Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Adjust Picture on Rca Projection TV
My top picture on my tv is concaved. There are no picture controls to adjust does anyone have an idea how to resolve it?
I have the same problem also. The peoples heads are cut off! Need help on what to do.
  • 44 Answers
Check the horizontal frequency and the electrolytic filters used in it. damm sure there must be filter that make it look like a concave. also check it by decreasing the width from the service mannual of processor. there is a service switch for every processor. that is his internal control unit. may be it is from the processor adjustment. you can set it by increasing or decreasing the frequency or display width-height clock pulse from the processor. to know about that perticular switch you must concern to the company....
Posted on Feb 12, 2008
I was given a P52960 ,2002 rca 52 projection tv and the sides of the piture are concaved in.Can this be fixed easy enough,i am good with electronics/wireing..iI was told by the old owner that the solu
concave or bloated pictures on crt projection tv's are corrected with what's called a 'pincushion' adjustment. Look for it in the menu under video controls.
Dec 22, 2012 | RCA P52960 52" Rear Projection Television
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection tv.it started of with just a blury spot across the top but after i messed with it the whole...
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
Nov 10, 2009 | Televison & Video
I'm trying to improve the picture- seems to be TOO DARK- tv is 10 yr old ser3 935351541- ihave tried color adj etc
Rca Screen Control These sets have screen control adjustment usually located behind the speaker grill(pops off -velcro or press tabs) and convergence front board. There are 6 contols on a black molded assembly about 31/2"x21/2" square. adjust only the top controls marked "Screen R G B" the bottom ones are focus
Method:
-turn on set and let warm up for 30 min at least
-switch tv to blank unused video input channel
-adjust each control in turn until you see the picture glow (with the corresponding color) and slightly back off the control - repeat for each color - this will increase screen brightness and ballance your color
Hope this helped.
Oct 18, 2009 | RCA P52945 52" Rear Projection Television
My RCA projection TV - the picture only shows red green and yellow and the picture is distorted almost concaved. It overlaps and nothing is clear. All 3 bulbs seem to be working. No idea what is wrong.
Sounds like convergence problems. This TV may not have the standard "STK.." modules. These sets are bad to lose voltage feeding the convergence amplifiers.
Mar 31, 2009 | RCA P52926 52" Rear Projection Television
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
Neon in color
sounds like you might need a good cleaning or your tv has contaminated coolant in the picture tubes. or you just might need to adjust the screen control for the picture tubes.
Feb 20, 2008 | RCA P46924 46" Rear Projection Television
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
Concave picture with rainbow effect at the edges
Hello, Check and replace IC1606 (P/N: 875292571) and IC1608 (P/N: 875982987). Best regards, Arpi http://www.partstore.com/sl/2/418644-ic-cxp86448635q-875292571.html
Apr 23, 2007 | Sony KP-57HW40 57" Rear Projection...
*** I have to configure Colors with each power on. ***
The six controls you appear to be adjusting are the screen and focus controls for each of the three picture tubes. These usually only have to be adjusted as each picture tube ages or when replaced. You may either have a defective "focus block" i.e. the black box you have been adjusting, or the CRT's themselves may be going bad at this age. You will probably be money ahead to just replace the TV with a new HDTV set. At 13 years old, it shouldn't have much life left in it anyhow.
Dec 29, 2006 | RCA P46924 46" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
322 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
