Question about Canon Optura 500 Mini DV Digital Camcorder
Canon Optura 500 not turning on
I'm charging it right now, and the red light is blinking, so it must be charging. However, when I try to turn it on, most of the time it doesn't respond at all, even when it is plugged into the charger. Sometimes, it will "ding" like when it is starting up, the screen will turn on for maybe a half of a second, and then go black. I've tried removing the battery and putting in a new tape; same response. Help?
  • 64 Answers
SOURCE: No power
One of the fuses is blown on the main pcb, needs to go in for repair if you need to get the tape out i can maybe take some pics at work and post them for you to see sorry.
Posted on Nov 19, 2007
  • 12 Answers
SOURCE: CANON OPTURA 500
Were the battery goes there is a cover with a silver screw holding it on. There is a flex behind it that sometimes comes loose and causes the problem you have described. Remove the screw and cover and push on the part behind the cover. I work at canon and when we get a model like yours that usually is he problem.
Posted on Jan 01, 2009
SOURCE: Canon mv940 camrecorder won't power up even with charged battery
My friend went back to England and got it sorted there
Thanks
a
Posted on Jan 22, 2009
  • 10 Answers
SOURCE: Canon Optura 60 will not turn on, No lights when plugged in.Dead
never buy a canon. i have the same issue and it is not easy to fix. i dissasembled the thing already but too complicated. the lithium memory battery inside too is non user replaceable as it is illustrated in the manual. you got to have it serviced to replace it because that small battery is soldered. poor buyers....
Posted on Sep 06, 2010
SOURCE: Canon ZR90 Mini DV Digital Camcorder no power even
Batteries may need to be recharged or replaced if the error persists after battery recharge or replacement the unit may require a service evaluation. If the batteries currently in the device and it is not working properly, remove the batteries and wait for 30 seconds and re-insert the batteries. In doing so if your camera has a back-up or date and time battery, remove this battery as well. Removal of the back-up battery will cause a full reset of the camera and will clear any settings, including date and time.
Posted on Mar 13, 2011
Optura 60 cannot be turned on
Whether you think the battery is fully charged or not this sounds like a defective battery problem. Have the battery checked.
May 05, 2017 | Canon Optura 60 Mini DV Digital Camcorder
Where can I get a user manual for Canon camcorder Optura 500
You can download the user manual for this unit from this link, just click HERE.
Sep 26, 2011 | Canon Optura 500 Mini DV Digital Camcorder
My Canon T2i camera's red light blinking at the buttom when I turn it on and it's not turning on.
Red blinking light usually means that the battery has not been charged, or has not been charged enough. Make sure to charge it all the way to turn on your camera.
Jun 29, 2011 | Cameras
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Aug 13, 2009 | Canon Optura 60 Mini DV Digital Camcorder
CANON OPTURA 500
Dec 31, 2008 | Canon Optura 500 Mini DV Digital Camcorder
How to record with dates
you shoul really need to look at the instructional functions of the can corder . simply look for the settings for you to get the right file
Mar 13, 2008 | Canon Optura 500 Mini DV Digital Camcorder
Canon optura 500
I believe you need a stereo mic. This will have two black rings around the male input. When you plug it into the camera, it will "disable" the built-in mic. I don't believe it will matter if the attenuation is on or off.
Jun 21, 2007 | Canon Optura 500 Mini DV Digital Camcorder
Power cord and battery's support NO power to Video Camera
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
Mar 17, 2007 | Canon Optura 50 Mini DV Digital Camcorder
Canon Optura 500 Mini DV Digital Camcorder Logo
53 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
