Question about Ahead Software Nero 6.0 (60045) for PC
Power Calibration Error.
I am just try to write a cd means most of the times my nero gives the error called power calibration error.
    Problem Solver:
  • 5 Answers
First re install your nero .and
A) Power Calibration is controlled by the recorder. Before any write operation, all recorders must do a 15 step power test to determine the optimum power for writing to the CD; this is called "Optimum Power Calibration"(OPC). And during the write, it continues to do this test to get the best write throughout the whole CD; this is called "Running Optimum Power Calibration" (ROPC). This whole process is controlled by the recorder, though initiated by programs such as Nero. There is an area on the inner part of the CD for the test and test data info to be stored. You can use this area up to 999 times.
So, when you receive the "Power Calibration Error" or "Power Calibration Area full" error message, then the cause will be either poor media, poor Power, or a defective Recorder.
POSSIBLE SOLUTIONS:
1) A might enable the OPC on this medium
2) Try another brand of CDR or CDRW media.
3) Also try different power connectors, and for recorders, do not share power with other devices. It needs its own power connector. If this occurs with an External recorder, the power source in the chassis could be the cause. Take the recorder out of the external chassis, and connect it internal, as a test.
4) Try different configurations, such as taking the CDROM to the Primary IDE bus as Slave, and have only the recorder connected to the Secondary IDE bus as Master.
5) Send the recorder in for Service.
Here is the direct Link: http://www.nero.com/en/632181809668074.html#23
I Hope this helps,
Posted on Feb 13, 2008
DVD RW doesn't write(power calibration error)
Uninstall Nero from your system completely with from registry then restart system and again install nero then try.
I hope that this has been very helpful for you
Dec 03, 2009 | Intel Motherboard
Power Calibration error
powe calibration error reffers to lens laser power
in other words the laser doesn't have enough power to write CD/DVD at specified speed
try to clean the lens (there are special CD-s for that)
and try to burn the cd or DVD at slower speed
but slowly your cd writer is dying
Jul 08, 2009 | Sony Computers & Internet
Dvd burning abort everytime because of "power calibration error"
you can try changing power plug or just get your device cleand some times when to much carbon gets into points the currents is effected...
Jun 01, 2009 | Sony DRU 510A DVD±RW Burner
CANNOT WRITE CDS
Had a drive that did the exact same thing myself. You'll need to replace the CD drive. It's cheaper than having it repaired.
May 30, 2009 | Intel Computers & Internet
My DVD Ram drive is not reading any CD/DVD
The most common reasons for a power calibration error is a dirty lens or bad media. Clean the lens with a short burst of cabbed air or carefully wipe it with a cotton swab.
Good luck.
Mar 17, 2009 | Microsoft Windows Vista Business DVD...
Power calibration error
change the cables of dvd drive, also check power
Sep 28, 2008 | Imation 16575 2.4x DVD+RW Storage Media
POWER CALIBRATION ERROR
Power Calibration error indicates that the drive hasn't been kept clean and is unable to guarantee a good write to disc...
I recommend a wet and dry CD/DVD Cleaner disk with Alcohol on the wet side (Like Tape Head cleaner liquid) and let it dry for a minute then run the disc again... if it still happens the drive is on its way out.
May 25, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Power calibration eror
Just install Nero 6 and that will fix it!!!
Nero 7 and 8 have communication problem with DVD RW drive!!
good luck
Jan 22, 2008 | Imation 16575 2.4x DVD+RW Storage Media
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
this can be a complicated issue to solve, so go to the link below and see if there is any advice that is rellevant to you http://www.cd-burner-help.com/power-calibration.htm
Jun 03, 2007 | LG (8526B) CD-RW Burner
Ahead Software Nero 6.0 (60045) for PC Logo
285 people viewed this question
Top Ahead Software Computers & Internet Experts
Lakshman P
Jax Planet
Jax Planet
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
