Question about Microsoft Windows 2000 Professional for PC
My systam using 256 mb ram for very slo that my worktime for enkerase
  • 51 Answers
Upgrade to a minimum of 512 mb ram for optimal performance.if you still want to use only 256 mb then reduce the number of applications which boot up on start up
Posted on Feb 12, 2008
Hi, I want to upgrade my RAM from 256 MB 400MHz DDR1 (hynix) to 1GB DDR1. Do the both will work together or i would have to use 1GB alone? Im having ASUS K8V- VM motherboard. Will it be compatible with...
It will be compatible but it is recommended, you use same type of modules(RAM)
ie 256 MB + 256 MB
1GB + 1GB
Plus the advantage of using two instead of one(If you want 2GB, go for 1-1Gb two modules, depends on you) are, if one fails other works.
Apr 24, 2011 | Computers & Internet
My system has a ddr 256 MB but it shows 192 mb only. what is the reason and solution plz
Your graphics card is sharing your system memory.
This means that you physically have 256 MB of Ram in you laptop, but the operating system can only use 192 MB of Ram because 64MB of Ram is dedicated to your on-board graphics.
Hope this answers your question!
Please remember to let me know if this information was useful!
Kind Regards
Dec 06, 2010 | Intel Motherboard
Ram 256 MB but show 128 MB pls send solution
If you have an existing 128Mb RAM module and inserted another 128Mb to give you a total of 256Mb and it stills shows 128Mb. Then the second RAM module may not be compatible or the second RAM module is faulty.
Try and use the same make and type RAM module as the original or insert a 512Mb RAM module instead of two 128Mb RAM modules. There is not much price gap between 512 and 256 Mb RAM.
Nov 01, 2010 | Intel D845GLLY Motherboard
I have Toshiba PSA10L-024F3P laptop with 256 mb ram. Can i add one more 256 MB ram to it
Yes, provided the 2nd RAM slot is empty. try to use the same make and model RAM that is already installed in your Toshiba.
Jun 16, 2010 | Toshiba Computers & Internet
After adding 256 MB with existing 256 MB showing only 256 MB in BIOS instead of 512 MB
The problem could be One of the 256MB RAM is not deatected as not inserted properly or due to malfunction.
Download this small application.
Here is the link
http://www.cpuid.com/download/cpuz/cpuz_153_setup.exe
Download this application and run (you don't need to install this software).
Check in which SLOT your RAM is Working using the above application.
Try to insert it properly again.You can also try by interchanging The RAM, yso that you can pin point whihc of the RAM is malfunctioning in case of MALFUNCTION.
Rate this Solution.
Jan 07, 2010 | IBM ThinkPad T30 2366 Notebook
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Cannot install 6940 driver
this is straight from hp
64 MB RAM for basic software installation (256 MB RAM for full software installation), 200 MB available hard disk space for basic software installation (450 MB for full software installation)
unless you get another 256mb memory it would be best for you to do basic installation.
Mark
Apr 21, 2009 | HP Deskjet 6940 InkJet Printer
Microsoft Windows 2000 Professional for PC Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
