 years old at the time). I would recommend NOT operating these ovens on a very high heat to get a reasonable life out of the elements.
Posted on Oct 19, 2008
Model SA392EB
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 15, 2013 | Smeg Ovens
Smeg oven UK80MFX1 troubleshooting
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Nov 30, 2011 | Smeg Ovens
Hi smeg se210x/1 doesnt want to heat up to a decent temperature?
May 30, 2011 | Smeg SE210X/1 Stainless Steel Electric...
Hi, we have a se280x oven and its about 4-5 years old and inherited this when we moved in 2 years ago. But the oven seems to heat sometimes or not constantly and especially seems like e the upper and...
Apr 15, 2011 | Smeg SE280X Stainless Steel Electric...
I have a Tecnik TKC 8522 double oven - I can't get the bottom oven to heat up. When you turn it on the fan comes on, but the red light doesn't come on and the oven doesn't heat up.
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
Sep 25, 2010 | Tecnik TKC8522 Electric Double Oven
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Smeg SE250XUK Stainless Steel Electric Single Oven Logo
477 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
