Sharp AR-5320 Black and White Copier Logo
Posted on Jan 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
L4 error code - Sharp AR-5320 Black and White Copier
Anthony Karuku
Level 2:
  • Sharp Expert 268 Answers
  • Posted on Jan 30, 2010
Anthony Karuku
Sharp Expert
Level 2:
Answers
268
Questions
Helped
104874
Points
615
L4 means that there is an overload in the drive system. Check the developer unit if its running smoothly or the drum. Make sure the exit unit is not jamming. This can be done by openning the cover on the right side and you will see a small motor. Clean its sensor.
Sharp Printer. How to fix error code L4-17
Error Codes > Sharp > MXC300W > Code L4-17
PrintCopy .info https://printcopy.info > brand=Sharp > code=L4-17 Code: L4-17; Description: Drum motor lock trouble; Causes: Drum motor trouble Connection trouble of the connector and the harness between MFPC PWB and the ...
OCE CM4010 L4-06 error
Hi Felix.
The link will take you to the answer and possible resolutions. Thread Sharp MX 3501N ERROR CODE L4 06
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
2helpful
Error code L4-02, what is the error?
In the Sharps, a L4 error is some kind of motor error. Not sure about L4-02 on the 355.
20helpful
4answers
Error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
11helpful
2answers
Sharp photocopier with error code L4-01
Hello sir L4-001 that's driving problem, check the main motor ,gears belts.
4helpful
Error L4
l4 if sub code is 01 .check sub code by pressing start key .that is for main drive motor and gears .just check all main drive properly mian jee
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
