Question about Brother XL-5130 Mechanical Sewing Machine
Why does thread nest form?
When I start to sew, why does a thread nest form, it gets so tangled, that I have to remove the material, and cut off the thread. It is very fustrating. Please let me know what I am doing wrong. thank you
  • hleipfert Oct 09, 2008
    I started out just fine, but after a 5 min break I went back to my machine and continued to sew. when i started on the 2nd piece the thread got all bunched up and tangled around the bobbin case. What do I do? How do I get it to stop doing that. My machine is brand new first time using it when this happened.
    Help Me.
  • Brother Master
  • 1,388 Answers
To read about the reasons and solutions to this looping on the underside...........start here.........and as allmakes says, ensure correct threading through tension dial.
Posted on Feb 17, 2008
Bobbin thread keeps getting caught up when i begin to sew about 4 stitches in.
bird nesting is the result of incorrect needle thread tension
adjust the tension tighter
Oct 25, 2017 | Sewing Machines
Thread keeps tangling on underside
Called thread nesting or bird nesting.
Install a brand new needle that is compatible with the thread and fabric you are using.
Remove the top thread totally from the machine.
ALWAYS RAISE the presser foot and rethread the top thread from the beginning.
Confirm the thread path is correct.
Retest your machine.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Jul 23, 2017 | Sewing Machines
Singer touch ironic 2005 getting a huge tangle of thread on the bottom as I am sewing. This is not resolved by removing and replacing the bobbin.
Usually, a thread nest or bird nest, is a result of an upper thread issue: misthreading, thread not seated in the tension disk, upper tension too loose. Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point between high & low number. Then retest.
Jan 09, 2017 | Singer Sewing Machines
Fashion Mate 248. The top stitch is fine but will gather too much under the material. Wraps around the bobbin holder and tangle up into the bobbin thread. Does anybody know whats going on?
That is what is referred to as bird nesting or thread nesting. It usually results from mis-threading, the thread not being fully seated in the tension disk, or the tension set too loose. (I have a machine that does this frequently because the thread "jumps" out of the take up lever when sewing fast--instant thread mess.)
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Make sure the thread path is correct. Set the upper tension to the midway point between high & low number. (You will probably need to tweak the upper tension because every machine differs over time, but the midway point is the factory standard setting.)
While you are at it, check to make sure the bobbin is loaded and threaded correctly in the bobbin case.
If you continue to have issues, you may need to take it for service.
Sewing Machine Thread Bunching Up Here Why
Dec 10, 2016 | Sewing Machines
Having trouble with tension on my Husqvarna Viking E 20
Be sure to RAISE the presser foot BEFORE threading the upper thread. (Remove the upper thread and rethread from the beginning.) Upper thread malfunctions commonly occur if it is not threaded correctly or the thread is not seated in the tension disk properly.
Install a brand new needle if you haven't already done so.
If it continues, this information about bird nesting could be helpful:
Why Do Get Bunched Up Thread Under My Fabric
8 Tips to Fix Birdnesting in Embroidery
Why Is the Thread Getting Tangled Up Under My Material When Use My Sewing...
Jan 22, 2016 | Husqvarna Sewing Machines
Thread tangling inside bobbin case catching on another part
1. thread machine correctly.
2. make sure bobbin case in spinning in the case in the correct rotation. If the bobbin is spinning off of the bobbin incorrectly, "bird nesting" is the result.
Jul 20, 2014 | Brother NX-400
Bobbin Issues
On the bobbin holder, there is a tiny adjuster you should be able to undo or do up with fingernail or small screwdriver cotton should be firm when pulled by hand not to loose or not to tight.
Oct 19, 2017 | Sewing Machines
Needle sticks on sewing machine and motor won't move it forward
Copy & paste into your browser: http://fixsewingmachine.com You need the free diagrams & details provided on their web site. Jimmy
Apr 05, 2012 | Montgomery Ward Sewing Machines
Thread breaks
Hi!
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Thanks
    Rylee
    Jan 30, 2009 | Husqvarna Viking 1
    Brother XL-5130 Mechanical Sewing Machine Logo
    347 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
