The burners on my GE Gas Stove will not light automaticlly also when you turn them on the ignitors don't click. This happen after I used my self- cleaning for the first time and I stopped the cleaning process half way through I don't know if that has anything to do with the burners but please help
my burners will not spark fire. i have the spectra xl44 stove
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak. You can look at it and see how it compares to the broil ignitor. If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
SOURCE: GE XL44 Gas Stove
This Randy again. I checked out the top of the stove as you suggested and found every thing to be ok. Where might the pilot light be located on this ge xl44? this unit is about 13 to14 years old.
Thanks for your help
Randy
SOURCE: Bake ignitor Location
Hi Kurt, welcome to FixYA!
In the diagram below, Part #28 is your ovwn ignitor. (See the red markings to highlight it)
It is located underneath the oven floor, and the floor should come out by removing the two screws located in the bottom rear of the oven cavity. Take out the racks, take out those two screws, and lift the oven bottom up from the rear, then disengage the front lip and lift it out. I hope this is helpful info and thanks for allowing us to be of service to you.
to you.
SOURCE: I have two burners that don't ignite
FIRST MAKE SURE YOU TURN OFF THE GAS AT THE MAINS , THEN REMOVE THE ALL BUNERS AND GIVE THE TOP PORTION A GOOD CLEAN WITH WARM SOAPY WATER TO EXPOSE THE SCREWS WHEN LOCATED REMOVE THEM AND THE TOP THEN YOU NEED TO FIND THE IGNITE WIRE FOLLOW IT TO ITS SOURCE CHECKING FOR ANY BREAKS AND ALSO CHECK CONNECTIONS . GOOD LUCK .
Testimonial: "Thanks so much, but now I'm a little scared, plus i don't know where the gas valve is. i think i will have to call a repair man."
SOURCE: How do I replace the ignitor for the stove top of
if you need a part check out www.appliancepartssolutions.com cheep parts ;)
good luck
Same problem, two burners won't light anymore.
same problem here
Burners will sometimes not light on the GE Gas Stove XL44. Will click maybe once and not light the burner. One time the right side would light, but the left would not.
Afre my husband cleaned the stove by lifting the top up he knocked something off (he doesn't remeber what) now I have to light it and the oven with a lighter.
I have a simular problem with the same GE stove Three burners work but the 4th doesn't make the clikking sound. I can llight it with a lighter though.
I have a ge xl44 gas stove, I was cleaning the top and got cleaner inside the unit, now it won't light. I have tried to get the top open, but can't figure it out. What's the trick?
