Question about Apple iPod nano
Help I have a dell Demension 8400 with windows xp. Yesterday I wiped the hard drive and reinstalled win xp becaus of a virus problem. Now I haven't any sound. What must I do to restore it. Is there really a site where driver down loads are truly free? Al
  • eccshaker Jul 27, 2008
    No sound. Cut off and on slide on top.
How to put music on it
Posted on Feb 15, 2008
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
HELLO!PLAESE HELP ME.I HAVE dell vostro 1015 windows vista but i want to convert it into xp,the problem is whenever i try to install windows xp a blu screen appears saying that something about my bios
Are you using a full version retail or OEM copy of WIN XP to install? Or is it a recovery copy from another PC or laptop? You will need to use a full version disc to perform the retrofit. You will also need to download the WIN XP Drivers for your laptop from the Dell Site. You CANNOT "upgrade" install WIN XP over VISTA and keep your drivers, settings, files. Performing a WIN XP install will require a total wipe of your hard drive. Therefore you will have to save off all your personal files before you do this. Microsoft doesn't provide assistance for downgrade-type installations, so you must basically wipe your hard drive and then reload the OS.
Jan 07, 2012 | Dell Vostro 1015 Laptop
I wanted to wipe my entire hard drive on my old Dimension 8400 that contained windows xp on it and reinstall it with windows vista, which i have the cd for. however, when i did so, each time i try loading...
1. you will need to know 1st that the hard drive you are installing is compatible with the desktop.
2. Is the hard drive compatible with the new Operating system (VISTA).
3. Check to see if you have the hard drive properly inserted that is properly cabled and connected.This will render error in installation.
4. Make sure you are installing the Operating system correctly.
5. Some boot sectors become corrupt during a change in Operating system if the hard drive is not properly formatted.
6. Try formatting the hard drive again and re-installing.
Feb 12, 2011 | Dell Dimension 8400 PC Desktop
I have 2 identical computers . one has gotten a worm or something . and i cant even run a mal ware remover because of it . im at wits end , i was wondering if i could just get another hard drive and just...
You don't need to get another hard drive. You can just format (wipe) your hard drive and reinstall Windows, the device drivers and a
anti-virus program.
You need a CD of Windows and the product installation code. The product installation code is on the Windows label on the the back or side of the computer.
Did you get a Windows CD with either of your computers?
If so you can use this CD to install Windoes.
Oct 05, 2009 | Computers & Internet
I'm having an issue reinstalling Windows XP on a Dell Dimension 8400 PC.
Okay you need to boot from cd
put win cd in drive restart when asked to boot from cd hit enter
this should get you there
if not we'll have to change your boot options
Jan 15, 2009 | Dell Dimension 8400 PC Desktop
Error reinstalling Windows XP on Dell Dimension 8400
Sounds to me like the hard drive is bad.Download some testsoftware that does not require windows and test it.
Dell Demension 8400
Try this:
Go to the command prompt. click run adn then type cmd and then click ok.
on the command prompt type chkdsk /r /f then press enter, then a small window will pop uo saying that you need to schedule a scan after the computer reboots,just click ok or yes. after that restart the computer. This will check the HDD for bad sector or bad cluster and then fix it, this may take time depending on the problem (if there is). I do not think it is cause of virus for you can use it for over a month, mostly if you are infected your computer will not last long.
Apr 30, 2008 | Dell Dimension 8400 PC Desktop
Insert the winxp disk and boot from that, when prompted hit any key to boot from cd.
Win xp will start to install choose to delete the partition, confirm delete.
then press enter to install to that unallocated partition, choose format to NTFS.
Follow the prompts and it has formated the hard drive and will install XP.
Apr 30, 2008 | Dell Inspiron 8500 Notebook
Apple iPod nano Logo
29 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
