Rubber cup top of television tube is loose does this matter and what is it
  • gottaproblem
    gottaproblem Feb 12, 2008
    televisions going to the tip! swapped transistors, loosely put the back on, plugged her back in, turned it on, there was a flash of bright white light (fuse blowing) and thats about enough of that.
    thanks for your help
    cheers
    rob
  • 2,130 Answers
The rubber cup supplies the high voltage to the CRT. The cup will move around a little but it should not be loose. Make sure you let the TV set bleed off the high voltage before you touch this connection. The correct way to discharge this lead is to attach a lead to the chassis ground and the other end to a screwdriver and insert the screwdriver under the rubber cup and touch the metal lead under the rubber cup. Make sure your hand is insulated when doing this. You can remove the rubber cup by grabbing the rubber boot and squeezing it. This compresses the clip under the boot and allows you to remove the lead from the CRT. make sure you do this with the set unlugged and with the CRT anode fully discharged.
Good Luck,
- Jim
Posted on Feb 12, 2008
When i use my reusable k cup, water comes out all over
Use the $15 reusable Kcup with a rubber seal ring. If the lid is not down and sealed it will over flow with grinds. Press down firmly after filling with grinds. Also, clean tubes Top/Bottom with a paper clip to free them from debris that clog the tubes. Use distilled water also.
Jan 07, 2014 | Keurig Coffee Makers & Espresso Machines
Want to recycle. How do you get clip off picture tube?
Most places will take the set whole--if you are talking about the red lead with a rubber cup on side/top of picture tube=
It is held in with a two piece clip---insert a large flat screwdriver and press first on one side and when it releases pull up and repeat with other side--it is the Anode lead and if set on recently you can get shocked---attach a wire to the screwdriver and touch the connector while the wire at other end is touching gray paint or spring on side of tube which is earth ground.
SD TECH
Apr 24, 2012 | RCA F27678BC 27" TV
Codigo p1440
EVAP System Vent Circuit Malfunction
This diagnosis detects leaks in the Evaporative Emission (EVAP) purge line using of vapor pressure in the fuel tank. The EVAP canister vent control valve is closed to shut the EVAP purge line. The vacuum cut valve bypass valve will then be opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP control system pressure sensor can now monitor the pressure inside the fuel tank. If pressure increases, the Engine Control Module (ECM) will check for leaks in the line between the vacuum cut valve and EVAP canister purge volume control solenoid valve.
Possible causes
- Incorrect fuel tank vacuum relief valve
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Leak is in line between intake manifold and EVAP canister purge volume control solenoid valve
- Foreign matter caught in EVAP canister vent control valve
- EVAP canister or fuel tank leaks
- EVAP purge line (pipe and rubber tube) leaks
- EVAP purge line rubber tube bent
- Blocked or bent rubber tube to EVAP control system pressure sensor
- Loose or disconnected rubber tube
- EVAP canister vent control valve and the circuit
- O-ring of EVAP canister vent control valve is missing or damaged
- EVAP canister is saturated with water
- EVAP control system pressure sensor
- Absolute pressure sensor
Possible solution
- Loose fuel filler cap
- Leaking fuel filler cap
Hope helps (remember to rate this answer).
Jan 05, 2011 | 2000 Hyundai Sonata
I had an emission test done on my 98 bonneville and it failed because code P0440 evap control system what should i do ?
Here's list why your car is coming up with this code. It could be any of these things causing it.
DTC detecting condition:
  • EVAP control system has a leak.
  • EVAP control system does not operate properly.
Possible cause:
  • Incorrect fuel tank vacuum relief valve
  • Incorrect fuel filler cap used
  • Fuel filler cap remains open or fails to close.
  • Foreign matter caught in fuel filler cap.
  • Leak is in line between intake manifold and EVAP canister purge volume control solenoid valve.
  • Foreign matter caught in EVAP canister vent control valve.
  • EVAP canister or fuel tank leaks
  • EVAP purge line (pipe and rubber tube) leaks
  • EVAP purge line rubber tube bent
  • Blocked or bent rubber tube to EVAP control system pressure sensor
  • Loose or disconnected rubber tube
  • EVAP canister vent control valve and the circuit
  • EVAP canister purge volume control solenoid valve
  • EVAP canister purge volume control solenoid valve and the circuit
  • Absolute pressure sensor
  • Fuel tank temperature sensor
  • O-ring of EVAP canister vent control valve is missing or damaged
  • Water separator
  • EVAP canister is saturated with water
  • EVAP control system pressure sensor
  • Refueling control valve
  • ORVR system leaks
  • Fuel level sensor and the circuit
Apr 01, 2010 | 1998 Pontiac Bonneville
My toshiba tv has shadowy streaks on the screen what is the problem
If your TV is a old picture tube technology type try the following.
The following is for technical experts only
It is EHT cable contact problem.
Switch off TV. Remove all electrical wire connections including antenna cable etc.
Wait for few hours! Open the back cover. You will find a thick red colored cable connected to the picture tube through a suction rubber cup. Ease the rubber and slightly rotate it. Very little only. This will establish a new contact in the picture tube shell. Place the rubber cup in the same way. This just a suction cup and hugs the picture body and air tight.
Now switch ON try. If OK leave it. If not try the same way of waiting.
Failing to observe the cooling period,
You are likely to get High Voltage electric shock as picture tube acts as a storage current for few hours. ( Even switch is OFF )
Mar 30, 2010 | Televison & Video
The picture wouldn't come up so we opened the back and found a wire that is hanging loose and were not sure where its supposed to go...apparently it looks like it gives power for the picture bulb to work
BE CAREFULL!!! Is it a red wire with a suction cup on the end? If it is, it connects to the top of the picture tube (there is a little hole in the back of the tube at the top). Unplug the set first and under the suction cup you should see two little tabs. Turn the suction cup inside out to expose the little tabs and insert the two little tabs in the hole. You may have to sqeeze them together a little bit. After they are in the hole they should spring out and latch on to the edges of the hole. Let go of the suction cup and allow it to cover the hole and tabs and all. Hope this helps. Thanks and be carefull. This is the high voltage lead.
Oct 28, 2009 | Televison & Video
When I installed my delta replacement cartridges, RP1740 two handeled faucet, the water will not turn off no matter which way I turn the handle. I have a new rubber cup and spring. It looks so easy, I must...
Sounds like you might have the rubber cup seals installed upside down? The spring goes int he body first, then the cup seal goes over and on top of the spring.
Jun 25, 2009 | Delta Plumbing
Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
Apr 21, 2008 | Sanyo DS31520 31" TV
Disconnecting TV anode
first pull the rubber up then push one side of the pin in and pull up lightly n then do the same thing on the other side n u can get it out. good  luck
Oct 27, 2007 | Philips 27PT543S 27" TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
