Question about HP Compaq dc5100 PC Desktop
No emulation my buddy tried to re install windows, messed up his machine. I tried to boot from disc but i get no emulation code and it wont go any further
    Novelist:
  • 123 Answers
To recover your data try to start the computer in safe mode.
If this doesn't work try to mount your hard disk on another computer.
Restart the computer and after Bios loads up and press F8.
Then select Safe Mode and press Enter.
Run a virus scan, assuming that you have an Antivirus program installed.
You can find a good free antivirus program here.
Have you recently installed a new program and/or device?
You should uninstall it from Safe mode if so.
Have you used the System Restore option?
Check out the following documents from Microsoft where you can find detailed information about your problem:
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 12, 2008
How to tell if a hard drive needs replacing on a samsung r519
1. If you have blue screen give us the exception code (0x000000) 2. How did you get to this point? 3. What is the condition of you install disk? Windows setup could just be messing up because the windows disk is damaged. Find an OEM copy of windows and set it up to boot from flash drive or external drive (CDs at prone to damage if you want a reliable windows install only use optical media if its in pristine condition.)
Jul 28, 2013 | Samsung R517 R518 R519 R522 Laptop Lcd Led...
I have acer laptop aspire 5736z with windows 7 but i wanted to change the windows xp but it brings the error message (blue screen). it stops installing windows xp. what could be the problem. it boots well...
The problem is your computer uses a SATA hard drive and windows XP doesn't naitively support SATA. You have three options around this.
  1. Go into BIOS and if you have disable SATA/AHCI and set it to SATA/IDE emulation mode
  2. Download nlite http://www.nliteos.com/download.html and download sata drivers from intel's website and build your own windows XP disc and incorporate the sata drivers into it. Then use this disc to install.
  3. Download VirtualBox http://www.virtualbox.org/ and install XP in a virtual machine to run on top of Windows 7
Windows XP will go end-of-life in 2014 and then Microsoft will no longer make software that is compatible FYI.
Comment if you need any additional assistance.
Sep 18, 2011 | Acer Computers & Internet
My ******* computer wont load windows 7
Hi jeff,
What error do you get when trying to install win7?
Have you tried booting from the disc by going to the boot menu to select the dvd/cdrom to directly boot from the Disc of win7 instead of installing form within another orpeating system.
mvincentc
May 15, 2011 | E-Machines T5082 PC Desktop
Acer Power SV, I need to reformat but no Wn Xp disc
buddy you have to need xp window cd you can buy it or take from your freind without xp window cd you cannot install window.
Oct 20, 2009 | AcerPower SV PC Desktop
Computer wont boot
You will have to repair this file using bootable Windows Xp cd.
This problem will be solve.
Insert bootable Windows Xp cd and then press any key for boot.
When option appear for repair and write there Repair=R then you should press ' r ' and then you should follow the instructions.
Good Luck
Sep 24, 2009 | E-Machines eMachines T3830 PC Desktop
Computer wont start up fully
Your boot menu for Windows is corrupt. Try to boot from the windows installation disc and make sure to key any key when told to boot off the disc. Once the windows files load, you will have a choice of what to do next. If you have XP, choose the repair option and you will be faced with a black DOS screen...after the blinking cursor type
FIXBOOT hit enter
Try to boot the computer without the disc in it. If it does not boot, then boot off disc again and this time type:
FIXMBR hit yes and enter
Try once again to boot without the disc.
Also try to boot into safe mode by tapping F8 when you see the Compaq name come up during starting. If you can get to the multiple boot up option screen, scroll to "Safe mode with networking" and choose that. If it boots then you can go to the start button > accessories > system tools > system restore > choose a restore point back a day or two and follow the prompts.
If you have Vista, boot off the disc and choose start up repair. If that doesn't work, boot again and choose restore computer to an earlier time. Again choose a restore point back a few days. Good luck ParrotHead PC Repair
Sep 06, 2009 | Compaq Evo N610C Notebook
Intel Macbook Flashing Folder, wont boot DVD
Hi yeddi,333,
You say you originally booted into what you assumed was the install screen and tried to install from disks - then you later mention borrowed 10.5 disks - - was this one set of disks or two?
Unless those install disks (esp. the 10.5 disks) were for that version of MacBook, they likely won't work - different chip-sets from MacBookPro, iMac, etc. You'll need to either get the right recovery disks, or find someone who is able to re-image your computer via Target Disk Mode or using NetRestore, or some similar software product. If you don't have these resources, it's likely fastest/easiest to get the right install/recovery disks from Apple - - since they already sold the OS with that computer, you can maybe get a recovery done by them - - I'd call and ask.
Also - - does this MacBook have AppleCare (3 year extended warranty) - - if so, see if you can exercise that for actual hands-on assistance.
I'd also be sure that the hard drive was properly replaced and is actually working - - why was it replaced originally?
You're probably going to need to contact Apple for some assistance - go to this site to schedule phone support.
http://www.apple.com/support/expert/
or go into your nearest Apple store and show it to one of the "geniuses" at their tech support desk.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Feb 21, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Cd rom message "no emulation" when booting the windows xp installer
when i install my windows xp professional i get a message prompting BOOT TO ATAPI CD-ROM: "NO EMULATION".... how can i fix this?Pls help me on this
Jun 07, 2008 | ASUS P4SP-MX Motherboard
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
HP Compaq dc5100 PC Desktop Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
