Question about Uniden Cordless Phone
Handset won't registger
My GE 25802DE3-A cordless handset won't register. The base unit doesn't beep after I press and hold the page button. How can I register my handset when this happens?
  • 1 more comment
  • kathu Feb 15, 2008
    handset needs registrtion ho do you do this
  • Deadphone Feb 19, 2008
    My phone was working, had to unplug it and now it would register???? HELP.nothing works, nor do the directions in the manual
  • Anonymous Mar 01, 2008
    Same thing - keep hitting the button to get it to register and it won't do it... Now we have no phones!!!!!!
Called the customer service line a few mins ago. Here are the steps the guy told me to do:
1. Unplug the AC adapter
2. Unplug the phone jack
3. Take the battery out of the phone
4. Wait 15 minutes
5. Put everything back together in reverse order (battery, phone jack, adapter) and it should work as directed. If you have the additional phones like we do and those don't register right away, just take the battery pack out and put it back in.
Posted on Mar 01, 2008
JJschuhman
WOW!!! Thanks I did it, and I just registered the phone and it is working!!!
The only step is
6. You need to fully recharge the phone for the 16 hours and then register it.
I am using the phone as we speak
thanks again for the posting
Posted on Mar 02, 2008
Ok so i followed all the steps it doest work, does that mean i have to charge it for 16 hours to try again.. where do i keep the handset when i press ti register, close to the main base or wht
Posted on Mar 23, 2008
I have a GE model 2810GE AND THE screen say's HAND SET NEEDS REGESTRATION. WHAT SHOULD I DO ? CHARLES
This is from the instructions at GE's site for the model 28110 (you said 2810, which isn't found):
  1. Press the mute/program button. Hold BASE PAGE for 5 seconds, then PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.)
  2. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number
Hope this helps. Thanks for using Fixya!
Feb 11, 2010 | Uniden Cordless Phone
No link to base
This may help. It's from the Panasonic help page:
You may try to:
Disconnect AC power adapter from the back/bottom of base unit, then connect it again properly.
spacer.gif OR, to resolve this issue, you have to re-register the handset.
  • To do this on a non-expandable cordless phone:
    Press and hold the LOCATOR/INTERCOM button on the Base until a beep sounds.
    Press and hold the FLASH/CALL WAIT button on the Handset until a beep is heard.
    When registration is complete, a beep sounds from the handset.
    Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
    If this fails to help:
    Remove the AC Adapter from the phone base or wall outlet for a few seconds and reconnect. It may also be necessary to remove the battery from the handset for a brief moment.
  • To do this on a expandable cordless phone system:
    Press and hold the LOCATOR/INTERCOM button for the extension that is displaying "No Link To Base" on the Base until a beep sounds.
    Press and hold the FLASH/CALL WAIT button on the Handset that is displaying "No Link To Base" until a beep is heard.
    Remove the AC Adapter from the base or wall outlet for a few seconds and reconnect. It may also be necessary to remove the battery from the handset for a brief moment.
Jun 24, 2009 | Panasonic KXTG5632BP Twin Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
Tesco arc200
I solved it out u must pres de paging button on the base while registering the phone to base keep the paging button pressed until starts to beep like 5-10 sec. Good Luck
May 16, 2008 | Uniden Cordless Phone
Cordless phone EnGenius SN 920
. A new handset arrives with a handset ID number of 00, to register this handset to your system take the following steps:
  1. On the EnGenius base unit press and hold down both the "Volume" & "Intercom" buttons for about five seconds. You will hear a beep from the base unit. You can now release the two buttons.
  2. On the EnGenius handset (00), press the following buttons: "menu", "6", "1".
  3. A new handset ID number (ie: 12, 13, 14…) is automatically assigned by the base and registration is complete.
Feb 29, 2008 | EnGenius SN 920 Ultra Cordless Phone
Unable to register, not asking for password
See below for complete instructions but think you have missed out part 2......
Reregister the handset or add additional handsets.
1. Remove all handsets form charging or Main base unit.
2. On on Main base unit, press and hold Page button for 10 seconds until beep. ( Not paging beep )
3. On 'unregistered' handset press and hold Redial & Calls buttons ( Top left and top right ) until 'bs-' appears.
4. Enter handset number ( eg: bs-1 ) then the pin number( could be 0000 but check your manual ).
Cheers
Monty
Feb 16, 2008 | British Telecom Freestyle 2200 Trio...
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
New Expansion Handset refuses to register with the base
If im not misytaking the base has to be set up for another expansion too.
Apr 06, 2006 | Motorola Mobility MD7091 Cordless Phone
Uniden Cordless Phone Logo
336 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
