FixYa.com
Tags:
Olevia LT27HVX 27 in. LCD Television
Olevia 227V lcd (by 3 users)
posted by darladog on Feb 12, 2008
I need to remove the stand so that I can mount the tv on the wall. I can't figure out which screws to remove on the tv to remove the stand,
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by davidbooth, posted on May 20, 2008
I have the same problem. The TV is an Olevia 227-S11. There are 2 screws at the top of the base but removing them did nothing. Thanks
Comment by tklambertjr, posted on Mar 16, 2008
how do i remove the stand to wall mount?
Best Solution
posted on Jun 19, 2008
Helpful (85)
dep292
Rank:Apprentice Apprentice
Rating: 85%, 3 votes
All you need to do is remove the two long screws on the back of the tv panel just above the stand, then the two short back panel screws AND the three short screws just above the two panel screws and the stand will come right off. DO NOT remove any of the other screws in the perimeter of the back panel. There is no need.
After much trial and error this is the correct and EASY procedure for this apparently troublesome task. Good Luck !!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 21, 2008
Not Rated (0)
hcforde
Rating: 0%, 0 votes
Unscrwew knob on back that holds on the gray cover on the back of the stand. remove the cover that the knob held on . Ther are 4 bolts under this that need tobe removed. Thats it.
Can you Help with these Flat Panel Televisions problems?
LT27HVX no sound!
I have a LT7HVX Olevia... Answer This...
says no signal when switched to...
I just hooked an hmdi cable to... Answer This...
Will not turn on
The power light is on, the... Answer This...
Olevia power problem
Just wondering where this... Answer This...
tv mode on the tv is acting up
the picture keeps running off... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
