Zenith R56W36 56 in. Rear Projection Television
Problem for Zenith R56W36 56 in. Rear Projection Television
Convergence problem - NOT STK ICs / resistors
By andiklein on Feb 12, 2008
I really hope someone can help me with this.
Our LG RT-39NZ40RB rear projection TV has massive convergence problems ever since I ran the "Auto Convergence" feature after moving houses. Jumping onto the most obvious solution, I have already replaced both STK392-570 ICs (and checked all feedback resistors), but the problem persists.
What is particularly curious, and I unfortunately didn't notice this until now, is that the menu on-screen display is out of convergence as the rest of the picture when there is an input signal, but when I switch to an input that doesn't actually have a source connected, e.g. AV4 or the Component inputs, the OSD is perfectly crisp with all 3 colors in line. At the same time it does not make any difference whether the input signal is TV via aerial and tuner, an XBOX via Composite cable on AV1-4 or the same console on either of the two Component inputs. If there's a signal, the display is out of match, no signal and all looks fine.
As I said, I wish I had noticed this earlier as it is pretty obvious that the actual convergence mechanism has been working all along or why should the OSD work without input signal.
Now, what else might be the actual cause here?
I sure hope there's an obvious solution to the problem that I can fix with a little more DIY so that the new STKs haven't been a complete waste.
Thanks in advance for any ideas, Andy
Comments:
Feb 12, 2008
- Thanks ini79.
I did an optical check of all electrolytic caps to see if any of them were showing the obvious signs of damage. Nothing there. Unfortunately I don't have the appropriate means, or knowledge as a matter of fact, to follow up on your solution. I'm afraid the problem proves too hard to find for me. Anyone need a Convergence Board for an LG RT-39NZ40RB with two brand new ICs? ; )
Same Problem
Jul 10, 2008
-   Model Number...LG RE 39NZ40RB
I have a similar problem but just the convergence is out no matter what source...Can anyone provide information on how to access the service mode?
Thankyou
Mike-   Guest
Best Solution
posted on Feb 12, 2008
Helpful)
ini79
Rank: Wiz
Rating: 87%, 40 votes
have you check the electrolytic filters. check the video IC. also check the polyster or disk type capacitor, because they hold the frequency. in on screen mode the half of section is dead, but when you applied a signal it start converting it display mode. every signal is extracted from video signal in TV mode. the best way to check all this properly you need a colour pateran generator. when you used it you will find a fault and the area.
best of luck...
Was this helpful?
Yes
No
Solution #2
posted on Jun 20, 2008
Not Rated)
357reaper
Rank: Wiz
Rating: 81%, 42 votes
I NEED THOSE PARTS BAD (607-291-4034) ANYTIME PLS CALL ME ASAP 24/7 ASK FOR CHUCK
OR I CAN CALL YOU FREE LONG DISTANCE.
Was this helpful?
Yes
No
Popular Solutions for Zenith R56W36 56 in. Rear
Questions and Unsolved Problems for Zenith R56W36 56 in. Rear
Do you recommend Zenith R56W36 56 in. Rear Projection Television?
Answer
Answer
TV will not stay on. Red light turns off than comes back on. Redlight on is the off postion
Answer
The picture on my zenith R56W36 tv is blue. Sound is ok
Answer
when i turn my tv on all i have is a black screen and great sound. any solutions?
Answer
i accidentally pushed the auto convergence button and it messed up the picture..it was fine befroe
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , TX
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
