Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby vacuum I have a G 6 kirby vacuum. The power cord has been checked and has continutity and replaced the power switch and the vacuum will still not run
    President:
  • 1,673 Answers
There are 2 safety switchs, one on the front that the nozzle activates, and one on the side that the bag asembly activates. The motor brushes and/or armature maybe bad.
Posted on Feb 12, 2008
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Kirby G6 - won't power on
Check the cords two wires with an OHM meter for continuity replace if you get a reading showing OL The ground wire you can forget about this test
If any sort of numbers appear in the meters display the cord is good
Replace the switch instead
Jul 10, 2010 | Kirby G6 Bagged Upright Vacuum
The kirby wont start no power
Start by checking to insure you're getting proper voltage through the cord. Make sure the bag emptor and front brush roll nozzle are installed properly as each must activate the switch for it to run. It could have a defective switch.
Jun 20, 2010 | Kirby G6 Bagged Upright Vacuum
I need to replace power supply. where the cord
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
Mar 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Kirby will not turn on
For the kirby to run all the switches need to be in contact. First check the brush head and make sure its attached properly, then check the plastic piece on the bottom of the bag (called the mini emptor) it should be all the way against the body of the vacuum. if all that is good check the cord where it runs up the handle and connects to the swiveling strain relief at the top... usually those cords go bad right there. If the cord is good, you probably need a new switch but before you spend the money on that expensive genuine kirby switch check the motor carbon brushes and the commotator on the armature where the brushes make contact.
Jan 02, 2010 | Kirby Generation 3 Bagged Upright Vacuum
No power from Kirby!!
Determine if the headlight works before anything else. If the light works but the motor won't you have power thru the vac and the problem is internal possibly motor brushes... or a loose wire on the inside connecting to the switch.
If the light goes out is likely a switch or cord problem. Switches on these vacs break more often than cords. What you see on top is the switch button, not the actually internal switch, however a switch does not normally fail while the vac is running, that sounds more like a loose connection or a bad cord.
So isolate the cord. Unplug it at both ends and plug lamp ( or test meter) into the cord into the cord and gently wiggle where the plug end meets the cord. If the lamp goes on and off the issue is the cord. You can buy a replacement specific to the Kirby series and plug it in yourself. If this s does not isolate the problem, take it to a service center. Kirby is very intricate inside.
Sep 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Our G3 Kirby will not power up?
Either the cord or the switch is bad. The cord is simple. Take the tab screw on the back of the machine off and the screw holing the cord cover off. Pop off the cord cover un-plug and remove then reverse steps to replace. If it is the switch that is better left to proffesionals so call your local vacuum shop.
Apr 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Vacuum stopped working
Sometimes after years of use the power cord can break internally where you won't see it. Look for damage or twists in the cord. With the vacuum turned on wiggle these areas between your hands and see if it tries to run. If so replace the cord. If not the switch may be bad or the motor needs to be serviced. Good luck. Please rate me so I know if I helped.
Dec 30, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 vacuum
check the cord. see if there are any frays. or broken spots. usually it is one of 3 things. 1, faulty electric cord. 2. the attachment or floor nozzle not being properly attached( kind of a duh issue LOL)
3. a faulty switch assy. the switch can be kind of a bear to replace. I hope it is the cord. if not i would take it to a kirby repair person, because it is very easy to damage the motor assy when replacing a kirby switch. trust me i have damaged a few learning how to do it
Jun 21, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G6 no power
Could be the switch, I would check the cord 1st. It has 2 wires running thru it, one may be open. That power cord goes bad often, if anyone is pulling on the wire rather then the plug, then it would have have stretched and break.
Jan 15, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
108 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
