Question about Sony WEGA® KV-BM142M40 14" TV
SONY WEGA SCREEN
I HAVE SPIDER WEBS IN SIDE MY SCREEN. HOWW DO I GET RIDE OF THEM.(REAL SPIDER WEBS)
Thank you for the tip, totally easy. our t.v. looks like brand new.
Posted on Feb 13, 2008
  • 579 Answers
Take the back cover off and vaccum them out, then dust it. If you can take it outside, compressed air does the fastest job of cleaning out dust.
Posted on Feb 12, 2008
Yellow lines at the right upper screen looks like spider webs.
this will be your polarized filters which you cant buy anymore you will have to buy a new engine which depends on the model is between 600-800 unless you can pik up another same model of ebay for parts with a different fault but it is a common fault in these also the lgs
May 07, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Spider webs in tv
Easiest way to deal with this is unplug set and remove the back cover. The area inside is fairly open---with a swiffer type duster reach in carefully and remove all the spider webs. Go easy along the inside of the inner screen so you do not scratch it or damage it.
Let me know if you have questions.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 08, 2009 | Sony KP-51HW40 51" Rear Projection...
Screen is blue and spider-webbed.
It sounds like the Optical Engine is causing the problem. Due to the cost of the part involved, (around $600.00) I would call Sony at 1800-222-SONY and see if they would be willing to help with the repair cost.
I hope this helps,
Skyassoc
Oct 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i clean the inside of my 57" projection tv . this is an hitachi flat screen, i have spider webs inside
without knowing the model number; some you can remove the rear cover and gain access with a swiffer type duster and clean the webs out(also clean the lens at the same time) Others: the only easy way is to remove the screen--not real easy if you have never done it before---most outside service techs will be happy to come to your home and clean the webs out; also clean the lens and the mirror.
Aug 06, 2009 | Hitachi Televison & Video
Spider webs Sony KDF-42WE655
I'm guessing they're inside of the Tv right? well what you could do is buy a can compressed air to remove all the spider webs and dust inside of the Tv :)
Jul 01, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Replace bulb howw?
how to install replacement bulb on kdf50we655?
Apr 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Cob webs
Hi, remove rear top cover, this will give you access to clean the unit, be advised you should use 2 people once you get all the screws out, the back is HEAVY because there is a mirror attatched to the rear cover(on the inside) and if you drop the cover it`s expensive to replace, good luck, BMW Rider
Jan 25, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Dirty screen but it is behind the outside screen.
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Oct 24, 2007 | Hitachi 50UX57B 50" Rear Projection...
Trying To Remove Screen
I have a panasonic 53 inch and have had the same problem on numerous occasions. I removed the backing of the television, stuck my vaccuum cleaner hose inside the tv and sucked out the spider and the web.
Apr 29, 2007 | Toshiba 65H81 65" Rear Projection...
Clean inside of the screen? Spider webs?
You should get the service manual so you dont take apart something you shouldnt
Aug 24, 2006 | Panasonic PT-61HX40 61" Rear Projection...
Sony WEGA® KV-BM142M40 14" TV Logo
159 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
